CPU over temperature error.solve it please - Computers & Internet
    Master:
  • 328 Answers
Calm down
the CPU fan and heat sink are collecting a huge amount of dust the fan my looks it is turning but slower than normal
the heat sink is that metal fined bulk that have the fan at the top of it when the dust is filling the gapes between fins and under the cooling fan
it is easy to clean just unplug the CPU fan clean the duty heat sink first in it`s place dont remove it make sure all fins are clean so the air could flow and cool the things up
the fan in your hand remove the backside sticker you will find a small white plastic ring that hold the end of fan`s axial with small knife tip remove the ring then take of the blades of fan away clean them will with a small tissue clean the inner part of fan coils and so then bring a very littil mount of any thick cream hand cream or vasilien jelly lubricate the axial reassemblies you have a fan better than the new one and makes no any sounds
Posted on May 24, 2011
    Guru:
  • 868 Answers
Hi web0105,
I see that you CPU is having issue overheating.
If I may ask have tried cleaning the heatsink and putting additional thermal paste between the heatsink and the processor?
this is the only thing that can prevent overheating on your CPU.
I hope this helps.
mvincentc
Dear sir, my motherboard is amd athlon 64 socket 939.when i on the system then system is running but processor fan is not rotating.Finally after 25-30 minutes it automatically turned of and displays cpu...
It sounds like the cpu's temperature is raising over the safety level set in the bios so it switches off and displays the error!
to solve this either:
Your cpu cooler fan needs replacing
or
Your current cooler fan isn't connected to the correct socket on your board (check you're user manual, usually a .pdf you can download from manufacturers site)
or
Just try connecting your current cooler fan to the cpu and see if it turns on at all. If not make sure you replace it with one that is compatible with your system that can fit in your case
If the temperature has raised to a significant level the thermal paste could probably use replacing also, so get some thermal paste remover and thermal paste, and read in your motherboard user manual how to replace the cpu heat sink safely.
Sep 26, 2013 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Error code for AMI
If the CPU temperature isn't too hot then just go into the Bios and disable the CPU temperature monitor option.
Aug 19, 2012 | Computers & Internet
Processor thermal treat error while booting
Make sure that cpu fans are running normally. Go to BIOS (generally with F2 on intel motherboards), and there will be information about cpu temperature, also fan speed (in RPM). If fan speed is 0 or very low problem is in cpu fan. (connection problem might be). If cpu fan speed is normal (high value) and cpu temperature is high, I will suggest you to open your PC case (or notebook) and see whether cpu fan is dirty or not. This is very common problem. If so, clean it.
May 09, 2012 | Intel Computers & Internet
It goes off automatically
Enter bios and check your CPU temperature, maybe it gets hot (optimal CPU temperature depends on CPU type, but usually it? not normal if it? above 65 *C) and because of that shutdown occurs. If the CPU temperature is high, apply heating paste between CPU and heatsink. Usually if the PSU is defective, the system restarts, shutdown occurs rarely.
If this is the solution for your problem, please rate my post, otherwise give us more details aboutyour problem.
Regards,
Andras
Sep 13, 2010 | EliteGroup 741GX-M Motherboard
What cause error code 511 cpu fan not detected
3 wire conductor fan. The 3RD WIRE IS THE fan sensor located in the fan's electronics this is malfinctioning come in tthe construction of the fan itself.
Aug 23, 2010 | HP Compaq d530 SFF PC Desktop
Mother Board problem
use bios CD update bios on the mother board.ok
after that cpu fan...refix the cpu fan after cline,
apply the paste on the Proccessor.it working fine
Mar 16, 2010 | ASUS P5GC-MX/1333 Motherboard
Just turns its self off with out any warning
How mush time stays the laptop in on state? Check the airflow ports (incoming and outgoing) and clean with a small brush and a vacuum is case of dust. Try again and report the results with a post.
Thanks and regards
Please kindly rate this solution
Stelios
Feb 27, 2010 | Acer Aspire 5500 5570-2609 Laptop
I'M TRYING TO SEARCH IN THE WEB BUT I CAN'T GET
Normally Checksum errors mean that the Battery on the board may not be holding a charge any longer. Best suggestion that I can give is to replace that battery. You can buy it in any electronics store. Just make sure to buy one with the EXACT same size. If that still does not work you may ahve to update your BIOS you can message me about that.
Sep 02, 2008 | Computers & Internet
Intel 845gvsr shutdown problem.
pls change the mother board capacitor of 820uf 6.3 v
Aug 13, 2006 | Enlight 17IN LCD PC SILVER/CHARCOAL W/...
Computers & Internet Logo
169 people viewed this question
David Payne
David Payne
