Question about Zebra MT2070 Barcode Scanner - P/N KT-2070-SL2078C1WW Barcode Scanner
I have just received a Morotola MT2070 barcode scanner and I am having problems as it won;'t connect to the host PC. I didn't receive any PC drivers in the packaging and have not been able to find a driver for an XP machine. I have also submitted several on-line requests but nothing. Can anyone help. Might be worth saying that this is my first exposure to scanning technology so I am a bit of a greenhorn here.
SOURCE: Z4M is printing fine white lines in the barcode
As the label comes out of the printer...it sounds like your printing in picket fence mode (vertical bars). You most likely have 1 or more pixels out on the printhead...try cleaning first...if that fails... you will have to replace the printhead.
Posted on Apr 16, 2008
  • 97 Answers
SOURCE: Gaps in barcode with Zebra S4M
By gaps, do you mean a "void" area ? Over time, the elements on the printhead will wear down and finally they won't transfer heat to the ribbon. This causes a gap or void area. Usually the elements go out one or two at a time. If the area that is worn out is supposed to be printing bars for the barcode, this will cause the scanning problem you are experiencing.
The best way to see if elements are worn out is to design a label that has a thick solid black line across the label or a solid black box. You will see white vertical lines in the areas where elements are worn out. Another method would be to use the widest and longest label you have and print a 'pause" test label. This is done by turning off the printer, pressing and holding on the PAUSE key while turning on the printer. Hold the pause key for 10-15 seconds and when the printer is done with it's power on self test, it will start printing out a test pattern label which includes a nice black area where you can look for the white vertical lines.
Hope that helps !
Posted on Apr 06, 2010
  • 257 Answers
The gaps run in the direction of the label feed? You have a bad printhead. Bad dots on the printhead prevent it from printing your format in the areas that you see the blank lines.
There is no easy fix other than replacing the printhead. You can prevent (or actually prolong the time between failures) in the future by periodically cleaning your printhead. It's recommended that you clean the printhead after every roll of labels. The printhead is underneath the hinged assembly. Over time, ribbon or adhesive from the labels builds up and causes dots to go bad - creating the blank lines you see. Clean your new printhead with rubbing alcohol.
Posted on May 17, 2010
Yogger
  • 117 Answers
SOURCE: Hello, I have the Motorola LS3478-FZ
Hello Mathew,
the USPS barcode is the GS1 128 (Code128) that will help you by activating accoring to the manual. Please be sure that you enable all lenghts of the Code128 barcode. That is probably the issue.
Posted on Sep 21, 2010
Yogger
  • 117 Answers
SOURCE: the scanner will not scan
The barcode is probably not enabled in factory settings. I would propose to use the manufacturers software called DataWedge, provided at support.symbol.com and check again. If you still have no luck try to find out which kind of barcode is it, by the producer and enable it in the settings of the software. Or better just select the option "Enable All" in the Basic configuration of DataWedge
Posted on Sep 30, 2010
Hi, I need to know how to program the DB Power barcode scanner model # BCE0008
Unfortunately, this is all I can find for instructions.
Operation Instructions:
1. Connect the USB receiver to the host (e.g.: PC)
2. Pull the trigger to start the scanner. It works on two beeps.
Notes: 1. The charging port on the scanner is for battery charging only. Do not connect it to data cables.
2. The LED light at the scanner bottom is on and red under charging and off when charging is finished.
3. During working, the scanner will auto shut down in case of not in use for 20 second.
4. The receiver was paired to the reader at factory. Do not pair again unless necessary. When self pairing is needed, please first read the code CHANNEL SETTING. (Before setting, please reset the receiver until the light turns long green. Reset it to the light off when setting is finished.
Package Including: 1 x Wireless Barcode Scanner 1 x Receiver 1 x Charging Cable 1 x Instruction
Sep 08, 2016 | DBPOWER 2.4GHz Wireless Handheld Automatic...
Scanner services is not running
What is the scanner hooked to? IF this is an error on a pc, we need to know what operating system you are using
Apr 03, 2013 | Zebra MT2070 Barcode Scanner PN...
How to reboot Motorola MT2070 Barcode Scanner
Press and hold the 2 key and the scanner trigger for 5 seconds for a warm boot, and 10 seconds for a cold boot. Be advised that a cold boot will erase all user data programmed into scanner.
Mar 13, 2012 | Motorola Computers & Internet
COM1 port is not released when scanner is used over RDP
If your scanner has a twain driver, you could install drivers on the device and use Elusiva Remote Scanner from www.Elusiva.com/products/RemoteScanner
Mar 12, 2010 | Symbol Batch Barcode Scanner P360/460...
How do i get it to connection
You have to set-up the barcode scanner in the manual. The most common mistake is not scanning the "host" option. The scanner default is "no host" It will not work until you enable the appropriate "host" option by scanning that particular barcode. Read the manual. Contact the Honeywell Help Desk (they bought Metrologic)
Nov 03, 2009 | Metrologic Instruments MS9535 VoyagerBT...
Are you able to please give me the reset instructions for a symbol scanner? model: LS4278
Hi, I would be happy to assist you in resetting your LS4278, but it would be helpful to know how you are connected. The Set Defaults barcode will reset all of the scanner settings, but it will also cause you to lose the "pair" (communications) between the scanner and cradle. If you try scanning a barcode at this point you will receive a single beep followed by four error beeps. This just means the scanner is not talking to the cradle. Scan the barcode on top of the cradle. The scanner should give a high low high low series of beeps followed by a short low short high. The short low short high indicates the scanner is talking to the cradle again and you are ready to scan.
If you are connected through the USB port and scan a barcode and get one beep, but do not see data on your host try unplugging the black power supply cable from the cradle. Try scanning your barcode again and it should show up on the host.
Jul 09, 2009 | Symbol Cobra LS1902 Handheld
I get a "Connection Rejected" error when I try to connect the scanner to a PC
This could be a number of reasons.
First check that there is no password set on the hand held device.
Go to Control Panel >> Password to delete.
You may also have to many Partnerships on the host PC. On host PC open up ActiveSync and then open File and Delete Mobile Device.
If that all fails try re-installing Activesync and the host PC.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Mar 10, 2009 | Symbol MC9090 Barcode Scanner
Scanner doesn't turn on
Hello Loverboy,
the scanner turns on automatically as he he receives power from the host interface.
Please check the cables and connection. For RS232 interface would you need an external power supply. USB can power the scanner without external power supply. By Keyboard Wedge installation please connnect also the Keyboard.
Nov 09, 2008 | Symbol LS2208 Handheld
LS2208AP
The scanner must be set to the IBM PC/AT host type. Unfortunately, these scanners are not plug and play. They do not detect the keyboard host on power up so the host type barcode must be scanned the first time it is setup. It should remember that host type until you set defaults. The IBM PC/AT host type barcode is on Adobe page 56 of 342 of the LS2208 Product Reference Guide. Print and scan this barcode. The scanner should start working immediately.
Oct 31, 2008 | Symbol LS2208-7AZK0100S Handheld
Zebra MT2070 Barcode Scanner - P/N KT-2070-SL2078C1WW Barcode Scanner Logo
82 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Gareth Cockram
Gareth Cockram
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
