Question about Microsoft LifeCam VX-1000 Webcam
I bouth 1 yesterday and when i ploged it in the usb slot it couldnt instal
The light on the hardrive is blinking faster than normal and i couldnt connect to my laptop, it was working fine 2 mins before, i think its because i forgot to safety remove before i plug out.
This kind of behavior of a Portable Hard Disc, may be due to some reasons :-
Most probable cause is the Virus / Malware in the PC or Laptop.
Second cause is USB slot of PC or Laptop is corrupt or not properly installed.
The last cause is the Data Cable is not right.
Mar 12, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
Can a Windows 95 have a usb port installed
Yes.
Load the required driver from Microsoft but it will not be USB 2 only USB 1.
Oct 16, 2010 | Computers & Internet
MY MOBILE SOFTWARE CD(NOKIA 5233)ARE NOT DETECTED BY SYSTEM .WAT IS THE PROBLEM???
first become sure from cable.then go to setting of nokia pc suite & try to select the correct port(USB & COM 1 & COM 2 or etc...)
then go to control pannel & new hardware installation & scan .if it could find your phone,can install drivers too.if u couldnt succes,try to reinstal pc suite but BE CAREFUL,DONT CONNECT your phon durin installation...after compeleting installation connect the phone,it must find it automatically...&finally if u couldnt success to solving this problem,try to install the final version of nokia pc suite from its site...
(scan your pc by an update antivirus)
good luck
Aug 14, 2010 | Nokia 5200 Cellular Phone
Memory problem
hi, are the sticks all the same type? make sure they are seated well, had same problem on my msi board, i seated them and moved them side to side carefuly. and it saw the sticks not detected before. also if they are not the same specs, there may be a compatability problem, most ram is backward compatable, but if not the same specs could be a problem. in my case the slots were worn from too many upgrades,and seating them properly worked. hope this helps you, happy new year!
Jan 01, 2009 | VIA MSI K8T Neo2-F K8T800 Pro Socket 939...
USB 2 PCI card installation on IBM NetVista with MS Vista
Lucy,
USB 2.0 cards require 2 IRQs.
  • 1 IRQ supports USB 1.1
  • and the other the Enhanced (USB 2.0) controller.
Installing the USB 2.0 card in a slot that does NOT share an IRQ or shares an IRQ with onboard USB produces the best result. Consult your motherboard manual or online guide to determine which PCI slot is best for you.
You should also try disabling the on board USB support from BIOS setup.
Thanks
Iqbal
Apr 28, 2008 | IBM NetVista A40 PC Desktop
How do you remove song from your mp3 4gb sansa sandisk
1. Either your MP3 playr is write protected .
2. there is some problem in firmware .. lode firmware thru cd ..
Jan 15, 2008 | SanDisk Sansa e260 MP3 Player
Ad d memory to an HPpavilion ze 4900
From the research that I've done of the ze4900 the maximum is 1GB but I also read that some can go up to 2GB, I need the HP part number of your laptop to know for sure, it's a 7 or 8 digit string that starts with a P then another letter, 3 numbers, then two more letters. You can find it on a label under the system with the serial number. Thanks.
Jan 14, 2008 | Computers & Internet
Microsoft LifeCam VX-1000 Webcam Logo
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
