Question about Cameras
Im trying to playback on tv when i conect leads to tv picture is black and white not colour any sugessttions
    Guru:
  • 1,705 Answers
1) Check that the pictures are in colour and not black and white.
2) Make sure the cable is fully home both in your camera and the tv socket.
Posted on May 24, 2011
Wii connect to samsung smart tv series 8
This is due to incompatibility of color system,i.e., using PAL for Secam etc. Always connect yellow RC jack to yellow RC socket.
Jul 30, 2012 | Televison & Video
EasyCap - ''no input signal or signal is unclear'' Please Help!!!
In the ULead VideoStudio Application. Go to "Capture" tabbed panel. Select "Options" then "Video and Audio Capture Property Settings...". A window should pop up.
In the "Source" tabbed panel. Change the "Input Source" drop down menu to either "Video Composite" or "Video S-Video" depending on whether you are using the yellow or S-Video picture lead.
Change the "TV System" combo-box to PAL for colour and NTSC for black and white. On my computer S-Video option is showing black and white when using my Sky HD box, don't know why this is yet.
Try the above and you should get a picture. You can also change the frame rate and other compression techniques etc.
If it still doesn't work try changing your digital/sky/vcr/xbox picture settings to PAL for colour or others for picture preference.
Hope this helps.
Goodluck
OAC
Mar 06, 2010 | Ulead Videostudio 8 for PC
Nintendo 64.black and white picture
In order to play a different region game on a different region TV (example playing a PAL game on a NTSC tv) your tv needs to be automatic enabled. Some tv's have an option on the remote to change the input signal to PAL NTSC or SECAM. If your tv does not have that then there is literally nothing you can do apart from get a different tv with this feature.
Dec 25, 2008 | Nintendo 64 Console
Playstation2 conection to 26
i assume your using either a yellow/white/red or yellow/green/blue/white/red rca lead to plug in to your telly, make sure they are all going to the same input ie, input 1 or input 2 and the correct colours
Sep 02, 2008 | Televison & Video
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Black & white picture on vcr & dvd playback
Check your VCR or DVD for correct region and standard. If I had a camcorder, VCR, or DVD player here in America on Pal standard or eupopean region the same thing would happen.In fact I accedently did that on an unknown switch on the camcorder.
Dec 04, 2007 | Televison & Video
JVC dvl 9700 playback on tv is black & white
You can get the sound to play by hooking up an additional cord to the audio jacks - the same as you would do if you didn't use the s-video. I am still working on the b & w issue
Nov 27, 2007 | Video Cameras
My genisis has no picture!
the leads probably need replacing as these often split inside are you sure the your selecting the right setting on the tv are you using the colour leads red and white or is it scart lead ...............
Nov 19, 2007 | Sega Genesis 2 Console
RCA tv only in black and white?
The route through the circuits in the TV from the various sources all lead to the final video amplifiers for red green and blue. Somewhere along the route is a circuit called a colour switch. This allows colour if the signal is strong enough, otherwise it only allows black and white. This fault suggests a weak video chip which is the one just before the switch circuit. the fault could also be a faulty coupling capacitor to or from this chip, or a low power supply voltage. Check for dry soldered joints around this circiut. Please note if resoldering on new televisions that they may have non leaded solder which requires about 50 degrees centigrade hotter iron.
Oct 15, 2006 | RCA F27628 27" TV
Cameras Logo
53 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
