Question about Garden
I bought a slightly used weed eater XT200. I am looking for the manual.
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
Your manual can be found here:
http://www.hammerwall.com/Manuals/WeedEater/Description/XT%20200/WeedEater/L0401139/
Click on Manual Location to download the manual and should bring up this link:
. http://www.hammerwall.com/Download_Manual/10449/
enter the 4 char Captcha and download the manual.
Thanks for choosing FixYa,
Kelly
Posted on May 24, 2011
Where can I get a replacement for a murray weed eater that is still under warranty, I have only had it since the end of March 2016
with your receipt go back to where bought and depending or their policies ask for exchange or refund but more than likely will need to notify manufacturer for refund /exchange since over 30 days look at owner manual and warranty paperwork they have info on their policies and who to contact
Jul 24, 2016 | Garden
Can't find owners manual for the following weed eater model numbers xt-200, xt-260 and poulan model # p35oo
XT200: http://www.weedeater.com/ddoc/WEEO/WEEO2004_USen/WEEO2004_USen__530163333.pdf
XT260: http://www.weedeater.com/ddoc/WEEO/WEEO2010_USen/WEEO2010_USen__545186831.pdf
P3500: http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2007/NOUS2007_545154718.pdf
Sep 06, 2011 | Garden
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Where or how can I get an owner's manual for the Weed Eater Model 115?
They can be found online. I used to know the address but don't have it any longer. Just keep looking, I know it is there...Lee
May 28, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Jul 30, 2009 | Garden
Tryingto replace my troy built weed eater's head
Replacement head can be purchased from amazon, here Amazon com troy built head. I hope this helped you. Have a nice day. Vince
Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Garden Logo
351 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
