Question about Blackhawk Night Ops Xiphos Nt Weapon Mounted Light, Black
Using my trigger finger to activate light, it sometimes won't come on or it comes on but after pressing switch a second time it doesn't turn off. Or I press the switch and it goes straight to strobe. Basically I never know what's going to happen when I activate the light. I was given the xiphos for SWAT and used it for three months and this issue came about. I was given a replacement Xiphos and it started the same thing after a few days.
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
Sep 28, 2012 | Dishwashers
Interior lights come on, draining battery
You should check the various door switches and any manual cab light switch. A little physical movement on those switches should be able to identify the problem area. With the door open you should see the switch that gets pushed in when the door is closed. Push it in with your finger and see if it reacts properly. sometimes there's a little tab on the door itself that would be the contact point with that switch and if it comes off or is damaged, the switch doesn't get pushed in far enough.
Aug 27, 2012 | 2000 Mercury Grand Marquis
It turns on and comes onto a report problem so i send it but sometimes a report problem doesn't come up nether the less either way it starts for about 7 seconds then just freezes won't let me move...
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
Sep 15, 2011 | Sony Playstation 3 (PS3) Console
My WHD928 won't start. Plugged in, tank is in correctly- but no go. The lights don't even come on. Is it terminal??
I hope it's not terminal, as Windchaser is no longer in business. Remove and check the top of the water collection bucket for a float valve. It may be stuck in the "UP" position. If it is, jiggle the arm to make it return to the "Down". While you have the bucket out, look inside the bucket holder. On the rear wall of the holder you should see the bucket removal safety switch. It should look like a plastic trigger switch. With the unit ON, activate the switch with your finger. If the unit does not turn ON, then the switch is at fault. If it turns ON, then the bucket was not making contact with it, when it was last reinstalled. Reinstall the bucket "squarely" from top to bottom into it's holder. Making sure that it does not tilt down at the bottom when installed and makes contact with the switch.
If the unit did not turn On when you tried to activate the Bucket Removal Safety Switch, it's time to start shopping for a new dehumidifier. As there are no parts available for Windchaser units.
I hope this helped you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 08, 2011 | Windchaser WDH928 Dehumidifier
I have a Maytag LSE1000. The dryer and washer each have an issue at the moment. The dryer intermittently won't engage when it is turned in. When you press the "regular" button to start it,...
I really have NO idea what's causing your Maytags to misbehave, BUT I can tell you that the Maytag service centers have always been very accommodating when I've called about problems with dishwashers, dryers, and washing machines.They have explained the construction of the appliance and even told me the type of tools I needed to make repairs! If you still have your owner's manual, the toll free number should be in there. I hope this helps!
Jul 28, 2011 | Maytag Dryers
My garmin shows a computer picture and doesn't switch on anymore!
Connect it with the USB cable to a PC / Mac - does it communicate with Mygarmin.com? If so look for a software update and load it. Make absolutely sure it's connected to external power - so the battery won't die when updating. Then wait for it to restart.
If no connection then hold the power button for more than 20 seconds - this triggers the auto reset.
If that doesn't help - let it sit like this till the battery has been drained. Then try to restart while charging it.
If still the same - let it drain again and while pressing the On button, hold the lower right corner of the screen for at least 20 seconds. This will trigger a master reset - reverting back to factory mode. It will erase all user data.
Jul 04, 2011 | Garmin GPS
Have a 2011 Hyundai Sonata that is getting stuck in Park and I have to press the shift lock release to put in D everytime
No, that's wrong. The setup on the Sonata doesn't normally require messing with the shift lock release at all. I had the same problem tonight for the first time after owning the car for a year and a half, that's why I looked up this issue.
Jun 19, 2011 | Hyundai Sonata Cars & Trucks
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
When I turn on my set, light turns green, then after 30 seconds turns red won't come on
Sounds like there is a problem with the power supply. Try unplugging the T.V. and hold the power button for 30 seconds. Plug the T.V. back in and see if that helps. If it doesn't try switching to another outlet, and if that doesn't work then you may need to replace the power supply which would probably cost anywhere from 140 to 200 for one.
May 05, 2011 | Fujitsu PlasmaVision P50XHA40US 50 in....
Blackhawk Night Ops Xiphos Nt Weapon Mounted Light, Black Logo
Top Blackhawk Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Blackhawk Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
