Question about Nokia 1112 Cellular Phone
How restore factory settings - Nokia 1112 Cellular Phone
How to take laptop back to factory settings
Depending on the brand and year it was made there may be a factory partition that will restore computer back to factory defaults, if not then a reinstallation of windows will be necessary, If factory partition is available just do a search o Google with your make and model # such as : How to restore an Acer Aspire 7425 to factory defaults using recovery partition
Mar 15, 2014 | IBM ThinkPad T40 2373 Notebook
How to restore to factory settings
Go to the ASUS WEB site for instructions -
ASUS Notebook Restore to Factory Settings
http://en.kioskea.net/faq/4162-restore-an-asus-netbook-to-factory-settings
Sep 01, 2012 | ASUS F3F Notebook
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
I forgot my pasword, and i want to restore my factory setting on this phone been nokia 3600 slide so help me
Straight from the manual:
Restore factory settings To restore the phone back to factory conditions, select Menu > Settings > Rest. factory sett. and from the following options: 1. Restore settings only - to reset all preference settings without deleting any personal data 2. Restore all - to reset all preference settings and delete all personal data, such as contacts, messages, media files, and activation key
Best of luck!
Mar 15, 2011 | Computers & Internet
How to reset factory defaults to CK31? How I can put the settings to access WPA2 in wireless network?
Restoring Default Settings
You can restore the CK31 to factory default settings from
Intermec Settings.
Note: Using the Restore Defaults option restores all parameters
including network settings. When you choose to restore defaults,
you erase the registry. As a result, you may lose network
communications.
To restore factory default settings
1 From Intermec Settings, select Device Settings > Restore
Defaults.
2 Select Restore Defaults and choose the Run App button. A
Run Application dialog box appears asking if you want to run
the restore defaults program.
www.portablesolutions.com
May 12, 2010 | Intermec CK31 Portable Terminal
I cannot restore the factory setting for my nokia 6030 mobile
1 way: Select Menu > Settings > Restore factory settings
or:
*#7780# reset to factory settings.
Jul 31, 2009 | Computers & Internet
Forgot password to acess< and or its still default setting. could you tell me what the wireless 700 routers default password is
Restore Factory Default Settings When you restore factory default settings to the base station, you clear your Internet connection settings and any special base station configurations that you have established. After the restore is complete, you will need to reconfigure your base station settings or restore these settings from a backup file. You should restore the original factory default settings only under the following circumstances: O You are experiencing serious problems with your base station, and resetting the base station does not fix the problem. O You cannot remember your base station password. In this situation, you must restore the factory default settings by using the Restore button on the base station, and then use the default password admin to log on to the Base Station Management Tool. To restore factory default settings 1. Open the Base Station Management Tool, and then click Management. 2. On the Management menu, click Back Up and Restore Settings. 3. Under Restore factory default settings, click Restore Factory Default Settings. While the original factory default settings are being restored to the base station, the Power light on the base station turns orange. When the light is solid green, the settings have been restored. If you want to open the Base Station Management Tool after the settings have been restored, type admin as the password on the Logon page. Do not attempt to log on to the base station until the settings are restored and the Power light on the base station is solid green. After you restore the factory default settings to the base station, you should navigate to each page of the Base Station Management Tool and reestablish the network settings you want, or restore the base station settings by using a backup file. For information about creating a backup file of your settings, see the following section. Be sure to establish your unique base station password as soon as possible after restoring the factory default settings to prevent unauthorized users from logging on. For more information, see “Change the Base Station Password.” please rate this answer, thanks
Jan 30, 2009 | Microsoft MN-700 Wireless Router
Ibm restore to factory setting
You have not explained what is wrong with your computer.
Is the laptop working, does it boot up into Windows?
What are you trying to restore?
Are you trying to get into a previous Restore Point?
The Access button takes you into the BIOS, you can change the BIOS settings back to the Default settings (ie the factory default settings).
It is difficult to offer a solution without knowing the exact nature of the problem.
Nov 23, 2008 | IBM ThinkPad R50e Notebook
Nokia 1112 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
