Question about Fujitsu fi-4750C Flatbed Scanner
IRREGULAR STATUS IS DETECTED IN SCANNER IF THIS STATUS RECURRS AFTER POWER CYCLING PLEASE give following sense key and asc code to your service provider if asc code is the following please confirm following status before power cycling when asc = 0*580 confirm it the shipping lock(if any) is set at release position clean the sheet guide(white part)in adf
2 Suggested Answers
john_madd112
SOURCE: Fujitsu fi-5750C flatbed will not scan. I keep
Mine came with the same error message. If you look through the glass into the left front corner, you should see a spring loaded belt tensioner device. It merely hooks into the bottom plate against a spring to keep the belt tight. On my 5750C, the belt tensioner had slipped out of the base during shipping. The hardest part of inserting it back into the base was getting to it. Directions to do that are on this site at .../support/t484836-taking_apart_flatbed.
Posted on Nov 15, 2011
How solution Unebal to EF in Brother DCP 7055 matchine ?
Error code EF - Irregular power supply is detected
Print Unable EF
Turn the power off and then back on again.
Sep 29, 2014 | Brother DCP Office Equipment & Supplies
Tip
BitDefender antivirus with free license - Ubuntu
BitDefender Antivirus
is a versatile on-demand scanner built for Linux systems.
It provides antivirus and antispyware scanning.
1.
First get a free license copy of BitDefender.
http://www.bitdefender.com/site/Products/ScannerLicense/
Fill in the information to get the license key to your email.
2.
Applications> Accessories> Terminal
When you open this copy it (when you ask for your password, type):
gksudo gedit /etc/apt/sources.list
Add the following lines:
deb http://download.bitdefender.com/repos/deb/ bitdefender non-free
(Save changes and close sources.list)
3.
Terminal
wget http://download.bitdefender.com/repos/deb/bd.key.asc
sudo apt-key add bd.key.asc
4.
Terminal
sudo aptitude update && sudo aptitude safe-upgrade
5.
Terminal
sudo aptitude install bitdefender-scanner-gui
6.
Restart your system
7.
Applications> System Tools> BitDefender Scanner
on Jan 29, 2010 | Computers & Internet
Backside Optical alarm (G) when using Duplex option
Hi Rasha,
ADF backside scanning optical alarm (upper optical unit ADF) is E3 alarm. When there is an irregularity in the amount of light (ADF back), "E" and "3" will be displayed alternately on the function number display panel of the scanner.
Please check the followings:
1.Does the same symptom occur after turning OFF and ON the scanner?
2. Is the lower glass (white sheet guide) of the reading section dirty? Open the ADF, and clean the sheet guide (white part) and the glass.
3. Is the upper Optical unit ADF dirty? Are the cables damaged? Are the connectors connected properly?
4.E3: Is the upper lamp ON? Are the cables damaged? Are the connectors connected properly? Disconnect the SCSI cable and turn the scanner ON. Open the ADF and press ADF cover open sensor as shown below to see if the ADF lamps light which has to be replaced.
I would recommend to contact an authorized FUJITSU scanner service provider or the dealer where you purchased the scanner.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jun 12, 2013 | Fujitsu fi-4750C Flatbed Scanner
Fujitsu fi-5750C flatbed will not scan. I keep getting an error "Irregular status is detected in the scanner. Anomaly in Flatbed motor operation. There are some codes: Sense Key = 0x4; ASC=0x580;...
Sep 20, 2011 | Fujitsu fi-5750C Flatbed Scanner
My check engine light has been on for three days and when a scanner was placed on it the following information came-up. Trouble code P0031, H02S Heater Control Circuit Low (Bank #1 Sensor #1). However, I...
I can only help with the code,P0031=Shorted low condition detected in the oxygen sensor,1/1 heater element control feed back sense circuit.
Also a web site which gives the code breakdowns-www.wjjeeps.com/faultcodes.htm.
maori boy
Dec 26, 2010 | 2004 Jeep Grand Cherokee
Fujitsu 4750c Irregular status is detected in scanner
If "Front Side Optical Alarm" appeared, clean the glass (small and large one) of the flatbed and carrier unit.
If the issue persists, then check if CCD harness or CR cable is disconnected? Connect the connector.
If the issue persists, then replace Front lamp.
If the issue is not resolved, then replace the Control PCA or Carrier unit or Optical unit.
regards,
Tech Satya
Sep 21, 2009 | Fujitsu fi-4750C Flatbed Scanner
Fujitsu fi 5120c e2 error
See page 25 of:
http://193.128.183.41/support/scanner/manuals/fi-5120c_gs_p3pc-1312-01en.pdf
"E2" is "Trouble with the optical system (front)."
That doesn't solve your problem, but at least it narrow downs the focus of your problem.
Dec 05, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Fi-4120c2 error Code
The scanner does self-diagnostic when receiving Read Command (to start scanning) and displays the result if any error or alarm is detected.
Error code-E3 in Fi-4120c2 scanner means "Light intensity check" . When this error is displayed on the scanner panel, TWAIN displays the following error-
" Irregular status is detected in scanner. If this status recurs after power cycling, please give following Sense key and ASC code to your service provider.
If ASC code is the following, please confirm following status before power cycling’
- When ASC=0x580, confirm if the shipping lock (if any) is set at “Release” position.
- When ASC=0x680, clean the sheet guide (white part) in ADF.
(Error Code DS42001)
E3 explains Optical alarm (back). This alarm occurs if the gain adjustment of the CCD amplifier does not succeed at a READ command for the first document, or during scanning.
Probable causes:
- The lamp, the optical system or white sheet guide is dirty.
- Defective lamp or CCD.
- Connector disconnected
To check and resolve the issue, lease follow the steps provided below:
1. Is sheet guide (white part) in the reading position dirty?
#Open the ADF and clean the sheet guide (white part) and the glass.
2. Is the lamp ON?
3. Are the cables damaged?
4. Are the connectors connected correctly?
#Disconnect SCSI cable and turn the scanner ON. Open the ADF and press Cover open sensor to see if the lamp lights. If not, the error is caused by the defective lamp.
5. Is the optical unit dirty?
6. Are the cables damaged?
7. Are the connectors connected correctly?
# Check and Clean (ADF back):
# Check if inside of the grass for Upper unit ASSY is dirty. Clean inside of the glass of the dust cover.
9. If the issue still persists, then you may have to replace Optical unit.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Oct 08, 2008 | Fujitsu fi-4120C Path-Through Scanner
Fujitsu fi-4750C Flatbed Scanner Logo
1,383 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
