Question about HP Mini 1000 Netbook
Hi I have the Hp mini and its been installing update 25of 25 for hours I cant stop it or push any other buttons to make it go away. Its jammed. Turning it off does nothing either. Please help xx
  • khaled hussien May 24, 2011
    are the updates your computer is downloading updates for windows or not and what windows you are using
    Problem Solver:
  • 8 Answers
Have you tried using the Task Manager to end the updater task ? if you have not, then press CTRL+ALT+DELETE, then click on task manager. Click on the processes tab (second one from left) and look for words such as HPupdater. then right click on it and press End process
If that does not solve the problem, try pressing and holding the power buttong for a few seconds, this should turn the computer off.
Posted on May 24, 2011
Video controller driver
1-go to hp.com search for your mini part number click on driver button download it
2- or try to download and install with windows update
3-if you know what is your graphic card manufacturer:
if (intel go intel.com) if (NVidia go nvidia.com) if (ATI go ati.com)
4-if you still have problem try some automatic driver finder software like (download "driver solution pack") install and enjoy
5-if doesn't solve try call hp or ask someone to fix it for you
best regards
Jun 15, 2013 | HP Mini 1000 Netbook
A jam message that wont go away
Hello jmcmeeking
Open your printer like you are going to replace the ink, re- install ink cartridges close it up.
If that does not work, then open the printer ink department push the ink carriage all the way to the right it might be it can’t find the home position sensor. Turn it off and then on.
Good Luck
Oct 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I cant open my Iphone after rebooting
Some tricks to try;
1.) Try pushing and holding the power and home buttons for 25 seconds.
2.) Try connecting to iTunes and do a full restore?
a. If you are experiencing the same, try this:
b. Hold buttons sleep + home until iPhone turns off;
c. Open iTunes;
d. Hold home button and plug the phone to your computer. The phone will turn on and the iTunes + Arrow + cable screen will appear.
e. ITunes will recover you phone from unsuccessful recovery process.
Please let us know if that was helpful enough.
Good Luck & Thanks,
Shiv.
Aug 17, 2009 | Apple iPhone Smartphone
HI! I CANT NOT ACCES WEB SITES PROPERLY ON MY I
update the settings for internet or check if opera mini is avalable for imate worth a try
Jul 23, 2009 | i-mate K-jam Smartphone
How to Reset HP Mini 1000 Laptop BIOS?
http://laptoppassword.blogspot.com/2011/06/hp-mini-password-service-compaq-mini.html
Clear Bios Password for HP Mini - Compaq Mini:
HP Mini 1000, HP Mini 110, Compaq Mini 110C, Compaq Mini 110, HP 2230S, HP Mini 1120LA, HP Mini 1151NR, Compaq 700....If you see this screen on boot:Enter CURRENT Password: [_______________]
We can help you Remove Password, right now !!!
You just enter 3 random passwords one by one and see if you get a similar [System Halted] message with 10 chars Error Code. (e.g CNUXXXXXXX, 2MCXXXXXXX....)
Jul 16, 2009 | HP Mini 1000 Netbook
Jammed power button
Hi there! If you cant push it back try pushing it with a flat skrew driver, or try to bring it to the store from once you purchased and make sure you bring the receit.
May 28, 2009 | Coby MP-C7085 MP3 Player
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Jan 05, 2009 | Bulova Watch
Printer Jam Message
hp officejet 4100 all-in-one
Feb 25, 2008 | Office Equipment & Supplies
HP Mini 1000 Netbook Logo
43 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
