Question about Microwave Ovens
Whenever using my microwave, it sparks/arcs where the silver mesh fits onto the ceiling of the microwave. The silver mesh also needs replacing as it has deterioted... Please assist. There are no serial numbers or info on the microwave to identify model. It has a silver powder finish. And process of elimination does not match the four listed on your site (do not look like mine). Thanks
  • Microwave Ovens Master
  • 9,047 Answers
There should be a model number tag inside the cooking cavity, near or around the door frame or control panel, or on the back of the oven.
You can find links to helpful exploded view diagrams and part ordering help for most brands here.
I recommend that you bookmark that link to your favorites.
If you can't find the model number, you'll need to order a piece of universal waveguide material and use the old waveguide cover as a template to cut out a new one.
You can find that at Encompass here or you can call them toll-free at 866-779-5835.
It is part # 40QBP1012 UNIVERSAL WAVEGUIDE MATERIAL 10" X 12" (Cut To Fit)
If you don't have the old one, you can use a sheet of paper to trace the area where it goes, then transfer that pattern to the waveguide material, which can be cut with a razor, utility knife, or scissors.
Posted on May 26, 2011
I have a Sharp Carousel Microwave R-1460A. The disk on the ceiling, opposite the warming plate and about the same size, has severe burn marks (probably from food splatters). Any idea what that part is
see this indication and fix it. God bless you
  1. Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  2. Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity pain
Nov 08, 2013 | Sharp R-1460 Microwave Oven
Panasonic genius sensor 1250w
follow this test and fix it. God bless you
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity paint.
Oct 27, 2013 | Microwave Ovens
Lg combi multiwave
see the troubleshooting section and follow the steps and fix it.
God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Sep 30, 2013 | Microwave Ovens
Sparking in microwave (aftron make)
test this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#10#ixzz2aaus0Uj3
Jul 30, 2013 | Microwave Ovens
Oven aftron
follow this steps and fix it. God bless you
Brown spots on window of microwave
see this steps and fix it.God bless you
  • Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  • Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  • Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity paint
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#10#ixzz2aSjW5F9U
    Jul 29, 2013 | Microwave Ovens
    Rust or brown spots on window of microwave
    Microwave when turn on making a noise and sparks comin from fan area?
    Waveguide Cover
    Rack Support
    Feb 06, 2013 | Turbo Air TMW-1100M Green World 1000 Watt...
    Popping and shooting sparks
    Hi There!
    Check behind the "Wave Guide Cover" on the inside cavity. There may be moisture or food residue behind it. Should be a cover that is plastic or Mica. Really strange that it's sparking being new. Also check that you use plates without gold or silver trimmings (Crockery or porcelein). This will also cause sparking. Remember that microwaves will always go to the first organic source in its path. The wave guide cover, if soiled, is very close to the tip of the Magnetron and will therefor result in arcing. Good Luck, JUS004
    Feb 26, 2008 | Frigidaire PLMV169DC Microwave Oven
    Microwave oven defective
    It's actually a stirrer. Its purpose is to scatter the microwaves to ensure even cooking, similar to the way a turntable does in other models. Having a stirrer instead of a turntable allows for a bigger dish.
    The sparking is usually caused by deposits or grease or food debiris which heat, reheat and arc.
    If the oven is used very long without the cover, that debris and grease can get onto the magnetron and ruin it.
    You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
    Aug 30, 2007 | Jenn-Air JMV8208AAS Microwave Oven
    Microwave Ovens Logo
    70 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
