Question about Samsung Heating & Cooling
Display error - E425 for model no - CH105EZM1C/SER cassette type unit.
2 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: model 238322100 ser cm4768086 type 111
Check the following.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Posted on Jun 22, 2009
Call for service error in Toshiba studio 160
Code Description C01 Main motor drive error C04 PFP main motor drive error C06 LCF feed motor error (DP2000/2500 series) C13 Cassette 1 error C14 Cassette 2 error C15 Cassette 3 error C16 Cassette 4 error (DP2000/2500 series) C18 LCF tray error (DP2000/2500 series) C19 LCF feed motor abnormal (DP2000/2500 series) C21 Carriage initialization error C25 Scanner unit watch dog error C26 Exposure lamp disconnection or peak detection error C38 Replaced process unit error C41 Abnormal thermistor or heater disconnection at power ON C43 Warming up mode after disconnection judgment, or abnormal thermistor after ready C44 Warming up mode after disconnection judgment, or heater abnormal after ready C45 Thermistor disconnection at the end part of heater C56 Communication error between PFC and main unit C57 Communication error between main unit and IPC (DP2000/2500 series)
May 22, 2011 | Toshiba E-Studio 160 All-In-One Laser...
P4 comes up what does it mean
Maximum customers not giving full details about a/c model and brand. With your limited statement, I try to solve the problem.
P4 Error detail Abnomarlity ofdrain sensor (DS)
Inspected unit Indoor.(Cassette type unit)
Dec 25, 2010 | Heating & Cooling
My jvc camcorder model GR D23Ek displayed remove cassette -error 03
Hello :
Error 03 is very common in the Mini-DV models. This problem can be defective reel tables, or it can also be a defective rotary encoder. You can expect to pay intermediate to major labor for this type of repair. Parts are nominal.
PLEASE DON'T FORGET TO RATE .
good luck .
Apr 09, 2010 | JVC GR-D23E Mini DV Digital Camcorder
Oven shuts off after being on for short period of time and f3 or f2 code appears. also the display sometimes goes off and on model # che9830bcb ser # 24430972qw
F3 error code usually means a faulty oven temperature sensor, a fairly easy part to replace.
However, with an intermittent display problem as well this could mean a bad connection or relay in the oven control unit, which a bit more complicated.
Jan 19, 2010 | Maytag Ovens
PLUG MISSING AT BACK FOR WIRES SER.NO. FBTR429796ES
The plug for the unit can be ordered through pioneer . you can simply call 1-800-pioneer and give them the model number & place the order.
Apr 15, 2009 | Pioneer KEH-P2030 Cassette Player
Panasonic casette air conditioner-display error temp 'CHECK'
Check that your water pump is working and not blocked up as the unit will keep swicthing off if it can not get rid of the water.
Nov 24, 2008 | Panasonic CW-C60RU Air Conditioner
Heating & Cooling Logo
113 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
