Question about Scott Cycling
I have a Scott Proonly rear bearing is worn. How do I remove the old bearing from the housing. Is there a special tool and where do I get it from Thanks
    Brigadier General:
  • 8,546 Answers
Which bearing is that? There's the bottom bracket and the headset. Wheel bearing?
http://www.parktool.com/blog/repair-help/categories/bottom-brackets
http://www.parktool.com/blog/repair-help/categories/headset-service
http://www.parktool.com/blog/repair-help/categories/hub-service
There are many special tools for properly working on bikes. Park makes them all.
Posted on May 24, 2011
How to change the belt on dryer
CHANGING THE DRIVE BELT
1. Remove the top cover and the rear panel.
2. T720/780: Remove the external fan housing.
3. Remove the special tool.
4. Remove the belt from the belt pulley and take off the belt.
5. Feed the belt over the drum onto the motor shaft and over the belt pulley.
6. Install the special tool.
7. T720/780: Replace the external fan housing.
8. Replace the rear panel and top cover.
_____________________________________________________
REMOVING THE TOP COVER
1. Remove the three T20 screws at the rear of the top cover. (Keep the two star washers.)
2. Tilt the cover and pull it backwards.
25758001-gtkp3url2ghtdqenstp5bokb-1-0.jpg REMOVING THE REAR PANEL
1. Remove the top cover.
2. Unscrew the centering nut until the face of the nut is level with the end of the thread and knock out the bearing.
3. Fit the special tool (part no. 88 011 54) by fitting the tube end into one of the stamped out keyholes in the front rail. Lift the rear edge of the drum and press the drum edge onto the roller.
4. Remove the ground connection (yellow/green wire) from the input terminal block (see pages 8 and 9).
5. Take the cable bundle out of the cable clamp and pull the header block off its terminal pins.
6. Remove the wiring:
T700/T720: R1 a, R1 b, R1 13, R1 14, R1 34 on the contactor.
T760/T780: Ra, Rb, R13, R14, R34 on the contactor and F3 and F4 on the radio interference filter.
7. T720/T780: Remove the hoses to the water tank housing.
8. Remove the centering nut and the eight screws.
NOTE: Do not remove or loosen the screws around the heater housing or drum bearing.
9. T720/T780: Remove the three plastic screws at the lower part of the rear panel.
10. Lift off the rear panel.
25758001-gtkp3url2ghtdqenstp5bokb-1-5.jpg 25758001-gtkp3url2ghtdqenstp5bokb-1-20.jpg
25758001-gtkp3url2ghtdqenstp5bokb-1-27.jpg REMOVING THE EXTERNAL REAR FAN HOUSING
1. Remove the top cover and rear panel.
2. Unclip the external rear fan housing suction side.
3. Unscrew the 10 mm nut on the external rear fan wheel and remove it.
4. Lift the external rear fan housing motor side and pull it toward you.
Dado
Jun 23, 2015 | Asko T701 Electric Dryer
Rear wheel bearing replacement on a 2001 dodge ram 2wd 1500
Pull the rear axles, remove axle seal. There is a special bearing removal tool that attaches to a slide hammer. Insert tool thru center of bearing and use slide hammer to pull out. Use old bearing against new bearing and tap in with hammer
Mar 08, 2015 | Dodge Cars & Trucks
How to replace belt on asko t701 drier
1. Remove the top cover and the rear panel (see page 26).
2. T720/780: Remove the external fan housing (see page 32).
8. Remove the centering nut and the eight screws._____________________________________________________
Dado
Sep 22, 2014 | Asko T701 Electric Dryer
SPECIAL TOOLS NEEDED TO INSTALL A NEW REAR WHEEL BEARING ON A 2006 CHEVY IMPALA LTZ WITH ABS ?
none really, metric wrenches or sockets, a breaker bar, w jack and jack stands, flat blade screw driver, and a pair of needle nose pliers, to remove the drum holder to get at the wheel bearing assembly.
