Question about Behringer Bugera 333212 120W 3 Channel Guitar Combo Amplifier
My new Bugera 333 212 combo has a weird "ringing" noise on the crunch channel. The noise can be heard on other channels too, but it is loudest on crunch. The noise is clearly mechanical, (it comes up when knocking the front panel gently with my fingers) but it is amplified and comes through the speakers also. This made me wonder if one of the valves could be microphonic. The noise appears while playing through the amp, as it resonates. It sounds like a small metal particle resonating, but it's weird because it comes out from the speakers. How can this be fixed and if I get it fixed by a professional, how expensive this type of procedures usually get?
    Problem Solver:
  • 7 Answers
Change your power tubes. Bugera says they are matching sets but they aren't. Buy from euro tubes they match their tubes within 1ma of each other and they sell amulti meter with a bias probe for 35 bucks
Posted on Jul 02, 2011
  • Behringer Master
  • 5,603 Answers
Microphonic tubes can be detected by tapping them lightly with a pencil. I cannot find if this uses a spring reverb, but if it does, vibrating the cabinet will get a clanky type sound from the reverb tank. This MAY use a digital reverb however which is immune to that. Next thing is to make sure your guitar can't "hear" the output sound of the amp because the strings can pick up the sound and resonate feeding back into the amp. You can detect if this is happening by quickly dampening the strings and see if ringing gooes away. You probably need 6 to 10 feet of clearance between the guitar and the amp OR put your body between the amp and the guitar. ALWAYS set sound level at safe levels. Get a sound meter and go no higher than 90 Db. I know a lot of near deaf musicians whose careers are near over because of hearing loss using too high level.
Posted on May 24, 2011
Can l get a drity guitar sound with my ampeg vt-60 if so how?
The VT 60 was made in the USA and was a very good sounding amp introduced by SLM (St. Louis Music) in 1989.
There are three channels: clean, crunch and overdrive.
You should be able to obtain a decent dirty using crunch channel but if I remember well you MUST have the dedicated pedal to switch channels and reverb.
Oct 15, 2015 | Ampeg Music
I own a Peavey Valveking vk100 and when using the distortion channel on high gain it makes a weird whistle-like noise (not a feedback sound). The strange thing is that if i lower the gain, the sound...
Sounds like Tube Microphonics to me...
Change the 12AX7 (I guess) for that channel for starters.
If not, some condenser went crazy.
Nov 12, 2017 | Music
Changing channels by it self
Is this happening only with the foot switch plugged in? A bad cable on the footswitch is the most likely cause but there could also be a problem within the footswitch jack on the amp.
Aug 16, 2012 | Behringer Bugera 333212 120W 3 Channel...
Whenever I slightly adjust the "Channel Volume"
You've got a loose wire! What's happening is that there's a bad potentiometer (the electrical component behind the knob) that's out of place and is only connecting fully at one point in the knobs circuit (the part where you get full volume) take it in to an amp tech at your local music store and they'll fix it up easily.
Feb 20, 2011 | Line 6 Spider Iii 15 Modeling Guitar...
Bugera 1960A - channel 2 has very low volume even when vol2 knob is turned fully UP!
The user manual is located at: http://www.bugera-amps.com/PDF/Downloads/1960_P0671_M_EN.pdf on page 5; When the HIGH 1 and LOW 1 (or HIGH 2 and LOW 2) connectors are used simultaneously, their sensitivity is the same (both LOW). This may be your problem however--- Try swapping input chanels to see if the problem follows ther cable or is in the amp.
Assuming it was working before, you may have a short in the cable or a bad component or tube in the amp. Tubes can be difficult to come by. If the other channel works correctly, It may be one of the small tubes. Hope this helps
Jan 04, 2011 | Behringer Bugera 1960 Classic 150-Watt...
Only the clean and insane channels are working, i no longer have the crunch or metal channel i get no distortion on these 2? the amp is only 2 years since i bought it brand new and the metal channel is my...
If you have the manual try doing a factory reset. The info is here:http://line6.com/community/docs/DOC-4499 You might also be interested in joining this forum:http://line6.com/community/community/support/amplifiers/spider?view=discussions
Jan 23, 2010 | Line 6 Spider Iii 120 Stereo Guitar Combo...
The gain control no longer works on the clean/crunch channel. all other features work fine, whats wrong with my amp?
Hi there. Try re-soldering the control pot to circuit board connections. If not, use ohm meter to verify pot functionality. If bad, replace.
Thanks
Paul
Jul 10, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Behringer Bugera 333212 120W 3 Channel Guitar Combo Amplifier Logo
411 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
