Question about Zebra Z4M Printer
Hello, how can I change label length through web interface
  • alekshopp Aug 12, 2011
    Thanks, I understood that after some experiments. The cause of the problem was labels that had some pictures on the back side. Printer could not define the length properly even after the calibration. Normal blank white labels solved the problem.
    Champion:
  • 254 Answers
You can't
To change the the size do a callibration with your labels
Posted on Aug 12, 2011
Z4MPLUS doesn't recognize the MEDIA(LABEL) automatically.
you should recalibt=rate the printer.
Are you sure that your previous label was not longer?
With the autocalibrate function activated the printer should try to detect the correct length. If it doesn't the yoou have
- A problem with the label border
- Preprinted stuff which the printer detects as to fo feed
Dec 09, 2013 | Zebra Z4Mplus Label Printer
Hi! I have a problem with my office Datamax E class printer. When i change tickets in the printer it doesn't print them the right size - normally they are too short. Do you have any idea how to solve...
If you are changing length(feed length) you may have to recalibrate the printer . Also ensure that your print format is the correct length for the stock.
You can look at the setup of the printer using the datamax-oneil printer configutation program, or if it is using IP connection, you can go directly to the internal web page for set up. make the cal length 3 times the label length, or leave at the default value.
Dec 29, 2010 | Datamax E-Class E-4203 Thermal Label...
The printer will print one label correctly, then feed out a blank one. when the next label is printed, the printer reverse feeds the blank label into the printer to print the next one, but not far enough...
This sounds like a size issue, meaning that your label has too many lines and that kicks to the "next page".
Look for too many line items on first label.
Oct 06, 2010 | Zebra Z4M Printer
How to stop calibrating soo much?
There is no way to get around the recalibration for different sizes of label, you must do it at every different label height, The callibration only sets the label height/length, so try doing the same length labels in sequence.
Oct 22, 2009 | Zebra 105SL Thermal Label Printer
Zebra Z4M Plus
Is the length of the label correct on the configuration print out?
Else try t check if there isn't a feed or print adjust in the parameters
Jun 25, 2009 | Zebra Z4M+ Printer
Printing wrong length on label
No, more than likely you just need to change the paper size and definitions within the driver and the application.
Don
Jun 19, 2009 | Intermec EasyCoder 3400 Thermal Label...
Zebra 140xiIIIPlus w/ attached cutter, cutter will not cut labels
For the cutter to work it is necessary to instruct the printer to "Use the cutter" This setting is usually accessible in the printer driver. Your label program interacts with the printer driver. Ensure that the cutter option is selected in the printer driver.
Apr 02, 2009 | Zebra 140XiIIIPlus Direct Thermal-Thermal...
Zebra 105 se label length is wrong
But physically measuring the label 1252? You can also disable the calibration options and then use the command ^XA^LL1252^XZ.
Jan 27, 2009 | Zebra 105Se Thermal Printer
2 LABELS COME OUT
your label length is set incorrectly, there are 2 things it could be
1) your software is telling the printer the label length is longer then the current labels, even if the label size is out my a single millimeter the printer will give you this issue of feed an extra label. you need to change this in your software. you can set a label size smaller then the current label size and it will work correctly
2) you software is not setting a label length and so the printer is going off its internal setting, to recalibrate hold feed and power up the printer letting go after the light starts flashing
it is important to note that label roll will change slightly over time so even though you are ordering the same labels as a year ago the manufacturer will have slight changes from batch to batch
Oct 13, 2007 | Zebra LP 2844 Thermal Printer
We are trying to set up to run locally on a serial port
The serial port parameters are set from the front panel.
Hit the "Setup" button, then hit the "Next" button (many times) until you reach the Serial Port parameters. You'll be prompted for a password before you get there. The default is "1234", entered with the "Plus and Minus" buttons.
Use the "Plus" and "Minus" button to make changes.
When finished, use the "Exit" button. Select "Permanent" changes and hit the "Save" button.
Sep 27, 2007 | Zebra 105Se Thermal Printer
Zebra Z4M Printer Logo
102 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
