Have inherited a ferguson record and tape combination player studio 20D and its a wonderful piece of equipment but I cannot get any sound out of it and I was wondering if i HAVE TO BUY SPEAKERS for it and where would I plug them in thanks eileen
Yes it will need a pair of external speakers which must have a speaker plug on each of the speaker cable. They plug into the speaker sockets on the back of the unit.
Posted on Jun 21, 2013
    Brigadier General:
  • 8,546 Answers
Most of those old relics had built-in speakers, which may be dead by now or simply disabled.
Barring that, the audio output could be run to any audio device (EXCEPT PHONO which is reserved for turntables).
There are many open-reel forums online where you might post questions for enthusiasts to answer.
Posted on May 24, 2011
8mm JVC tapes put into a VHS tape that will play on a combined TV and VCR. Please, please, I need your help! Found tapes from 15 years ago.
You need an 8mm player or the camera that recorded the tapes. Connect the video and audio from the 8mm player/camera to a VHS recorder. Put the 8mm on play and the VHS on record.
Jan 08, 2015 | JVC P-6120JDU Video Cassette, 8mm 120...
How do you extract audio from Maxell Hi8 tape?
easy: locate a local audio/video transfer place or videography studio that you can hand these off to. Request mp3 format on CD as the mode of delivery. Usually they have the equipment needed and it isn't very expensive. Some will even clean up the sound for you.
Slightly more difficult: locate a hi-8 player, buy a $30 conversion cable that goes from the hi-8 camera or hi-8 deck to your computer (type of cable will depend on the type of camera you get and type of computer you have), download video editing software and capture the tapes. Once the files are in the computer you can export as mp3 and burn a disc.
Apr 04, 2013 | Electronics - Others
I expected that the RCA leads from my turntable would just plug into the back of the RCD-W500C, but the manual indicates a somewhat complex cabling arrangement through the amplifier. I have not been able...
Your new cd player/recorder is a "component piece" as is your turntable,cassette player, reel to reel or CD player. Connect it as you would any other component piece of stereo equipment. Set up your recorder to "record" in real time(not high speed or synch record). Your tape recorder records anything that is playing through your reciever to your speakers. So, treat your "CD" recorder as you would a "CASSETTE TAPE" recorder. Play your vinyl record on your turntable and record to CD on your CD recorder ! Pay special attention to the dubbing speed, you will not use "synch or high speed !! Good Luck
Feb 26, 2011 | Audio Players & Recorders
I have a recording that is what I want except at one point someone coughed. Is there a way to edit out just that one second that messes up the whole recording?
You can copy this sound recording to the PC and use a program called Sound Forge 6 , which can edit off all the unwanted noise and feed back the edited sound to yourr player.
You can get help ffrom any video studio to do thsi job.
the other way is to use your tape recorder, edit and rerecord.
Sep 19, 2010 | RCA VR5220 Digital Voice Recorder
I just inherited an old Zenith console turntable and stereo combined. Stereo sounds wonderful, but when I play records, the sound isn't loud. Is this a problem with the needle or what? When I touch the...
Hiya, check and be sure the turntable is plugged into correct inputs, "phono"
If thats OK, then probably is the stylus but could also be the cartridge itself. Check the wires on the back of cartridge make sure they are fixed properly. If all Ok, then start with a new stylus first.
Hope it helps
Jul 25, 2009 | Audio Players & Recorders
Dvd vcr will not even recognise a tape in the recorder... we rarely use the vcr part of our combo but the tape player does nott
put a piece of scotch tape over the little square on the tape platic case bottom left......your recorder thinks it is a protected tape
Jan 18, 2009 | RCA DRC8300N DVD Recorder/VCR
Recording a DVD from a VCR
only if the tape is not the prerecordrd kind!
Dec 10, 2008 | Toshiba MW24FP1 24-inch TV/DVD/VCR...
No sound coming through when recording from hi fi tape to computer
This is actually simple to do. Connect the line out on your tape player to the line in on your computer. Then download a free program, from the net called Audacity at http://audacity.sourceforge.net/. The program is totally free and works great. Some recording studios use this program. In the middle of the main Window on Audacity set it to record from Line in. This is from the small drop down menu next to the little microphone icon. Then hit the record button on Audacity and play your tape. You can record each song individually or you can record the whole side of the tape at once and separate the tracks when you save them. You can even use this program to clean up the sound on your recordings. I have transferred many of my tapes and records to CD using this process. I hope I have been helpful and good luck
Jul 01, 2008 | Genius Soundmaker Value 5.1
Converting Hi-8 camcorder tapes to DVD
Did u try to connect your cam to a DVD recorder and record a dvd with the information from your tapes? Or I suggest to go to an electronic store and ask about a video converter package (Plextor and Dazzle both from Pinnacle Studio) and they will give you all the information. If you have more question please do not hesitate. Best regards
Feb 04, 2008 | Sony Handycam CCD-TRV87 Camcorder
Playback sound
Unit might be picking up 60 cycle hum or other electromagnetic field. Is VCR sitting on/under another piece of electronic equipment? If so, it could pick up such from the power supply circuitry of that other device. Try moving the VCR away from other equipment and see if the unwanted sound disappears.
Mar 09, 2007 | Philips VR550 VHS VCR
87 people viewed this question
 Grubhead
Grubhead
