My sound, audio, speech devices are not working and even to click it didnt work
  • 64 Answers
You have to get and install the audio device driver for your system before the sound can work
Posted on May 24, 2011
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
I have the Dell 5650 Computer Speakers and first 2 of the speakers stopped working and when i reinstalled the speakers again none of them worked. the green light of the center doesn even light up, any...
Hi, these instructions will help you with the Audio problem. These are the steps to setup and 'restore' the “Audio Drivers” Part (1) Click on the "Start" button, go to and click in the (right, pane) Control Panel.
Scroll to find, "Ease of Access (or) Speech Recognition Options. Click, on" Replace sound with visual cues."
In the See also: (Category), click, on “Audio Devices, and Sound Themes” click, “Playback” Next, click on the Active "Speakers.” Click “Configure” to "Audio channels" The (Speaker Setup) "wizard,” appear! Select (Test) click, Next! Follow the instructions. Part (2) Click 'Properties' change the "sound"(Level). Click on Enhancements, "Apply" changes. “The (Advanced),“not recommended!” In, the Controller Information (block), click on, Properties to "update" Drivers. Check to see if Device usage: (enable) if not? "Change it." *Note: Click "OK" to all change; 'Save' and Apply!, before exiting. “Did this solution help?”
Feb 03, 2010 | Dell 5650 Computer Speakers
Have reinstalled XP on my ACER veriton 5500G and sound did not work..Reloaded the required drivers....still no luck!!!
Hello my friend first make sure that your hardware is been recognized and there is not any problem with driver or hardware.To do this go to device manager
  1. Right-click My Computer then select Properties
  2. Select the Hardware tab
  3. Click the Device Manager button
Alternative option: Start -> Run -> devmgmt.msc -> OK
After you have open device manager check on sound,video and game controllers for your sound card,if is not having a yellow ! in front of its name and if you open it (double click) and on the device status says "This device is working properly" then your are ok and we are going to check the settings.If its not ok it means that you didnt install the right drivers or there is a hardware problem(conflict) and im waiting for your responce to help you.If everything its ok the we are going to check the settings.To do that we click on Start button and continue to the Control Panel item of the Start menu,then in the Control Panel window find Sounds, Speech, and Audio Devices section, click on it.Then click on Sounds and Audio Devices.Find the Audio tab (top line of buttons) and click on it. In the Sound Playback section: from the drop down menu, select the audio output device that your using.
Next make sure that your speakers are not muted.Click on the Volume button below the drop down menu.And unchecked if there is a tick on first or second(Wave) boxes and roll the bar to full(up).After you do that your speaker should be working:)
Good luck:)
Jan 31, 2010 | Acer Computers & Internet
Im trying to play music through my sound card and talk on the mic in paltalk i got SB1090 and it sitll dosnt work
try going to Start>Control Panel>Sounds,Speech, and other Audio Devices>Sounds and Audio Devices>click on Voice tab>go to Voice Recording,Default Device and change it to your current device.
Oct 15, 2009 | Creative Labs Sound Blaster Live! 5.1...
Audio/volume problem
First, go to control panel - > Audio devices, then right-click any empty spot on the sound device, and show disabled or disconnected devices. If "Speakers" shows up, right-click and choose set as default (or something similiar). If this does not work, just reinstall your audio drivers. Right-click my computer -> Properties -> Hardware - > Device manager - > Sound, then find the sound cards manufacturer name, and right-click an press uninstall.
Jul 20, 2009 | Acer Aspire 4720 Notebook
My speakers won't work we tried everything
do you have the audio drivers installed on your computer.go to control panel,sound,speech and audio devices and then click on sounds and audio devices.it should open up another window sound and audio devices properties.click on audio and check default audio device.should have some devices e.g realtekAC97.if its not there, google it to install and it should work.if this doesnt work please let me knoa.
May 30, 2009 | E-Machines eMachines T3830 PC Desktop
Sound is now unavailable
Please try to check your audio by right click (mouse) My Computer icon (on the desktop screen) > click Properties > select Hardware tab above > click Device Manager tab > click +Sound, Video & Game Controllers > double click your selected Audio Controller device- wherein you can see if the device status is working properly as well as if the Device Usage is Enabled, if not click Troubleshoot tab.
Or you can also check your Sound / Control device thru Start > Contol Panel > Sounds, Speech & Audio Devices > Sound & Audio Devices - wherein you can adjust the volume & test your sound.
Or you will have to reinstall the sound driver. best regards
May 21, 2009 | Gateway FPD1775W Monitor
My speaker sound
If you are using Windows XP, click >Start>Control Panel>Sound, Speech and audio devices> again >Sound, Speech and audio devices> then check the "Device Volume" control. Also check the controls under "Advanced" button.
Feb 15, 2009 | Polk Audio AMR50 Computer Speakers
Sound
Did you have sound before?
If yes then follow this for xp:
Start/control panel/Sounds, Speech, & Audio Devices/Sound & Audio Devices. Is page greyed out? If yes then most likely its your sound card or on board sound, or your missing drivers.
If not greyed out go to "Sounds" tab, click on any "Program events" sound under Windows then click little black arrow next to browse on bottom right . Sound? If the arrow is greyed out then its the same; audio hardware device or audio driver.
If there is still no sound click on "Hardware" tab and first Sound,video and game controller then "properties". This will tell you under "Device status" if this device is working properly. Do this for each Sound, video ect.... selection in the list. I have found there are usually 6 listings. If not then you are most likely missing a sound driver.
Jun 21, 2008 | E-Machines eMachines Desktop PC
Sound
Click on Start --> Control Panel --> Sounds, Speeches and Audio Devices
On the computer's native volume control, make sure nothing is muted.
If you have a sound card installed, reinstall the installation CD that came with it. If you no longer have the CD, go to the manufacturer's website and get the software from their website.
In many cases, when you go to "Sounds, Speeches, and Audio Devices," you can look for a particular item that has a yellow exclamation point beside it, and tell Windows to reinstall any missing drivers.
May 16, 2008 | Creative Labs Sound Blaster Live! 5.1...
Computers & Internet Logo
462 people viewed this question
David Payne
David Payne
