Question about Dewalt Air Tools & Compressors
What size capacitor is used for a emglo airmate am78-hc
SOURCE: compressor will not shut off
My emglo electric air compressor will not shut off when it reaches 90psi that I set it for and it keeps going so I have to shut it off manually because I am afraid it will blow up if I don't shut it off . The switch works manually,;what is stoping it from working automatically to the pressure I set it at? Model # AM78HC4V
Posted on Jan 01, 2009
  • 9 Answers
SOURCE: I would like to know the type of oil and
any small compressor oil will do like dewalt,quincy....or 30 sae oil
Posted on Jun 05, 2009
  • 12 Answers
SOURCE: emglo airmate AM78HC4V; when trying to start
I had the same problem. Replace the motor capacitor. small white cilinder part with two wire plugs conected to it. This will have a single bolt holding it to the frame casing, you will find it under the black plastic shroud that covers the motor. Take it into any electrical or compressor shop and they will check it for you. costs about $35.00.
Posted on Jul 07, 2009
brewerstool
  • 141 Answers
SOURCE: Have emglo airmate when I turn it on the overload
It could be a couple of things. To me it sounds like you have a short in the motor or damage to the cylinder and piston. You need special equipment in order to test the armature and field for a short. There may also be damage to the brushes and brush holder. There could also be a problem with the cylinder and piston. The bearing could be bad causing a hard start for the motor. I think it could be the combination of the two problems listed above. You may want to check the pump first and if that is not the problem it is an electrical short in your motor in which case you should buy a new compressor. It will cost more to fix if the motor is damage than to buy a new one. "BER" Beyond Economical Repair.
Posted on Oct 01, 2009
braintrust
  • 62 Answers
SOURCE: i need the assembly instructions for an emglo
there is aweb site called www.mastertoolrepair.com in the search type am77 should get schematic break down for your compressor, then go to internal parts and you should get a brek down and schematic on your compressor hope that helps
Posted on Oct 27, 2009
Owners manual for Emglo AM78-HC4v
Try Googling (emglo)(AM78-HC4v)(manual) without parens.
Mar 26, 2018 | Air Tools & Compressors
Can i substitute common motor oil for the proprietary oil sold for my AM78 Emglo 2-tank air compressor?
Dewalt claims that motor oil will cause carbon deposits to form on piston/cylinder head and on the inside of the discharge tube. I see carbon deposits on most all compressors that come in for repair. The carbon is not reason for repair. Usually forgot to add any oil causing rod failure. I believe that most compressor oils are just mineral oil. If the climate in your area is moderate, and you do not use the unit for 8 hours a day, motor oil will work just fine. The crank is steel and the piston rod is made of aluminum (no bearing shell). What makes the unit last longer is change the oil more often (holds very little oil). Good luck
Aug 11, 2011 | Dewalt d55151 factory reconditioned emglo...
Owner's Manual for AM78-HC4V
Hope this helps:
http://www.jennyproductsinc.com/manuals/JennyCompressorManual.pdf
http://www.jennyproductsinc.com/manuals/AM780-HC2.pdf
Jun 17, 2009 | Jenny Products Inc AM780-HC2 1.5 Gallon...
Emglo airmate AM78HC4V; when trying to start compressor the motor will only hum
Jun 08, 2009 | Dewalt d55151 factory reconditioned emglo...
Manual for Emglo Air Mate Compressor
Manual for the similar dewalt model is at www.dewalt.com, click on parts & service icon, then enter D55151. Or try clicking here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/5135175-01,D55152,Elec.pdf This Dewalt compressor is one of many versions of the Old Emglo AM78 compressor. There are several other brands built with the exact same design such as the Senco line. For parts list of actual Am78hc4v go to mastertoolrepair.com. If you have questions or problems with this compressor please email, Good luck
Jan 28, 2009 | Dewalt d55151 factory reconditioned emglo...
Compressor will not shut off
The switch is bad, replace it, this should solve the problem.
Nov 17, 2008 | Dewalt d55151 factory reconditioned emglo...
Air Tools & Compressors Logo
368 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
