Question about Bosch SMS63E Dishwasher
Bosch Dishwasher SMS4602eu is not heating up. I have tested the heating element for continuity and this seems to be fine. Any other suggestions would be greatly appreciated?
  • 213 Answers
SOURCE: test bosch heating element
remove the kick plate at bottom of dishwasher, at the left leg there will be a wiring diagram. remove console and test element from there. diagram will show which wires to test
Posted on Nov 20, 2007
  • 49 Answers
SOURCE: Fills with water, sounds like it starts to pump water then stops, then start again
you have a wash pump problem. can be 1 of 3 things. most likely something is caught in the pump impelor if not the wash pump motor may be faulty or ceized or it could be the capacitor for the wash pump motor is faulty. you can try removing the wash pump yourself and check the impelor if it spins freely then you will have a motor problem.
hope this helped
Posted on Feb 19, 2008
  • 1462 Answers
SOURCE: Whirlpool Dishwasher ADG7540/1
an ntc is very reliable. have you checked continuity thro the heater? other common fault is a dry joint devoloped on the control card - take it out and check for dry joints
Posted on Oct 03, 2008
Macmarkus
  • 2605 Answers
SOURCE: Bosch dishwasher SHU3032UC/U12: Gets
Welcome to FixYa.
Based on you description of the timer not advancing you`re on the right track when you said "Thought it might be the timer (control unit), but now am wondering if it could be the heating element or thermostat"
I suspect the thermostat isn't satisfied when heating the water, hence it get`s hung up trying to heat in the part`s of the cycle it`s called for.
It very well could be caused by a faulty flow switch, NTC or heater as well but not very likely.
The SHU 30** series Bosch dishwashers with a rotary dial timer have very few if any, issues with the actual timer or element but they do with the thermostat within the door panel.
If it ( the thermostat ) is not satisfied the water may heat but not be indicated via the thermostat, hence timer will not advance.
Here`s what you can try. If you have any hesitation or reluctance to service this yourself please call in an authorized B/S/H/ appliance technician.
**Turn off the breaker at the service panel before attempting any service suggested **
  1. You will require a #20 torx screwdriver to remove the door panel by taking out the screws around the panel, except the ones along the top ( watch the edges they are very sharp )
  2. Once the panel is removed you should see the thermostat over by the detergent dispenser clipped to the inner door, remove it and test it. You`ll need a ohm meter/multi-meter plus a lighter or match to heat it up to see if it open`s & closes.
Example...
**NOTE** it can occur the thermostat can become loose and detach from the bracket which holds it in place, this too can manifest in the sysmptom of the timer not advancing.
Let me know how you make out and what you find.
Thank you for choosing FixYa and Good luck.
Regards,
Macmarkus :)
Posted on Sep 10, 2010
Testimonial: "Wow, loads of good inf to try to fix my dishwasher! I appreciate the very detailed answer to my question."
Macmarkus
  • 2605 Answers
SOURCE: Bosch dishwasher shx46b02uc has stopped
Welcome to FixYa.
Based on your description
I'd say the issue actually with the control...unfortunately.
Bosch has had a history of this exact problem I'm about to lay out for you and it is rarely the element...maybe 1%. This is the first thing I'd be looking for if called out to service the unit with the symptoms you've described. **B/S/H/ also issued a recall on certain models between 1999 - 2006 depending on the model & serial number, you can check with yours but you'll need the serial number too. The issue was directly related to the heating circuit (specifically the heat relay on the control) Here`s the link if you want to see for yourself **
http://microsites.boschappliances.com/safetyrecall/dishwasher/
As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
My first suggestion would be contacting Bosch re: the recall or calling in an authorized bosch service tech. if that is an option for you and your budget however, If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself...it really isn't very complicated.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Flip this over and inspect the solder joints, it will be obvious when you see it.**
This ones new, but it's where to look...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed...or takes a long time as I mentioned and eventually display's "1" on units with a display and usually very poor cleaning as a result.
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Hope this answer`s your question, let me know if I can assist you further.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Nov 26, 2010
Testimonial: "I appreciate the fast response. Makes a lot of sense and will start exploring next steps. Nice work."
Why is my Bosch SHE4AM15UC dishwashwer not heating water not sanitizing? How do I fix this problem?
The problem could be a failed heating element. If replacement of the control panel results in no change, the element could be the problem.
Jul 16, 2014 | Bosch SHE4AM15UC Dishwasher
LG LDS581 dishwasher HE error mid cycle
HEATING (ELEMENT) ERROR // Water heating error
The manufacturer has assigned this error or fault code to indicate a problem with the water heating circuit. Turn off the circuit breaker to the dishwasher for 30 minutes, allowing time for the appliance to cool; then restart the cycle. If error returns, check the heating element for continuity and check the wiring harness for any obvious signs of damage. If the heating element shows infinite resistance after testing with an Ohm meter, replace it.
Oct 01, 2017 | LG 24 in. LDS 5811 Built-in Dishwasher
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Regards,
BElectric
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
My dishwasher does not do a hot wash. Why is this? If I need to replace the heating element, how do i gain access to heating element on my Bosch classixx dishwasher?
Hi, a common problem with these machines is the solder coming away from the heater relay. A simple repair if your lucky. Run a continuity test on the element with a multimeter before replacing it, as it is a massive job to change it. I just changed mine yesterday, the machine had to be totally stripped down. Although its not an impossible task, it does take some time. A kindly man on this site sent me a manual for Bosch dishwashers, which helped me enormously on stripping the machine down. I don't know if it is any good for your machine, but if you give me your email I will send it on to you. Mike :)
Nov 29, 2010 | Bosch SHU9950 Dishwasher
Have BOSCH diswasher model SHE44C06UC/22 and it continues to cycle but never drys
That could either be a problem with the control module or the heating element...my first guess would be the heating element... as it is looking to sense it working and does not...
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 29, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
S5N27B keeps stopping mid cycle
If the cycle doesn't complete, check these:---
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Bosch Dishwashers
Dishwasher stalls
Water-heating cycle
Timer
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
May 31, 2009 | Bosch SHU4006 Dishwasher
We have a +11 year old Bosch SHU3006/UC/U06 that never leaves the wash cycle. We had to stop it during our last test run at 3 hours. Chat advise is suggesting a water temperature problem (I origionall...
Check continuity of the heating element to see if it is broken/open.
The dishwasher prefers that the incoming water (water heater) be 120 degrees (F)
Apr 04, 2009 | Bosch SHU3036UC Dishwasher
Bosch dishwasher running to long and not sanitzing dishes
Sounds very much like an element fault. Locate and test continuity of the element
Jan 02, 2018 | Dishwashers
Test bosch heating element
Nov 16, 2007 | Dishwashers
Bosch SMS63E Dishwasher Logo
55 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
