Question about Cell Phones
E 63 charging signal ok but battery not charging jumperdayagram
    Sergeant:
  • 145 Answers
You are required to purchase company branded bttery from reputed showroom he will give you guarantee
Posted on May 24, 2011
What does codes 64 63 11 09 and 21 0n 2005 dodge stratus mean
CODE 11 No distributor referene signal detected during engine cranking....Check circuit between the distributer and the pcm.
CODE 12 Problem with battery connection.Direct battery input to pcm disconnected within the last 50 ignition key-on cycles.
CODE 13** Indicates a problem with map sensor vacuum system.
CODE 14** map sensor voltage to high or to low.
CODE 15** Problem with vehicle speed sensor signal.No vss signal detected during road load conditions.
CODE 17 Engine is cold to long.Engine coolant temp stays below normal operating temp(check thermostat).
CODE 21** Problem with oxygen sensor signal circuit.Sensor voltage to computer not fluctuating.
CODE 22** Coolant sensor voltage to high or to low.Test coolant temp sensor.
CODE 23** Indicates that the air temp sensor input is below the minimum acceptable voltage or sensor input is above the acceptable voltage.
CODE 24** Throttle position sensor voltage to high or low.Test the tps.
CODE 25** Idle air control (IAC) valve circuits.A shorted condition is detected in one or more of the IAC valve circuits.Or a vacuum leak has been detected.
CODE 27 One of the injector control circuit output drivers does not respond properly to the control signal.Check the circuits.
CODE 31** Problem with canister purge solenoid circuit.
CODE 32** An open or shorted condition detected in the EGR solenoid circuit.Possible air/fuel ratio imbalance not detected during diagnosis.
CODE 33 Air conditioning clutch relay circuit.An open or shorted condition in the compressor clutch relay circuit.
CODE 34 Open or shorted condition in the speed control vacuum or vent solenoid circuits.
CODE 35 Open or shorted condition detected in the radiator fan low speed relay circuit.
CODE 37** Open or shorted condition detected in the torque converter part throttle unlock solenoid control circuit.
CODE 41** Problem with charging system.An open or shorted condition detected in the generator Field control circuit.
CODE 42 Fuel pump relay or auto shutdown relay (ASD) control circuit indicates an open or shorted condition.
CODE 43** Multiple cylinder misfire detected.Peak primary circuit current not achieved with the maximum dwell time.
CODE 44 Battery temperature sensor volts malfunction.Problem with the battery temperature voltage circuit in the pcm.
CODE 46** Charging system volts to high>Computer indicates that the battery voltage is not properly regulated.
CODE 47** Charging system voltage to low.Battery voltage sense input below target charging voltage during engine operation and no significant change in voltage detected during active test or alternator output.
CODE 51** Oxygen sensor signal input indicates lean air/fuel ratio condition during operation.
CODE 52** Oxygen sensor signal input indicates rich air/fuel ratio during engine operation.
CODE 53** internal pcm failure detected.
CODE 54** No camshaft position sensor signal from distributer.Problem with the distributer synchronization circuit.
CODE 55 Completion of fault code display on check engine lamp.this is end of message code.
CODE 62 Unsuccessful attempt to update EMR mileage in the controller EEPROM.
CODE 63** Controller failure.EEPROM write denied.Check the PCM
Dec 12, 2012 | 1995 Dodge Stratus
Key will not turn in 2002 S430
Just some suggestions.
Clean the end of your key and get an earbud and metho/alchol and clean the keyhole sensor.
Change the battery in your key.
Check the charge level on the battery. Recharge.
Check alternator charging.
climatecontrol diagnostic menu
To enter mode press "REST" for more than 5 seconds. Use the left & right Auto buttons to scroll.
standing
value code description
15 1 Inside Temperature
11 2 Outside Temperature
11 3 Left Heater Core Temperature
10 4 Right Heater Core Temperature
10 5 Evaporator Temperature
11 6 Engine Coolant Temperature
3 7 Refrigerant Pressure: displayed as 1.xx bar where xx is in the display
10 8 Refrigerant Temperature
0 9 Not Used
1.2 10 Blower Control Voltage: 6.0V
11 Emission Sensor: 2.4V
12 Sun Sensor: 4.1V
0 20 Control Current for Auxiliary Fan: 3.2mA (Is this value too low?)
0 21 Engine RPM: 44 => 4,400rpm
0 22 Vehicle Speed
0 23 Terminal 58d: 32 or 32% of Full Battery Charge
12.0 24 Battery Voltage: 13.3V
8 40 Software Status: 164
5 41 Hardware Status: 85
216 42 Variant Code 1st numerical value
14 43 Variant Code 2nd numerical value
50 Not assigned
51 Not assigned
52 Not assignd
60 Roof OPE/CLO
61 Left side air outlet, knurled wheel potentiometer Volts
62 Vacuum actuator 46, feedback potentiometer Volts
63 Center outlet, knurled wheel potentiometer Volts
64 Vacuum actuator 47, feedback potentiometer Volts
65 Right side air outlet, knurled wheel potentiometer Volts
66 Vacuum actuator 48, feedback potentiometer Volts
Item 63 is the input signal from the thumbwheel controlfor the center vent, and 64 is the feedback signal to the controller giving it the position of the vent flap. As you move the thumbwheel these values should continously vary from a minimum of roughly .7 to 4.5.
