Question about Onkyo HT-S3300 Theater System
I have purchase onkyo 5.1 channel home theater but i am not able to hear sound from rear speaker when a and b speaker setting toggled and subwoofer effect also not getting
  • David Dunn
    David Dunn May 24, 2011
    Umm, have you looked in the manual?
    New Friend:
    Problem Solver:
  • 7 Answers
The 2 front speakers need to be connected to 2 big banana plug/screw connection marked Speakers A and not the last 2 color coded Push in style connectors,I had the same issue and this was the fix.Look at the quick setup guide closely,I did not look at it close enuff also.
Posted on Mar 24, 2013
SOURCE: Sound only out of 4 speakers
if I understand it correctly, you are telling me that even if you used the surround speakers there is still no sound coming out then it might be a faulty receiver and it needs to be taken back. Sorry but I can't, in good faith, tell you to open up your receiver and try and fix it.
Posted on Sep 03, 2007
SOURCE: Problem with Onkyo HT-SR700
Can you explain how you have the DVD player connected to the reciever and what the label on the jacks read on each.
Posted on Sep 16, 2007
SOURCE: Onkyo subwoofer not working
I fixed my subwoofer. The resistor at R16 (right next to the fuse) was the fried component. I removed it and replaced it with a 13K ohm 5 watt metal oxide resistor (from Mouser Electronics if not available locally). Works fine now. I got the solution and the circuit schematic from an audio hobbiest at diyAudio.com. This is, evidently, a fairly common problem.
Posted on Nov 19, 2007
SOURCE: Problem w/ surround sound for Onkyo HT-R430
You might have blow the fuse for those channels.
Posted on May 05, 2008
  • 21 Answers
SOURCE: Hi, I have an Onkyo Home Theater model HT S5200
It is a grounding issue.
Buy a $0.99 ground lifter plug from Wal-Mart.
Posted on Nov 19, 2010
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
I have just set up my onkyo 5305 i only have sound to front speakers have checked connection but im lost now in the settings
Onkyo are known for having 2 seperate connections for the rear speakers. 1 set for a surround sound, channel "A", and 1 set for seperate set a speakers, channel "B". check for the second set of connections. Also, your only gonna get sound out of the rear speakers thru surround sound mode when the unit actually sends singal. The sound is determined buy what setting you have the receiver set to.
Mar 06, 2011 | Onkyo HTP-102 System
I get no bass sound from sub-Woofer connected to Yamaha RX-V465
Check your speaker settings in Setup menu / Speaker Setup / Manual / Config (and then in this submenu also Equalizer).
In Config, choose where should low frequency sound go - subwoofer and/or front speakers (if they are big enough). The settings are: Bass Out: SWFR/Front/Both.
Also check Subwoofer phrase in SWFR Phase.
Check settings of all speakers, they can be Large / Small / None. If small, frequencies lower than "Crossover" settings, will not be put on them.
Nov 13, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Woofer assistance
You need to buy an active (self-amplified) subwoofer. Attach it to the Subwoofer Preout connector.
Go into Speaker Setup (SP SYS/SETUP Button near upper right side of Op Panel) and follow the prompts.
The parameter we're most interested in is the question "Subwoofer Yes" or "No".
Some guidance when selecting speaker parameters for the rest of the channels:
SMALL vs LARGE: This has nothing to do with size so much as it deals with the BASS handling capacity of the speakers. If you say SMALL, most low frequencies from those channels will be re-routed from them to the Subwoofer. If you say LARGE the channels will still get the low frequencies they deserve.
I imagine you would be able to answer LARGE for all of your speakers.
Even if you have all LARGE speakers defined the Sub will still have work to do as it will be dealt the LFE (Low Frequency Effects) from encoded movies and all or most of the content below certain frequencies.
Mar 27, 2009 | Onkyo TX-DS575 Receiver
Sound from 3 channels only
Hi, first of all did you verify with the manual if it is possible to run a testsignal through all 5 channels?
One of the most common problems in this case is the basic settings of the device. If you don't have the manual, mostly you can download them from manufacturers website. Chances are that for some reason the setting is set 3.0 stereo (also known as 3channel sound) which is always the 2 fronts and the centre speaker.
Best thing to do it is take a DVD with THX on it and run the THX setup, it will send test signal to all channels.
Jan 15, 2009 | Philips HTS3450 System
7.1 channel onkyo home theater -- no sound out of subwoofer
You might try different listening modes; Some modes (Direct, DTS, Dolby - though I'm not sure which, offhand) require a seperate LFE track for sound to be output by the subwoofer.
Nov 25, 2008 | Onkyo 630-Watt 7.1 Channel Home Theater...
Onkyo 875 - No sound
YOU ARE PROBABLY USING 5 SPEAKERS WITH OR WITHOUT A SUB, AND YOU CONNECTED THE REAR SPEAKERS TO THE REAR SPEAKER OUTPUTS. THEY WON'T WORK THIS WAY. RECONNECT THE REARS TO THE SURROUND SOUND SIDE SPEAKERS, AND RERUN THE AUDISY SETUP. THIS SHOULD TAKE CARE OF THE PROBLEM. YOU HAVE TO FOLLOW THE DIRECTIONS AND SET UP THE DVD INPUT, IT WON'T WORK RIGHT OUT OF THE BOX, TOO MANY VARIABLES.
JACK
I CAN'T GET MY 875 TO RECOGNIZE COMPONENT VIDEO SIGNALS, I GUESS I'M STUCK USING HDMI, AND COMPOSIT INPUTS.
Feb 25, 2008 | Audio Players & Recorders
you are in stereo mode which only uses the two front speakers, hit the surround sound button remote or hit the mode button and cycle through until you get to the Dolby II setting
Dec 31, 2007 | Onkyo HT-S680 System
Onkyo HT-S3300 Theater System Logo
276 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
