Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Fridge not working
Freezer is fine but the fridge will not run. Please help
  • Anonymous Sep 28, 2008
    I HAVE A HAIER FRIDGE AND HAVING THE SAME PROBLEM,I THINK ITS THE FAN IN THE FREEZER SOMETIMES IT WORKS SOMETIMES IT DOSENT.BUT I CANT FIND A DAM FREEZER FAN NOWHERE FOR HAIER.
Error code ER FF and evaporator fan makes loud noise
Posted on Aug 26, 2008
Bottom of fridge not cold
After adjusting the settings switch or dial (usually inside fridge) you wait a couple of hours then see if bottom is colder. Most fridges (older models anyway) have an adjustment procedure. This worked for our Magic Chef purchased about 1994
Mar 03, 2013 | Kenmore Refrigerators
I have a Kelvinator Opal Fridge/Freezer. The freezer is working fine but the food compartment wont cool. It used to run too cool and freeze stuff on the top shelf. The fridge seals are fine, the fan runs...
The vent from the freezer to the fridge can be blocked with frost and is preventing the flow of cool air to the fridge.
This can happen if there is frost build up due to failure of the auto defrost timer.
So please check on the fan section , remove panel and see if there is frost or block, if so check the timer Heater and the thermostat.
Jan 24, 2011 | Refrigerators
I own a amana fridge fridge on top freezer on bottom . all of a sudden my fridge stopped cooling the freezer still works fine I hear fans running but no cool air at all. please help me
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 16, 2010 | Amana Refrigerators
We have a lg gr-s592gt and we noticed the frezer is working fine but the fridge wasnt cold. i noticed that the two fans that controller the temp in the fridge arnt working but everything seems fine , this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Ice build up and stops the fans...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 11, 2010 | Refrigerators
EL7ATRR Refrigerator: Freezer working fine but fridge not cooling...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 17, 2010 | Whirlpool EL7ATRR Refrigerator
Whirlpool Fridge Freezer not working fridge is
ID THERE FROST BUILDING UP IN THE FREEZER?IKE
Mar 14, 2009 | Whirlpool ET4WSKXS Top Freezer...
Frgidaire side by side fridge not cold freezer is good
Fan needs to be replaced. Common issue and easily done. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Frigidaire FRS26ZSG
Freezer not working but fridge is
tratra72
You said,
I opened my freezer today and everything was defrosting. The fridge is working fine. I thought maybe did not shut properly so made sure it was closed and 8 hours later it is still not freezing. The fan is working but the air is refrigerator. HELP!!!
1.Try unplugging the fridge for 5 minutes and then restarting it! This may reset the system!
2.If the freezer is so full that the rear vents are blocked then this may happen. Because the fridge and the freezer share the air!
3. If not then the freezer and the fridge have different controls and the freezer control if faulty!
then you need service. ur site has good service companies in your are for our customers!
Bless You,
please give me a good rating before you sign off!
thank you
Sep 14, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
204 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
