Question about GPS
How to remove and change the battery in a Tom Tom GO 540 Live.
  • 56 Answers
Answer: AnswerI have TomTom 910 in USA, (and I have one in the UK). Access to the battery is behind the front screen but the plug is under the circuit boards.
1) Remove 4 screws under ends of rubber strips on back. (All screws are Torx number 6)
2) Remove back cover. Front frame around screen comes off easier now.
3) Remove 2 screws in round top circuit board. Remove 4 screws from lower circuit board. These two boards may have a glue connection. Do not worry if it separates
4) Lay back circuit boards to unplug battery. Note flat ribbon cables are fragile. The 3 wire plug is the battery. Unplug wires to battery from receptacle on circuit board.
5) Remove front screen by pressing a screwdriver against the small metal tags that follow the edge of the screen. The tabs need to be pushed in slightly to allow you to lift the screen out. It may need some leverage, but be careful not to put the screwdriver to far behind the screen as there are a couple of thin cables for the connections.
6) To remove the hard drive you may need to unscrew the vertical black tags about 2 cm long. These simply come away and are grasping the business card size silver box IE the hard drive. The rubber end caps are pressed in, pry out with small screw driver.
7) Remove battery and replace. Note the two sided sticky tape around battery. When putting more tape on, be careful you do not put to much around the right hand end as it will connect with the thin cable when you put it all back together.
9) Reverse assembly. Mine works fine now, good luck. (and so does mine! BLP)
Footnotes: I did not have a Torx #6 screwdriver nor could I buy one locally. I found a #7 mini star bit works just fine. Source: Harbor Freight item # 93316, 6 piece Mini Star Bit Set - $3 PMVN - 9/19/2009
I am not advertising but Batteryship.com included with the battery #5 & #6 torx screwdrivers, a very small philips (star), a straight screwdriver and a plastic pry tool. Whatever I paid more than another place it was worth it.
When disassembling do not remove the battery clip. Just pop out the battery from the front (experienced having to reassemble that whole thing). Also having a set of tweezers to put the electrical connections back together helped a bunch.Not sure if this will help but they may be close designs
Posted on May 24, 2011
Unit will not come on
Make sure everything is fully charge and if you can try to change the battery to check if its a problem with the battery...
Hope that helps..........
Sep 30, 2008 | Tomtom GO 910 GPS Receiver
My gps has the wrong time
you did not state a question,you only stated that you have a tom tom 540s.
So what's your question?
I look forward to your reply,
Bye for now.
Jul 25, 2010 | Tomtom ONE GPS Receiver
Deseo cargar mapa de Uruguay en tom tom one, como
amigo , yo tenia el mismo problema de mapas con un gps de un tomtom y otro con sistema wince ,luego busque y me recomendaron un servicio tecnico en cap fed argentina y me cargaron argentina y uruguay,ya me lo solucionaron,ahora quedo barbaro !! te paso la pagina ,espero que te sirva ,salu2 http://www.mapeo-gps.com.ar/
Jan 09, 2010 | Tomtom ONE GPS Receiver
ALL Voltages (three wires) iones battery of Ton Tom one
Not sure why you would need to know this , red is live black is return circuit and the yellow is auxilliary and usually goes to charge input. as a live wire It is easier to cut and graft a new battery to the stubbs of wire than to solder new battery on. What you might really be needing is the polarity.. whether any charge pin is positive or negative if you are making a new internal charge point. Consult the back of the charger it usually states the polarity in a graphic.
Jul 23, 2009 | Tomtom One XL GPS Receiver
Removing a TomTom from my TomTom account
email in to have device code reset, attach receipt
May 22, 2009 | Tomtom One Europe v2 GPS Receiver
Mobile phone won't connect to Tom Tom go 540 live
Hi, I got round this problem by pressing and holding the ON/OFF button for 15 seconds untill system reboots. Then reconnect mobile,if not delete mobile and repeat process.
Apr 05, 2009 | GPS
1999 540i AC problem
tom disconnect the battery for 5 minute hook it up and try it if ac work sometime computer shot out you disconnect and it reset the computer it hapen to me on my 98 540 good luck pierre
Sep 06, 2008 | 2002 BMW 5 Series
Tom tom one battery change
I too dropped my tom tom go 300. It appears the battery was disloged as it will only work if attached to another power source; AC Adapter or cigarette plug. Does anyone know how to open the case to check on the battery?
Feb 28, 2008 | Tomtom GO 300 GPS Receiver
Tom tom 300
you have te release the front cover. Then you see a couple of torx screws. Release them and the tomtom is open. You can change the battery
Jan 04, 2008 | Tomtom GO 300 GPS Receiver
GPS Logo
203 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
