Question about Bernina Artista 180
Feed dogs don't want to feed.
I have a Bernina 180, a lemon I might add, and my newest problem is the feed dogs don't push thin fabrics through without puckering them and hanging up completely on seams.
By thin fabric I mean rayon or cotton. I have adjusted the pressure on the presser foot to have more contact with the feed dogs but I still have to pull the fabric from behind to prevent it from bunching behind the pressure foot.
I had it timed and tuned only a year ago and do not use it for weeks at a time. I am a seasonal sewer .Do you have any suggestions besides another tune up.
  • smso Sep 01, 2008
    Continue to have the same problem? can I fix it myself?
  • Crayoneater May 11, 2010
    Was the person that gave you a tune-up Bernina certified? With the machines today you simply can't take it to a general technician. They don't have service manuals available for all makes and models out there and parts would be an arm and a leg. Puckering may be caused by tension, feed dog height (0.9mm), presser foot height (7.5mm), timing, zig-zag stitch without stabilizer, etc. Bernina is not in the business of making lemons, their track record is second to none. You bought the Lexus of sewing machines, why not take it to a Lexus dealer if possible? There is a number of checks you can do, but the timing on many of these machines requires pinning several gears. Feel like taking some measurements and confirming some details? You won't have the tools but perhaps we can confirm some measurements with a feeler guage if you might have?
    Problem Solver:
  • 8 Answers
Sounds like the feed dog height is not set correctly. You could fix it yourself but you would need a dealers service manual and there is a height gauge that should be used although I have set them by eye...and experience.
Bernina's are fantastic machines and I have yet to find even one that is a lemon. Just like finding a good auto mechanic, you need to find someone that actually knows more than how to blow off lint and apply oil.
Your problem should be a low cost quick fix/adjustment that can be accomplished by a knowledgeable and skilled technician.
Good luck finding one!! Bill
Posted on Sep 27, 2008
  • Mary Dunn
    Mary Dunn Nov 13, 2015
    Use a dime to set the height.
The presser foot doesn't sit all the way down in order to sew correctly. Can I adjust it myself? How?
Has that particular presser foot worked in the past? Do the other presser feet work?
If it hasn't been used before, check that it is the correct foot for the machine. Is it perhaps a darning foot or free motion foot? If so, those particular feet are made to Not rest on the feed dogs so that the fabric can be manually moved without the use of the feed dogs.
If none of the presser feet work with the machine, then the needlebar has probably shifted. It may be best to take it for service as it may require specific tools and gauges to adjust it properly.
Presser feet for every purpose
Manual:
https://www.bernina.com/en-US/Support-US/Machines/BERNINA-artista/BERNINA-artista-180
Jun 05, 2016 | Bernina Artista 180
How do I drop the feed on my Bernina 180?
On the right side of the machine is a square button near bottom of machine. Push it in until it stays in. That is the way to lower feed dogs
Feb 18, 2015 | Bernina Artista 180
How do I lower the feed dog on m Bernnia 180
Push in the square button on the right side of machine until it clicks. Then push in again until it u clicks. The feed dogs will raise once the machine starts to sew again
Bernina Virtuosa 150 Presser Foot Loose
try increasing the presser with the adjuster
Feb 10, 2014 | Bernina Virtuosa 150
Why does my needle keep breaking when I use the blind hem stitch? The needle is not entering the hole in the sole plate correctly. How can I fix this?
Machine breaks needles
1.make sure you are using the right needle for your type of sewing machine.
Most machines can use generic Schmetz needles. There are cases where the machine will only use ones specified in the owners manual.
2.the presser foot may not be installed properly
3.use the correct needle for the type of fabric you are working with. To fine of needle on heavy fabric or to course a needle on silk or jersey can damage fabric.
4.let the feed dogs guide the fabric & the feed dogs will work with the presser foot .
5.the needle is not all the way in -push all the way up against the stop
Mar 24, 2012 | Bernina Artista 180
My Bernina 180 will not feed when I use a twin needle on knit fabric.
are you using a stretch twin needle; without one you'll get skipped stitches. However, the feed sounds more like a feed dog issue. Have you lowered the feed dogs for any reason? Will it sew on a woven cotton okay? If yes, but not feeding the knit then you could try turning up the presser foot pressure and see if that helps with the feed.
If you look across the needle plate with the presser foot removed and manually turn it through a stitch sequence, can you see the feed dogs coming up above the needle plate??
Jun 13, 2011 | Bernina Artista 180
My bernina 1004 feed dogs wont move when switch is put into drop position.
Not completely sure about your B. 1004 but in my model Bernina, the feed dogs are lowered so the fabric can be moved by the operator, like when free-motion quilting. The feed dogs don't have contact with the fabric, there's no need to move.
Sep 16, 2010 | Sewing Machines
I hav e Bernina 1150. When I attach the walking
Hi, when you quilt straight lines using the walking foot, you need the feed dogs up, to move the fabric in a straight direction under the needle. When you do free motion quilting, which is done with a darning foot, your hands move the fabric in many different directions. Since you want to be the one to move the fabric, you put the feed dogs down and you do the work. So when you use the walking foot, keep your feed dogs up. When you use the darning foot, feed dogs down.
Feb 20, 2010 | Sewing Machines
Is there a way to lower the feed dogs ''a little''?
I thought this was free . . . didn't know I'd be asking to join. So, I called the shop where I purchased the machine. They were able to help me fix the problem.
Nov 12, 2009 | Bernina Artista 180
Bernina 1130 feed dogs won't feed fabric
On a Bernina 1130 the power on-off knob and the feed dog raise and lower knob look similar and are next to each other on the end of the machine, making it easy to lower the dog assembly entirely, without realizing it. Make sure you didn't accidentally lower the entire feed dog assembly by turning the feed dog knob: you can tell as you turn it if the dogs are up or down. On the Bernina 1130 the knob, like the power should be in the horizontal position to be working both feed and power.
Apr 10, 2009 | Bernina 1008
Sewing Machines Logo
386 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