Apr 03, 2017 | 2002 Mercedes-Benz S-Class
Garmin 255w i replaced the battery, symptons of charging
Hello
There sill be a battery symbol in the forner of the screen which sill indicate advancing the charging signal [very like battery signal of a cellphone] in green color. You can see it on its manu page. To increase the accuracy of the battery guage, gully discharge the battery and then fully charge it. Do not unplug the Nuvi, until it is totally charged. Connect the vehicle power cable to the mini USB connector on your Nuvi and to a power outlet in your vehicle. The vehicle key may need to be turned ON/ACC for Nuvi to charge.
Connect an AC adapter [optional accessory] to the nuvi and a wall outlet.
Connect your Nuvi to a computer using a USB cable. The computer must be ON for the nuvi to charge. OK.
Jan 12, 2012 | Garmin nuvi 255W GPS Receiver
My laptop emachine 350 is charging but it only show 63% of recharge, my battery is getting full,wat the problem
depending on how old the battery is, it may appear to be fully charging but is in fact only meeting the 63% of charge it indicates.
Firstly, download this and let it confirm the battery charge, it is freeware.
http://www.mioplanet.com/products/batterymeter/
You may find that you need to "educate your battery", to do this, run it down to flat, recharge it and then run it flat again, do this a few times. If the battery then still refuses to charge, you MAY have a defective charger / charging circuit, but more likely, the battery is at the end of its life
Jul 02, 2011 | Computers & Internet
Is there a list for computer codes for 1980-1990's Chrysler Le Baron
Yes here is that list.
Chrysler products COMMON CODES OBD1 (vehicles made before 1995)
Part 1: Chrysler Domestic vehicles
CODES/Meaning
88 display used for start or test
11 camshaft signal or ignition signal, no reference signal during cranking
12 memory to controller has been cleared within 50-100 engine starts
13 map sensor not detecting any change during test
14 map voltage too high or too low
15 vehicle speed sensor, no signal detected
16 knock sensor circuit. open or short detected
17 low engine temperature, possible thermostat fault
21 oxygen sensor signal, neither rich or lean detected
22 coolant sensor voltage low
23 air charge voltage high/low detected
24 throttle positioner sensor voltage high/low
25 automatic idle speed motor driver circuit, short or open detected
26 injectors 1,2,3 peak current not reached
27 injector control circuit does not respond to control signal
31 purge solenoid circuit, open or short detected
32 egr solenoid circuit, open or short detected
33 a/c clutch relay circuit, open or short detected
34 speed control servo solenoid, open or short detected
35 radiator fan control relay circuit, open or short detected
36 wastegate solenoid, open or short detected
37 part throttle unlock(PTU) circuit, open or short detected
41 charging system circuit not responding to control signal
42 fuel pump or auto shutdown (ASD) relay voltage sensed at controller
43 ignition control circuit not responding
44 battery temperature voltage circuit problem
45 turbo boost limit exceeded-map sensor detects overboost
46 battery voltage too high
47 battery voltage too low
51 air/fuel at limit
52 logic module fault
53 internal controller failure
54 camshaft reference circuit not detected
55 end of message
61 baro read solenoid, open or short detected
62 emr mileage not stored
63 eeprom write denied
64 flex fuel sensor signal out of range
65 manifold tuning valve, open or short detected
66 no ccd messages
76 ballast bypass relay, open or short detected
77 speed control relay, open or short detected
May 31, 2011 | Chrysler LeBaron Cars & Trucks
Why won't my computer charge me nikon s202 camera
The S202 does not include any charging circuitry. The computer connection is solely for transferring your photos and videos, not for charging the battery. You should have received an MH-63 battery charger with your camera, use this to charge the battery.
If you need a charger, you can order one from Nikon at
http://shop.nikonusa.com/store/nikonusa/en_US/pd/productID.213504100
or a third-party charger from
http://www.overstock.com/Electronics/Dolica-Nikon-MH63-Charger/3540127/product.html
Nov 15, 2010 | Cameras
My nikon coolpix s220 wont charge... do i have to have the original charger???
The S220 uses the EN-EL10 battery. The camera does NOT incorporate any charging circuitry, so connecting it to a computer actually drains the battery. In order to charge the battery, you need the MH-63 battery charger or a third-party equivalent.
If you need a charger, you can order one from your local Nikon dealer or from http://www.nikonmall.com
Feb 21, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Charging battery
You don't. The EN-EL10 battery requires the MH-63 battery charger or equivalent. The camera does not contain any charging circuitry.
Feb 14, 2009 | Nikon Coolpix S210 Digital Camera
Charging problem.
Since your laptop is one year old, i guess you still have warranty on it. Your battery is bad and you need a new one. Go to the shop and request a new one by the warranty.
Nov 03, 2008 | Compaq Presario Notebook
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
