Question about Nokia N72 Cellular Phone
Call log not show and phone number not save - Nokia N72 Cellular Phone
    Sergeant:
  • 145 Answers
Read carefully catelogue book thoroughly for operations
Posted on May 24, 2011
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
Nokia e 52 does not save log
Try deleting files from phone memory......goodluck
Jun 01, 2012 | Nokia E52 Smartphone
Hi, I have background data and autosync both ticked in my phone's general sync settings so I can receive emails from my gmail account, but it has also autosynced my contacts so that now I only have...
This is happening not because of Gmail contacts sync. This happens due to setting in Contacts application which is not showing phone contacts.
To solve this problem, 1. Open Contacts from Menu 2. Press Menu button (first button on phone), select "view" 3. You will see option to view phone contacts, gmail contacts,Facebook contacts (if you have setup Facebook) etc. 3. Check "Phone " and you will see phone numbers also in contacts.
TIP: You can check " Only show contacts with phone number" to hide email only contacts.
Reply in case of any problem.
Jun 15, 2011 | Samsung Galaxy S GTI9000 Smartphone
I want to block unwanted callers from calling me . i am unable to block these callers
to block a particular mobile number, if the contact is saved in your phonebook, do these.
1. press menu,
2. select settings
3. select application settings
4. select call
5. select all calls
6. select auto reject
7. scroll down and select reject list and add number.
8. select search and it will give an option
9. select from two options, call log and phonebook
10 select phonebook (this is because the numbers were saved in your phonebook)
11, once set and configured, check and enable auto activation
12. click save and exit the settings.
if the contacts is not on your phonebook.
follow the steps 1-9 but step 10 will be your call log not the phone book.
10. select call log
11. it will give you the phone numbers of all the person who contacted you, including those who sent you a message,
12. at the right upper corner you will see all, filter it through received message and it will give you those who sent you messages.
13. select from the contacts or numbers from the list.
14, select and enable auto activation
15, select save and exit the menu
Apr 11, 2011 | Samsung Star GT-S5233 Cell Phone
Message problems
This is a pretty common issue: the number that you are receiving is different from the one you have programmed in your handset: just look at the called received log and change the number in your address book to 'exactly' what you see (you can of course re-saved this number from your log context menu options). The usual issue is with receiving a 'non-local' number with a Country and Area Code or a 'local' number which also append Country/Area code in the call-id.
Hope it helps and let me know how you go.
Jan 26, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
It won't save in comming phone numbers
Please follow the steps.
1) Go to call logs.
2) Press menu key.
3) Select Options.
4) Select call logging.
make it to None.
If still it is not working follow the other steps given below.
1) Go to Options.
2) Select Status. 3) Select file free. See wheather you have enough files available in your Handheld if there is no space available than you wont be able to save the call logs..I hope I was able to help you.
Thank you for using Fixya.
Oct 22, 2009 | RIM BlackBerry Pearl 8100
Same problem with unlocked atnt blackberry bold
If you saved the phone number to your contacts list from your call log, it will automatically save with a '+' in front of the number. For example, I call you, you don't know my number, but after we talk, you save my number to your contacts list from your "received calls". This is the only time I have ever had it save this way. I go in and Edit the contact's phone number to delete the '+'. Hope this works for you like it did for me!
Jun 28, 2009 | RIM BlackBerry Bold Smartphone
Hy is my blackberry pearl not showing who my message is from
Cause:
  • Number is not saved in the address book
  • Issue with the setting in the handset
  • Software issue
Resolution:
  • If the name is not saved then saved the name in the handset
  • In the handset go to Call logs -> Menu -> Option -> Smart Dialing -> Country Code is +91 and Option ->Security Option -> General Settings -> Include Address Book -> Yes
  • If the above two option is done then re-install the software.
Jun 18, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Listing contacts
to list a contact the easy way just type the number it and press options and it will display save go from there
if some one called and u missed it when the screen shows one missed call it should show the number if not it was private u can also go in to call log and go to dialled calls.recived calls.and missed calls and will show u the numbers
Jun 28, 2008 | Nokia 6288 Cellular Phone
"Memory Low, Delete Some Data"
You might want to try a "Hard-Reset" To do this you turn of your phone, press and hold "Answer Call(Green)"+"3"+"*" and then turn it on. This should reset your phone completely and clear the memory. CAUTION, back up all your vital data before you do this, it clears EVERYTHING.
Dec 27, 2006 | Nokia 6682 Handheld
Nokia N72 Cellular Phone Logo
46 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
