Cant open my laptops ac adapter medion md6100
2 Suggested Answers
  • 184 Answers
SOURCE: Toshiba Portege 7100 AC Adapter
Specification of Toshiba Portege 7100 AC Adapter
Output: DC15V 4A
Power: 60W Max
DC Connecter (Barrel) size:
Internal Diameter: 3.0mm
External Diameter: 6.3mm
Posted on Aug 16, 2011
I have a compaq presario cq50-107nr and i plug my charger in the front light is on but when i press the power button to start up the light goes off and nothing happens help? It happen several times and i...
Please 1. unplug the ac adapter, detach the main battery, press the power button for 15 seconds, plug in the ac adapter, and restart your laptop. If the problem persist: 2.unplug the ac adapter, detach the main battery, press the power button for 15 seconds, take out the hard drive, plug in the ac adapter, and restart your laptop. If the problem persist, then it means that the laptop motherboard is dying. Please read your laptop's service manual before you open the laptop's case/body.
Mar 01, 2014 | Computers & Internet
No power light nothing working
Hi Keith, i would suggest contacting Medion as this appears to be a faulty mainboard, but you could try checking the obvious (ac adapter fuse) and the ac adapter could be faulty, can you check on other equipment, if out of warranty then you may have to take to a good local tech.
Feb 01, 2014 | Medion Computers & Internet
Medion MD 98200 My laptop will not turn on after my son removed the battery pack accidentally
Turn on the laptop without the battery, using only the AC adapter. If doesn't work remove the AC Adapter and battery. Hold down the power button for 30-45 seconds then plugged in the AC Adapter and put battery back in then [on]
Apr 11, 2013 | Computers & Internet
HI there, I wonder if someone could help me with the problem I am having with a Medion E1210 netbook. (mini laptop) When it is running on battery, it shuts itself down after, between 2 and 30 mins, even...
did you try the ac adapter those go bad too, the amount of voltage coming out of the adapter is not higher than the batteries out put voltage, then the battery wont charge
try the ac adapter
Oct 09, 2010 | Medion md40298 Notebook
Medion laptop brand new, powered up once only (windows 7) but wont startup windows since 2nd power on. I have tried using ''Application & Support disc'' but still no joy. The Medion Hellpdesk never...
Hi there, since your laptop is brand new, it is not really a major problem. You can try this method:
1. Pull or take the battery out from the laptop
2. Remove the AC adapter
3. Hold down the power button for 30 seconds
4. Put the AC adapter only
5. Turn on the laptop
6. And last put back the battery in.
Hope this helps, God bless
http://podnutz-hdlaptoprepairvideos.blogspot.com/
May 31, 2010 | Computers & Internet
Medion laptop will not start - have checked power leads and battery - have tried starting without the battery in - could the motherboard be the problem and if so what do i need to do
After removing the battery, plug Ac adapter & hold power button for
20 secs. If it doesn't work, check if the Ac adapter with a multimeter. After that if problem continues, check the adapter (port) on the Motherboard if the solder is good. If it's not, you should solder it.
If all the above don't work, so it's probably time to replace motherboard.
Hope it helps. Please send me your feedback & vote to help us help you better.
Feb 16, 2010 | Medion Computers & Internet
all are not same but you buy through ebay you cant replace it go the shop and verfy onces
Jun 11, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Medion mim2120
Have you actually tried another adapter already??
It sounds like something has burned out on your mainboard. However depending on the model it may have a removable power board. You may have to find someone that can trace down the power circuitry of the system with a meter.
You mentioned this is not the original adapter- There is definitely a chance that your adapter caused this problem. I never take a chance on a higher or lower amperage AC adapter with a laptop, since it stresses the power circuitry of the machine. Even if you can get it going again, i would strongly recommend getting a closer to spec adapter.
Jan 12, 2008 | Medion md40298 Notebook
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
