Question about PNY 4GB USB 2.0 Flash Drive - Grey/Black
My 8GB USB flash drive stop working suddenly. Icouldn't even format it. when i insert it to the computer there is no error and it seems to be detecting the drive but when i double click the drive icon the message is "The disk is not formatted. Do you want to format it now? YES NO"
  • sepehre_arya May 25, 2011
    When I want to format it as quick, the process start but at the end of process it says "windows can not complete formatting" and i can not format it as full by windows again. there is no important data on it to recover. Maybe i thinck it need formatting as low level
  • 336 Answers
To recover your 8gb usb flash drive need to formating just click YES quick format only select.then if you need data of usb need software recovery files.
Posted on May 24, 2011
When i insert my USB flash drive called sanDisk cruzer 8GB in the laptop,am told that i need to format the disk in drive G before i can use it,when i try to format it, it says that windows was unable
If there is any Media Error not possible to format the drive otherwise use the following method on Windows 7
Open a Administrator command Prompt and type the command one by one
1.list disk
you can find the avilable disk and note your USB Drive Disk Number
2.select disk 1 (change the number)
3.clean
4.create partition primary
5.format fs=ntfs quick
6.assign
if no problem in usb it will format your USB Drive
Apr 03, 2014 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a SanDisk Cruzer 8GB flash drive,previously it is ok but lately it suddenly broke down. the flash drive when inserted, it is recognised by windows and the autorun prompts. but after opening the...
There is a program called get data back. This will recover data from a readable flash drive. Even if you have to format the drive to stop the errors and make it readable to windows, you can still recover the data.
Aug 22, 2013 | SanDisk Computers & Internet
I got a sd 8gb memory card free with MTS USB modem and it just doesn't seem to work! i am able to transfer the files but unable to open. my phone is compatible with 32gb expandable memory and i al
I believe the phone will need to card to be FAT32 format and the card may be formatted as NTFS. Insert the SD card into a computer. In "Computer" note the drive letter. Lets use E: as an example. Open a command prompt and type format E: /FS:FAT32
That will format it to fat32. Now try in the phone.
Dec 27, 2012 | SanDisk 8GB microSDHC Memory Card with...
I can't seem to remove write protection from this disk to format it. It is and 8gb usb device. It tells me it's write protected whenever I try to fix it.
Try with my property click here , choose download - and download winsetup from usb.
Try format with this software ,
if still error, contact me.I will help you my friend.
Jun 16, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Unable to save delete or format datatraveler 8GB key. It also seem to have a virus which I have so far not been able to clean. Plese I need your help.
exactly the same thing has happened to be before, but I was able to solve the problem using Avira Anti-virus.
Here is what you have to do to get your flash drive working again;
Install Avira Anti virus on on your computer. If you don't have Avira anti-virus software, go to www.avira.com, on the Avira home page, you will see Free download. Click on the free download. Allow the software download on your computer. Go to the location where the software was download and click on the software to have it installed on your computer.
After the Avira nti-virus has been successfully or completely installed on your computer, insert the data-traveler 8GB into the USB port of your computer.
The moment the data-traveler 8GB is inserted, the Anti virus will pop out with a dialogue box alerting you about virus detected on the data-traveler 8GB.
Select 'Delete...", and the box might pop out over and over. Just keep selecting delete until the whole virus is deleted from the data-traveler 8GB and your flash will be okay.
You can format the data-traveler 8GB thereafter or right click on the data-traveler 8GB from 'My computer' and scan the drive with Avira anti virus.
This should fix the problem you are facing presently. But if it does not solve the problem, please let me know so that I can give the next step to taking.
Your sincerely.
Elect_Comp.
May 23, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computer can not find its capacity and can not be even formatted. i want it to its capacity back.
> cannot be formatted
It seems to be "broken" -- either physically or electronically.
Exercise the SanDisk warranty to get it replaced.
Oct 07, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Unable to format my SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Aug 20, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Card Cant Be Read
Same thing happened to me, after taking some pictures of a christening, connected to card reader, it wasn't recognised by card reader. I re-inserted it in camera and got card error, tried some softwares to extract pics but for nothing!!! I'm very dissatasfied!!
May 25, 2010 | SanDisk Ultra II 8GB Secure Digital High...
Sandisk Ultra 2 compact flash 8gb won't work in my camera (Olympus E-520), it says 'card full' & I am unable to format the card, it says 'card error'.
insert the card to a card reader then format it in the following way:-
right click my computer then menage then click disk menagement then right click on your card then click format. good luck.
Jan 09, 2010 | SanDisk Ultra II 8GB Secure Digital High...
8gb pny pendrive not working
Try to connect it to another usb . If it still does not see it do check disk with fix errors. I had such a problem many times and usually check disk helps.
Apr 18, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
PNY 4GB USB 2.0 Flash Drive - Grey/Black Logo
287 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
