Question about Bosch Washing Machines
What does code flashing E21 on Make: Bosch and Ref. WVD24460GB/02 mean please?
3 Suggested Answers
Krazytech
  • 725 Answers
SOURCE: Error code E21
E21 Water not pumping out fast enough. .
Check for Restriction in drain pump or hose...
No restriction. Go to step (2).
2. Start the washer and check for 120 VAC at the
drain pump. if no voltage Replace the control board.
120 VAC. Remove the pump and check for
blockage. If blocked, remove the restriction,
if not, replace the pump.
Posted on Aug 24, 2008
  • 3 Answers
SOURCE: E21 is flashing on the screen what does this mean?
E21 indicates that water is not draining from the machine fast enough. This can be caused by a kink in the drain hose, a problem with the pump or a problem with the pressure sensor.
On my washer, there's a copy of the service manual inside the machine - remove two screws in the back and take off the top. The manual includes the error codes and the steps to take.
Posted on Nov 18, 2009
Error code e21: Bushes replaced by engineer but unable to reset machine. E21 still shows. Bosch totally unhelpful.
the electronics lock out during power surges like you would get from brush failure giving e 21 error. you have to access service test prog to reset this, and it is not in public domain.
i do know how to reset it though but difficult to explain on this forum you may find a you tube video if you search online.
Sep 24, 2016 | Bosch Washing Machines
I have a Bosch dishwasher that had error code E24. DW would work if door was opened about 1 minute into washing. New drain pump. No fix. New error code of E21. New control unit, still same problem.
E21 is a circ pump blockage issue. Check that all hoses are clear, unit drains completely. Depending on the age, a new circulating pump may be needed or new motor capacitor.
Jun 22, 2016 | Bosch Dishwashers
How do i reset code E21 on bosch classixx speedWash?
E21 is a blocked drain issue. Maybe a sock is stuck in the pump impeller.
Oct 05, 2015 | Bosch Washing Machines
All the lights on the spin speed panel light up and flash when switched on, no other sign of it starting a cycle, any clues please.
motor fault , change the carbon brushes and reset pcb. goggle e21 error its the same process to reset ..
Jan 29, 2015 | Bosch Washing Machines
E21 code on Bosch Dischwasher...what does it mean
E21 Circulating pump blockage
This would be caused by a blockage or a poor water flow from the main motor of the dishwasher. This can be caused by a capacitor failure or for other reasons.
Dec 08, 2013 | Kenmore HE2 Plus Front Load Washer
Error message e21. Bosch dishwasher
My mom had the same issue with her fancy bosch dishwasher! It ended up being a hose, if I remember correctly. Her problem also took two repair trips, I know for sure it was not a new motor issue. I would have someone check the hoses and the electrical panel.
May 28, 2013 | Bosch SMS68M02AU Dishwasher
E21 error code
E-21 excessive foam: too much detergent or wrong detergent being used. Needs HE stuff in it. Bosch troubleshooting guide
May 16, 2013 | Bosch Nexxt 300 Series WFMC2201UC
What does F02 fault mean?
Hello elaineginolf, welcome to Fixya. Error code "02" typically indicates a lock problem. Since not all models are the same can you clarify the model of Bosch you have ? The post category says WFL2060 but that can't be since that model has no display and faults are indicated by way of led lights flashing in a set pattern. Could it be a WFR2460 with the digital LED display ? Let me know and I'll see if I can assist you from there. Macmarkus :)
Jun 26, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Washer WFMC3200.
first of all, start with you close the door,you put the set on and continue please
Sep 27, 2009 | Bosch WFMC 3200 Front Load Washer
E21 error code
There is a E21. Water not draining fast enough. Try holding the start/pause and cancel key together for 3 seconds. The door lock, wash, rinse and final spin leds should light. Any error codes should be displayed when holding those keys.
PLEASE RATE THIS !
Jun 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
103 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
