Question about Honda 3000 Watt Portable Generator
I have a Honda eu30is that won't start by electric ignition. It gradually became harder to start and eventually nothing. I thought it may have been the battery. after installing a new battery. still no luck. It does start perfectly via rip cord. Any thoughts?
  • 148 Answers
SOURCE: electric start dont work
You probably have a bad switch
First look to se if there are any fuses
also see if horn works
FIX for determining if starter works
to find out take jumper cables and put the red cable on the plus side of the battery and the black on the minus side of battery(ground)
Put the black lead(ground ) on the frame of the bike near starter and touch the red to the starter lead( you may have to peel back rubber boot over starter nut
when you touch the starter nut it will spark and should spin over
if it does then you need to remove the screw assembly that holds the starter button and remove and clean it out with electronic cleaner (you may have to replace it if so go to honda shop and order new one
Good luck
Posted on Jan 07, 2009
SOURCE: I am looking for a servivce manual download for a
hi look for 4100 makita genertor manual
Posted on Mar 08, 2009
SOURCE: bke wont start
Hi there, try this sometimes the stand switch can make the bike not work if has got rusted at the back.and check or replace the coil., then check if you are getting a spark from the plug by putting the spark plug on top of the head. The next thing is if the bike turns over but not fire up, you need to strip down carb and clean jets, also check petrol value under the tank If you have a book it will go through this step by step. good luck.
Posted on Mar 20, 2009
  • 152 Answers
SOURCE: need a battery for honda eu3000is
No, you don't a factory ordered battery.
Yes you can use an after market battery as long as it is of the proper voltage (6vdc or 12vdc) for that system, and it has the proper dimensions (overall size) so as to fit in to the battery tray.
If possible take the generator with you to easily check your new battery's fit, while at the store.
Aduz
Posted on Mar 29, 2009
  • 490 Answers
SOURCE: WON'T START..NEW BATTERY ..DEALER CANNOT DIAGNOSE
remove the sparkplugs and clean the heads with a wire brush and test to see if the gap is rite
Posted on May 08, 2009
Honda foreman 2000 450 won't start but fires sometimes with electric start when letting off button but does nothing with the pull start.help
Hi, Christina and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
6. Faulty ignition coil or ignition / electronic module
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
honda trx450 foreman service and repair manual pdf
Honda foreman won start
http://www.hondaforeman.com/128-foreman-450/78283-foreman-won-t-start.html
Honda Foreman 450 wont start Help
Apr 17, 2016 | Honda Motorcycles
My 2007 Honda TRX500FE electric shift became harder and harder to get a clean shift over time, and then stopped completely. I am getting 5 flashes and a pause regardless f what gear I'm in. Changed...
The 5 flashes sounds like a fault code. This unit is a four wheeler, true? Might try posting in the correct section or perhaps call a dealer and beg code interpretation.
Mar 08, 2015 | Honda Cars & Trucks
1984 Honda shadow 500 won't start.
Hi, Anonymous before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1984 Honda Shadow VT500 Won start
What Do Check When My Motorcycle Won Start Honda Shadow Forums Shadow...
http://www.cycleterminal.com/Service-Manuals/Honda-VT500C-Shadow-Service-Manual-English.pdf
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-vt-owners-manuals
Apr 21, 2013 | 1984 Honda VT 500 C Shadow
Ignition problems. Sometimes the car will start and sometimes it won't even try. I thought maybe holding the gear shifter up will help and sometimes putting it in neutral will work when nothing e
From what you describe it sounds like the shift linkage needs adjustment.Was any work done on the transmission,or did you bottom out recently? I don't think it's electrical.Also don't keep a lot of keys on your ignition key ring this can wear the key slot and also cause the erratic starts.Good luck.
Mar 13, 2013 | 1995 Oldsmobile 88
Honda Accord keeps blowing fuse and won't start
Recently we had to put a new fuse in the starter ???????????? What fuse ? location , size . A fuse blowing means a electrical short to ground .
May 29, 2017 | 1998 Honda Accord
Troubleshooting moto guzzi stone
Just a thought as you asked...sounds like a poor throttle position potentiometer ... throttle cabled to butterfly most likely and if ECU dosen't know throttle plate moved you will see this symptom . If electric throttle , can you see(hear) plate moving whilst twisting , if so measure resistance/voltage on pot. . I do not know if resistance of position sensor can be measured while twisting throttle or pushing plate (bike off , battery disconnected or ignition off)
Luck
Hugh
Mar 10, 2017 | 2000 Moto Guzzi California Jackal
My lights, windows, and radio all work fine. But it won't start it makes a click noise but nothing. Then we thought it was the battery so we jumped it and now it won't even make no click noise at...
The "click" sound condition make us guess that could be a bad ignition switch or starter.
It turned out to be the starter. I first took the battery to have it tested and it was fine. Next, I took the starter apart and took it to Autozone to have it tested? and it was bad. It is not easy access to remove the starter. The intake manifold and exhaust system are in the way and need to be taken apart first. See instructions below:
- Take off Intake
- Take off Starter
Hope this helps (remember to rating this answer and leave some comment).
Sep 28, 2011 | 2003 Honda Element
I have a 1995 Honda cbr 600 f3 it won't start won't try an start the battery is fine so are the fuses I'm getting nothing no lights not even the ones that show your in neutral. It's really...
ORDER A CLYMER MANUAL FOR YOUR BIKE!!! Everything is easier to inspect with the fairings and accessory covers removed. While you are waiting for the manual, trickle charge your battery. Make sure your charger is a maintainer as well. It charges your battery and keeps it conditioned. Keep in mind, even if it's a new battery, they are not impervious to fault. When you get your manual, two or three days later, the battery should have a full charge as indicated by a green light(normally) on the trickle charger. Now, key your ignition on and get your multimeter. Read for battery voltage on the down side of your ignition switch.Then measure and note the draw from your battery as you hit the start switch. Open your manual and start reading through components like your rectifier, coils, main power fuse (probably a 30A)on your fuse box. Remember, a bad ground within your electrical system will report a failure to allow passable current to the components that need the juice. Look for corrosion or gunk on the contacts of your electrical components. Good luck, let me know how it works out.
Aug 20, 2011 | Honda CBR 600 F(3)S Motorcycles
I have a 1978 Honda 750F motorcycle that is electrically dead.
take your battery and have it tested. just because you have voltage dosnt mean its there under a load
Sep 06, 2009 | Honda CB 750 Motorcycles
Honda 3000 Watt  Portable Generator Logo
230 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
