Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
We changed our pool over to salt water four days ago ago and it is cloudy and has green algae in it. It had green algae when we switched. We thought the salt water system would kill it, but it is still there. So, We boost the system last night on day four and still the same as when we started. Need some ideas to get things back on track. When we switched over the ph was high and no chlorine reading at all, but had green algae. We did add ph minus to bring the ph down. Should we add algaecide? Not sure what chemicals should be used in a salt water system. Thanks so much .
  • Intex Master
  • 8,404 Answers
You don't mention the size of the pool. If this is a above ground small pool ... dump the water, clean the liner and refill it. Remove the metal with a sequestering agent. Get the alkalinity correct. Get the pH correct then add the salt to 3200 ppm.
Chlorine kills algae. Are you sure it is algae and not metal in the water?
pH should be 7.2 to 7.6. Alkalinity should be 100. If a gunnite pool, the calcium should be 300. Salt should be 3200. Cyanuratic acid should be 50+ if this pool is outside (not indoors).
What to do. If this is a big pool, and you are sure this is not metal in the water, I would super chlorinate the pool - take it to 20 or so ppm. Run the filter for at least 24 hours. Watch the pressure ... you will be filtering out a lot of stuff.
Let me know what happens ...
Thanks for your question @ FixYa.com
Posted on May 24, 2011
Cloudy/green
super shock pool with chlorine it will just maintain
Aug 11, 2013 | Intex Automatic Salt Water System for ...
My intex saltwater system pool is cloudy
The chlorine level maybe too low and it is allowing algae to start growing.
Check the Ph level, it should be around 7.
Check the chlorine level in the pools water, use your chlorine test kit.
Check the salt levels, make sure it is at the correct concentration, too low a salt level and the Intex will not be able to generate enough chlorine.
Jul 03, 2012 | Intex Automatic Salt Water System for ...
Getting same green film on top of water that is the same color green as the copper piece in the salt water pump has turned
The two green colors may be associated somehow but when you say anything about green water I think it is more likely the water is turning green from algae. The best way to rule this out is to test the chlorine level and then shock with vinyl shock to about 10 ppm. If it is algae then the it may be cloudy but should turn more blue rather than green. If other chemistry is good such as salt concentration and stabilizer then running the pump, filter and chlorinator according to the Intex manual. When a pool is shocked the filter can get dirty quickly and then reduce the flow. For this reason make sure you clean the filter. I hope this helps.
Please vote on this answer. Thank you.
Aug 26, 2011 | Intex Automatic Salt Water System for ...
Two weekends ago I came back from a 4 day trip to a green stincky pool. Low flow, we cleaned the filter and scrubbed the algae, by morning a beautiful sight. Yesterday after not look at the pool over the...
You should definitely shock however the best solution for solving an algae problem, which is what you have, is using a product called
Algimycin 2000
this will clear up your pool in about 24 hours
US Parts Center
Aug 18, 2011 | Intex Automatic Salt Water System for ...
Problem is test strips indicate high copper ion (pink) and total alkalinity is low (light tan) Free chlorine is ok (between 0.5 and 1) and ph is good. We have this greenish silt like stuff on the bottom...
1st.. Clean the green (algae) stuff out..
2nd. Clean the filter...
3rd.. Repeat step 1 and 2 until most all the algae is removed..
4rd.. Brush you pool with a pool brush to remove the remaning algae...
5th.. Seems like you have the right chlorine level but not running your filter long enough??? After all steps are completed, run you filter at 8 hrs and your chlorinator between 3 to 6 hrs until your pool clears up.. After that, vacuum again and clean your filter... During the summer months, 4hrs is not enough circulation.. Hope this works for you and good luck.. Please take the time to write a comment if this works for you...Thanks..
Aug 07, 2011 | Intex Automatic Salt Water System for ...
Says it's working, but water is getting greener each day
Is this green from copper? If this is algae and you are certain ... shock your pool to about 20 or more PPM dry chlorine. Make sure your salt is at 3200 ppm. If it is metal (in the water) ... typical of new water ... let chlorine go to zero and then use a sequestering agent to capture the metal. Note: Use a "Bobby Sox" to fill your pool with new water. This filter will grab a lot of the metals and prevent brown and or green water. Another thought, if the acid level is high and you have a heater, the water may be eating the boiler and be putting the copper on the walls of your pool.
May 01, 2011 | Intex Automatic Salt Water System for ...
Cloudy and green water already put algae in pool
you may need to re-fill the pool now? the filter has not done its job fully and you havent tested the water,,for PH? or you would have spoted this comeing,,,the pool will need extensive filtering and cleaning now plus lots of chemicals put in it before you can use it
Aug 08, 2010 | Intex Automatic Salt Water System for ...
My pool became algae taken, so we decided to convert to salt water. Had so much trouble we just drained and scrubed and cleaned and started the whole cycle over. Its a 15x 48, but now the water is green...
There is metal in your water ... get a good sequestering agent ... let the chlorine go to 1 or less PPM ... treat with the 'metal out' agent per bottle instructions. You can fill using a 'bobby sock' filter to trap some of the metal.
Jun 27, 2010 | Intex Automatic Salt Water System for ...
High chlorine/cloudy/salt water pool
Purchase a PoolRx unit for your pool. PoolRx.com....No more algae!! Clearer water
Aug 26, 2009 | Pool & Spa
CLOUDY WATER
I too have this problem after treatment for algae, especially if I got a day or two without running the pump, it starts to get mildly green. After adding the algaecide, it kills the algae, but leaves what I call the white dead floating...it takes several days for this to phase out.
If you aren't already doing so, put 3" tablets in the pump basket housing, that helps dramatically. Put a pair of knee-high pantyhose (one inside the other), on the return inside the pool. (you will be amazed what it catches after a few days). Also you can try some "clarifier" to help clear up the cloudiness.
I'm no pool expert, but have dealt with the cloudiness myself. Through trial and error, have learned that cloudy water doesn't necessary mean dirty water. It will clear within a day or two if you are keeping stabilizer tablets in pump basket and using shock once a week. And run the pump for about 8-12 hours a day, it will clear up quicker. And to me, using the pantyhose is an extra-filter and it catches the 'gunk' that the sand in the filter isn't catching. (it can't possibly get everything). Be sure to backwash your pump frequently too.
Hope this helps at least some. Good luck!
Jul 28, 2009 | Hayward Pro Series 31 Inch In Ground Pool...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
560 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
