Question about Panasonic Toaster Ovens
Meaning of ES indication in prestige induction stove
What setting should i use to cook food in the oven,
pick one and go,you see,we dont know what stove you are talking about or what settings because you failed to tell us these things in both questions
Apr 23, 2015 | Better Toaster Ovens
The oven turns on and works fine but I'm unable to turn it off. i have to go flip the breaker to turn it off. The clock does not appear to be right up against the screen, at times temp/clock fades in and...
If your unit is already old enough, I think it will need to replace many parts. So it is worth buying a new one than to repair it because many parts will be replaced soon. I hope I give you some idea.
Mar 21, 2011 | Magic Chef Toaster Ovens
I just moved in my condo with a magic chef gas stove/oven without a manual. I tried to use the broiler but I can't seem to make it start after pressing the button "broil". It is about 10 or 11...
Hello Bocsabh,
The model number will either be inside the door of the oven on the face usually and/or is located at the rear/back of the item. There should me a model and serial number listed on the plate. Once this information is found it will be alot esier to help you with your current problem.
Please post back to this thread and I will be glad to help you.
Thank you for chosing FixYa.com
Justin
Mar 09, 2011 | Magic Chef Toaster Ovens
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    How to set the clock on Nardi built-in stove (model FE46?) Thanks.
    There are 6 push buttons, the two on the right have a plus and a minus sign on them. Just use these to set the clock.
    May 11, 2010 | Toaster Ovens
    Need old West Bend Serving Oven -bun warmer- directions
    I have one of those that I got as a wedding gift from my parents in 1975. They were popular then. My mother had always come out with nicely warmed buns, but when my wife and I tried to use ours, our buns were soggy--from too much water, I guess.You have to use it on top of the stove, not in the oven. Try putting in about a half-inch of water and put in the middle piece. If it floats, then you have too much water. Put the buns inside, place the lid on, and put it on low heat for 2-3 minutes. You can regulate how soft or crisp the bun would be by opening the steam vent for more crispy bread, or closing it for it to be more moist. You can experiment with it, but yes, you DO need to use it on TOP of the stove.~ Barry
    Apr 23, 2010 | Toaster Ovens
    Wolf 4 burner stove developed a non stop ignitor clicking
    If you have Wolf model AS30KI, most cases the top burners are misaligned or one of the electrode is bad.
    Aug 31, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
    Igniter on Wolf Stove clicks continuosly
    Depends what Wolf model you have, if you have model AS48KI and the flame looks really high, (it supposed look like a flower), most cases the top burners are misaligned, you can try to re align the burners by turning them around. afterward if the burners are still clicking it may be ignition problem. Have fun.
    Aug 14, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
    Non stop ignitor clicking
    The thermostat tells the ignitor what to do. So, I believe the problem should be takrn up with the heat foreman
    Jul 29, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
    Toater over Broiler Cuisinart
    traducción electrónica
    Usted puede tratar de limpiar los contactos con alcohol (y/o papel muy fino de arena) como indicado en otras discusiones, pero el fijar es una solución cercano del término y finalmente los contactos hacen el arco y el hoyo otra vez. Esto lleva a temperaturas más altas a través de los contactos y si los contactos fallan antes la leva plástica se funde, su libre para dirigir los contactos para limpiar otra vez. Recuerde justo que este fracaso ocurrirá más con frecuencia cada vez. Una vez que la leva falla (se funde) su fuera de suerte. Escriba Cuisinart y dígalos cuán infeliz usted está con su horno de tostador. Si usted consigue la misma respuesta que hice (nosotros sólo lo reemplazaremos bajo garantía) entonces se siente libre reciclarlo (o tirar) y gastarlo su dinero en un delonghi (no afiliación - la mano mí hacia abajo 7 año viejo uno mantiene trabajando gran) u otra marca. Las compañías en que estos días deben tener mejor control de calidad en los productos (de China) ellos abofetean su nombre.
    Para el registro, mío que TOB030 tiene acerca de 10 Horas corre tiempo en ello antes falló @ 1.5yrs viejo. ¡El interior es todavía marca que zurra nuevo!
    Justo mis 2 centavos.
    Jan 22, 2008 | Cuisinart TOB-30 Classic 1500 Watts...
    Toaster Ovens Logo
    70 people viewed this question
    Top Panasonic Toaster Ovens Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Dave
    Dave
    Are you a Panasonic Toaster Oven Expert? Answer questions, earn points and help others
