Question about Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA)
My m.j does not work . the connection to the computer is broken. how do I get a replacement?
    Sergeant:
  • 486 Answers
In this case it would be better if you take your system to some proper hardware shop so that they can fix it for you.
Posted on Nov 08, 2013
Wiredcontroller is broken..options how to connect manually
Depending on what you mean by broken, you could do one of two things: open it and clean it (sometimes dust can in theory get stuck and make it appear as if the controller is broken), or find another broken controller on ebay (for cheap) and replace any piece that could be physically broken. Ideally, there would be a working piece in that broken controller that you could use for your current controller.
Feb 03, 2018 | Computers & Internet
How to fix barbie girl on computer
"fix" implies it's broken.
To replace the broken version:
1. Connect your walkman to your computer. (if you're connected to the Internet, drivers should be installed automatically).
2. Open a window to view the mp3 files stored in your walkman.
3. Find the broken file, delete it and replace it with a working version.
If you meant "fix" as in "edit":
steps 1 & 2 are the same
3. Edit the file using audio editing software (such as AVS Audio Editor), then re-save the file.
May 10, 2014 | Sony Walkman NWZ-W202 MP3 Player
I am unable to use the ac adapter. the connector has broken off inside the adapter plug.
firstly check the power supply is working, if it is not, replace it with a new one. the next thing would be to replace the socket on the notebook, as this may be broken. it would have to have the solder connections checked or replaced with a new one.
i hope this was useful
Feb 28, 2013 | Asus Notebooks Asus Eee PC T101MT-BU37-BK...
Lacie hard drive safe rugged usb connection broken
The USB connector would need to be replaced and soldered, in order for the device to work, some computer stores carry them because they have many applications.
Apr 17, 2012 | LaCie Computers & Internet
Just got used champion c84e...how does computer work..should there be an electrical cord?
There is no electrical cord for this elliptical. It is powered by the runners motion. If the computer doesn't turn on when you start running, check the connections underneath it. If they are tight, you may need to replace the fuse. If after replacing the fuse and it still doesn't work, the computer may be broken.
Mar 06, 2011 | Computers & Internet
When i connect usb for photo frame into my computer is says device not recognized. then say reconect and if windows does not recognize replaces the device but i purchused two for chrismas presents and they...
Try connecting each device to a different computer, to see if the devices work at all.
Try every USB port on your computer, to see if you have one "bad" USB port.
Dec 24, 2010 | Computers & Internet
My screen is black nothing shows up 3 months old
-check the cables on the monitor and disconnect and reconnect it
-if issue still persist you can check the cable of the monitor for broken pins (vga cable the one with blue connector)
-if there are broken pins then the cable could be the problem
-if not you can try to connect the monitor to another computer or connect the computer to another monitor
-if you connect another monitor to the computer and it works fine then the first monitor you have is broken
-but if you connected the monitor to another computer and it works then it could be the video card of the computer.
Nov 25, 2010 | HP w19 19" LCD Monitor
Some of my keys stopped working, yet if I press down in the left center under the keyboard then they work,, how do I get them to work all the time?? Replace keyboard??
You have an "open circuit" somewhere inside your keyboard - it could be a bad solder connection or a broken wire. In either case I would recommend a new keyboard.
Oct 31, 2009 | HP Pavilion ze2000 Notebook
Hp 1210xi usb socket broken
that's on either mother board or system control board..requires a special soldering device..is it under warranty?
Jun 05, 2008 | HP PSC 1210 All-In-One InkJet Printer
Linksys SPA-2102 NA Analog VoIP Adapter (2) FXS, (2) RJ45 (SPA2102-NA) Logo
43 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
