Question about Behringer Um300 Heavy Metal Distortion Effects Pedal
I havn't used my UM300 in only two days, last time it was working pretty well ... better than ever, today morning i woke up and tried to use it, but all im getting from the amp is a buzz in a very low volume ... i checked all my cables and the amp without the pedal, all worked perfect ... but the pedal doesn't seem to be operating :s
  • Behringer Master
  • 5,603 Answers
Dead battery or disconnected power adapter. Leaving cables connected discharges battery in a day as this is what switches the battery on. (The input cable)
Posted on May 24, 2011
My behringer um300 pedal won't turn on when pressed. the sound goes through, but any slight movement makes a loud, scratchy sound.
It's probably the activate button. Maybe it is stucked, but more probably that is damaged so when you tap it with your feet, it's making these sounds...
If you don't have any or very small experience in electronics, then take it to the electronics service center for electronics engineers to look it up,
Cheers!
Sep 05, 2016 | Behringer UM300 Ultra Metal Distortion...
LED Light not coming on
Did you get it used or brand new?
M-Audio is notorious for hardware related problems, mainly the USB ports. After awhile the ports wear and fail to hold the tight connection needed to keep the board fully functional. But I've seen the same problem with new boards too because of bad soldering.
If it's new then don't bother wasting time trying to figure it out. Just exchange it and save yourself the headaches. You may even want to look another board. If your partial to M-Audio then the Axiom is much better than the Oxygen. Either way, take advantage of the ability to exchange while you can, cause once that's over M-Audio will give you the finger.
Jun 23, 2017 | M-Audio Oxygen 49 USB Midi Controller
Can the material used for aircraft tires be used for regular car tires?
The materials are in fact pretty much the same, but it is the design that is different, you can try having a closer look during your next car tyre fit. As others have explained, airplane tires would not work well on autos and they would be much more expensive than what you can buy now. Auto tires are engineered and constructed very well and the quality has improved dramatically over the years. In the 1970's, top-of-the-line Michelin tires were good for 40,000 miles with a top speed rating of 100mph and they cost about $100 each. Today, the best passenger tires can go 80,000 miles at speeds up to 130mph and they cost about $150 each. Adjusting for inflation, they are cheaper today than 30 years ago, and they are far better tires.
Dec 11, 2012 | Yamaha Tyros4 61-Key Arranger Workstation...
My Casio Privia PX-330BK Keyboard won't turn on.
Try checking your power cord. Perhaps someone stepped on it and it pulled out. It happened to me once. I thought something was terribly wrong with it. I was pretty embarrassed to find out that I'd just cut off power via cable... check your cords before worrying too much. If nothing seems to be wrong, take it in to the repair shop.
Sep 12, 2012 | Casio Privia Px330 Px-330 88 Key Digital...
I seem to always get a static sound out of my Line 6 Spider Iii below 9 o'clock on the volume knob. Not only is it staticy, but the volume jumps all around and goes from whisper quite 1 second to house...
It sounds like you have a dirty pot (the volume control). Unfortunately the only way to clean the pot is to open the amp up and try to spray some Servisol Super 10 in through the small opening in the pot case.
WARNING: Tube amps contain lethal voltages even when unplugged! If you are not an experienced service engineer then take it to someone who is! It is a pretty common task in guitar amps so shouldn't cost too much.
Sep 10, 2011 | Line 6 Bogner Spider Iii Valve Tube Combo...
I own a Yamaha YPT-220 portable keyboard. The "c", "b" and "f" keys (all octaves) just stopped producing a sound. Anyone else have this problem?\r\n The dealer's service...
That's the thing with today's electronic and why warranty length is so important. Where did you buy your keyboard? It's strange that they won't fix it if it's still under warranty. My Casio CTK-2100 came with 1 year free service and they fix one key that stopped function in few days. I'm pretty sure Yamaha has the same warranty length. You sometimes have to be very persistent with them though...
Jul 18, 2011 | Yamaha Full-Size Keyboard
I used my Behringer 802 mixer for the first time lastnight and when i woke up this morning and tried to record,the sound was very distant and hardly audible.I tried to raise the volume by turning the main...
What are you recording from? If using a condenser mic and you fail to turn on the Phantom power, symptoms such as you describe would occur. You don't include enough information about your setup to allow us to help.
Jun 27, 2011 | Behringer XENYX 1002B Mixer
This morning during a church performance, 1/2 of our display went out on my PSR-S500. Is this a user-replacable part? I'm pretty handy with a meter and not afraid to crack the case. This item is not...
It is shop replaceable. I have heard this is NOT an uncommon problem. You can get the parts through Yamaha America in California. Here is your service manual:
http://elektrotanya.com/yamaha_psr-s500.pdf/download.html
Scroll down to "Get Manual" and click on it to download the manual (about 12Mb)
Yamaha support/parts contact
http://usa.yamaha.com/support/
May 15, 2011 | Yamaha PSR-S500 Digital Keyboard
Behringer Um300 Heavy Metal Distortion Effects Pedal Logo
79 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
