Question about Car Audio & Video
Amp protector light
As soon as I turn on my CD player, my protector light comes on and there is no sound from rear speakers and sub.
  • 631 Answers
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page. I'll assume that you've checked the amplifier's on-board fuses.
Amp in Protection - Troubleshooting
Let me know if you have any other questions.
Posted on Aug 15, 2008
The tuner works fine, all the speakers play including my sub. When I put in a cd, only my sub makes sound, and when I go to the ipod no sound comes out. However When I go to the zone control and select the...
are you using more than one amplifier? it sounds like you may be using the blue wire to turn one amp and and the blue/white to turn the other one on. use the blue/white only. the blue wire is antenna remote and turns off when not in tuner mode.
Jan 09, 2011 | Kenwood DDX516 Car Video Player
When the radio is on the sound comes out of all the speakers. when the cd player is on the sound only comes out of the sub woofer
are you running separate amps for the woofer and speakers??? sounds like you have the woofer amp being turned on be the amp remote wire (blue/white) and the speaker amp turned on with the power antenna remote wire (blue). if this is the case you need to use the blue/white to turn both amps on.
Apr 30, 2010 | Eclipse CD2000 CD Player
Is there a wiring diagram for the nikkai EAPA450 Amp
Hi, if you still need a photocopy of instructions email me mail@srands.co.uk
If you want instructions in brief this involves POWER CONNECTIONS, PHONO LEAD & SPEAKER CONNECTIONS:
POWER (At the same time when routing these wires, I would connect the PHONO LEADS from the car cd player to the amp, if your car cd player only has 1 preout (1red & 1 white) then you will need two phono splitters, a female to 2 males. Phono leads carry the unamplified sound from cd player to the amp):
~ Permanent 12V+ (Thick lead that is fused direct from battery all the way to the amp, wire must be 20a to 30a +, hence 1cm diameter wire, known as AWG8, Maplin sell cheaper kits then most)
~ Amp REMOTE (A thin insulated cable (5a is OK) from car cd player amp remote wire, this turns the amp on when the cd player is on, if your car doesn't have an amp remote wire, suggest nearest ignition supply or seperate switch that you turn on when you want to turn on the amp)
~ GrouND 12V- (Insulated lead (20a to 30a) to nearest part of unpainted car chassis such as interior panel screw hole, instead of an insulated cable all the way from the batery, this is common practise.
SPEAKER:
Each speaker has a - negative & + positive, these must connected correctly. The amp has 4 channel, 2 channel labeled as front, 2 channels labeled as rear. Using speaker wire, connect cable from amp to speakers. Note: Ensure the speakers being connected only receive sound from the amp (Not cd player as well, as would damage players or at the very least impair sound)
The amp has a feature called bridgeable this means a sub 8" or 10" sub can be powered by 'bridging' two channels. For example there are 2 ways to bridge power a Sub on the NIKKAI EAPA450:
i) Sub speaker wire positive + to channel RL and Sub speaker wire negative - to channel RR.
OR
ii) Sub speaker wire positive + to channel FL and Sub speaker wire negative - to channel FR.
Switches:
~ Bass boost, meant to be on for a channel if using sub, otherwise off.
~ X-over mode adjust hi/lo frequencies, only work if both x-over switches are on! Then adjust switch frequency knob, until it sounds right.
~ Gain (Volume knob) adjust volume knob up or down, until it sounds right!
NOTE:
You will need patience! many hand tools and parts such as: Wiring kit, fuse holder 20a/30a, Phono leads, speaker cable, Fork/ring connectors, wire strippers, wire cutters, set of screw drivers, also ueful to have zip ties to tdy excess cable and 'P' cable clips to tidy speaker wire to shelf, etc.
OK
Any more questions just email me mail@srands.co.uk
Dec 01, 2009 | Car Audio & Video
Amp light on but no sound
either something in your amp burned up, or the audio wires going from your cd player to your amp are bad
Apr 14, 2009 | Alpine MRP-M500 Car Audio Amplifier
Cd player plays, but no sound comes out of speakers.
first off the amp gets power straight from the battery. the amp is used to power the subs. the subs are suppose to be connected to the amp only( never the speakers).
for the second part you mostlikely killed the wires. you should get some one to look at it and check the wires. thee speakers might need to be re-wired
Jan 31, 2009 | Kenwood KDC-MP238 CD Player
My amp only powers the subwoofer when the radio is on but wont when the cd player is on
The person(s) who hooked up your system made a boo boo. They wired your remote turn on lead to the power antenna lead instead of the amp turn on line (both are blue and easy to mix up). Thus when your radio is on it sends a signal to the amp and the amp turns on, but when you set to CD the signal goes away and your amp shuts down. Easy fix, just re-wire the amp turn on lead and the problem will be fixed.
Jun 24, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
No sound!!!!!
sounds like you blew an interior speaker.. it would cause the radios internal amp to shut down.
Jan 17, 2008 | Panasonic CQ-C8303U CD Player
No sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
Sep 02, 2007 | Alpine CDA-9827 CD Player
Car Audio & Video Logo
209 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
