Question about Gigabyte GA-945GCMX-S2 Motherboard
Lan card problem - Gigabyte GA-945GCMX-S2 Motherboard
  • khaled hussien May 24, 2011
    is the indicator light on your card is turned on ? when the lan cable is inserted?
  • Gigabyte Master
  • 32,281 Answers
You can download the LAN and device drivers from Gigabyte WEBsupport site, select your model motherboard to download :- http://www.gigabyte.com/support-downloads/support-downloads.aspx
Posted on May 24, 2011
One of Intel DP55kg Motherboard desktop shows 100 mbps Lan connection when the other desktop shows 1gbps. why?
It depends upon the make and model of the LAN card. The one in the Intel may be a 10/100Mbps LAN card and the other one a 1Gbps LAN card.
You cannot make a 10/100Mbps LAN card run any faster than it was designed for.
May 11, 2011 | Intel DP55WG Motherboard
Uninstalled lan drivers
u can remove your lan card drive from add remove option in control panal
if u have lan card problem open your cpu diconnect lan card and clear its golden connector and clean pci slot which in on mother board then again plug it and reinstall lan drivers if problem not fix try with replace new lan card 100 percent it will help u
Feb 04, 2011 | Computers & Internet
I m unable to find lan drivers. i've a lan card
You use built in Lan Card or Lan Card which is in PCI slot.
1st you know the name of the Lan Card. But You can download different type Lan Card Drivers. Lan Card Drivers
Mar 15, 2010 | Computers & Internet
Lan card send reciving problem solutions
The lan card send receive problem occurs only due to following reasons
1.The network cable connection not having good connectivity
2.Due to physical damage of lan card due to power and etc
3.Due to improper fixing of lan card in case where lan card is not inbuild
solutions
you can check which is the problem
if the lan card is damanged means replace with external card
Feb 13, 2010 | Computers & Internet
I have canon ir3300 errorcode is E000740-0003
E740
0001 At power-on, the LAN card has a fault.
0002 The MAC address has a fault.
0003 The LAN card cannot be read.
Main cause The LAN card is faulty. The main controller PCB is faulty.
Action
1. Connector
Is the connection between the LAN card and the main controller PCB normal?
NO: Correct the connection.
2. LAN card, Main controller PCB
Try replacing the LAN card. Is the problem corrected?
YES: End.
NO: Replace the main controller PCB.
Jan 12, 2010 | Canon Office Equipment & Supplies
The internet providers technical person connected the cable and told me that your lan card is faulty so change it. my lan card is inbuilt on motherboard
Unplug your power cable; Take off your casing cover; make sure your hand is dry and clean, install your LAN Card to the right slot (Please refer to your Network Card Manual Book); Power On your PC, Press Delete at boot screen until u login the bios screen, go to the Advanced Tab on the top there, Select [Disable] for Onboard Lan; Then save & exit. You're done well! Congrat!
Dec 01, 2009 | ASUS M2A-VM Motherboard
My dell lan card is not working,i cannot connect to internet.
Either the LAN card is faulty or the LAN driver is not installed and/or not configured properly or the LAN cable is faulty.
Check Device Manager to see if the LAN driver is installed, working and enabled. If not then re-install the LAN card driver.
If the LAN driver won't install or detect the LAN card then it maybe faulty and needs to be replaced.
Try a different LAN cable.
Is all the LEDs on in the modem?
Try rebooting the modem (power it off for 30 secs and power it up again).
Nov 14, 2009 | Dell Ethernet Card Network Adapter
INTEX LAN Card 8139D RTL problem
you need to download the driver for your lan card. If the LAN card came with your computer, go to the computer manufacturer website to get the driver
Jul 04, 2009 | Computers & Internet
Hello sir, my system has been conducted a problem. lan card is disable so . i donot know how to enable lan card please give me a solution. thanking you
if the lan card is disabled then you have to reseat the lan card if that is a external lan card connected & not the integrated one..also check for the network adapters if they are installed under device manager or not...in case not you also have to install network adapters...
Apr 29, 2009 | Computers & Internet
How to unactivate lan card p5gc-mx by jumper
I would see if you can disable the LAN card in the BIOS, as the LAN card your speaking of is part of the motherboard and not a removable part. I have disabled these before VIA the BIOS and then installed a third party LAN card in an available slot on the PC.
Jan 17, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Gigabyte GA-945GCMX-S2 Motherboard Logo
126 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