remove tire then locking washers, remove rotor, using breaker bar, loosen bolt then remove the abs pick up, it is a 10 mm socket, put out of the way, and then remove the bolts, you might have to use a hammer to get wheel bearing to come free from housing.
reverse the procedure to install
Jul 14, 2014 | 2006 Chevrolet Impala
How to replace rear wheel bearing on 1994 bmw 325i
3-Series (Except M3, M Roadster, M Coupe, 318ti & Z3)
1. Raise and support vehicle. Remove wheel(s).
2. Remove axle shaft. See appropriate AXLE SHAFTS article.
3. Remove brake disc. See BRAKE DISC .
4. Screw special tool (33 2 116) onto drive flange with wheel studs. Drive out drive flange with special tool (33 4 201/202/203). See Fig. 33.
5. If necessary, pull off bearing inner race using special tool (00 7 500) and a thrust piece. See Fig. 34.
6. It may be necessary to remove inner wheel bearing race with the following procedure:
  • Detach wheel bearing inner race with special tool (33 4 400) through groove in bearing inner race.
  • According to outside diameter of bearing inner race, use special tool 33 4 401 with: 33 4 405 for dia. 45-51 mm, 33 4 406 for dia. 50-55 mm and 33 4 407 for dia. 55-61 mm in groove. See Fig. 35.
  • Tension special tool 33 4 401 with wrenches 33 4 403 and 33 4 404 until it can still just be turned in groove. See Fig. 36 .
  • Screw in special tool 33 4 402. Detach inner bearing race.
7. Remove circlip. See Fig. 37 .
8. Remove wheel bearing with special tool 33 4 031/ 041/ 042/ 043/ 045. See Fig. 38 .
CAUTION: Do not reuse old wheel bearing.
9. Draw in new wheel bearing with special tool 33 4 041/ 042/ 043/ 047. For inner bearing race 42 mm use special tool 33 4 049 and for 39 mm use 33 4 046. See Fig. 39 .
10. Installation is reverse of removal.
11. Replace stretched or damaged circlip. Ensure correct seating.
12. Pull in drive flange using special tool 33 4 041/ 042/ 043/ 045/ 048. See Fig. 40 .
13. Install brake disc.
14. Install axle shaft.
Nov 12, 2010 | BMW 325 Cars & Trucks
How do you change the rear wheel bearings on a 2004 chevy express 1500 van?
Axle Shaft Bearing & Seal Removal & Installation To Remove:
  1. Raise and safely support the vehicle.
  2. Remove the axle shaft.
  3. If replacing only the seal, remove the seal using a suitable seal removal tool.
  4. If replacing the seal and bearing on the 8.6 inch axle, install the slide hammer and adapter behind the bearing and pull out the bearing and seal together.
  5. If replacing the rear axle shaft seal and the bearing on the 9.75 inch axle, install the J 29712 or equivalent bearing puller into the axle housing behind the axle bearing.
  6. Remove the axle shaft seal and the bearing by tightening the nut on the J 29712 bearing puller.
Use a slide hammer, bearing puller and adapter to remove the old axle bearing 88457g81.gif
To Install:
  1. Install the axle shaft bearing using a suitable size driver. Drive the bearing into the housing until the tool bottoms against the tube.
  2. Lubricate the seal lip and install the seal with a suitable seal driver. Make sure the seal is fully seated in the axle tube.
  3. Install the axle shaft.
  4. Fill the rear axle with the correct lubricant.
  5. Lower the vehicle.
Oct 18, 2010 | 2004 Chevrolet Express
Do i need a special tool to remove the rear wheel bearing on a 2000 chevy suburban # 1500?
yes, after the rear axle is removed you have to use a large slide hammer with a special attachment on the end to get it out and the proper bearing driver to install the new one they are a very tight press fit into the housing
Aug 20, 2010 | 2000 Chevrolet Suburban
How do i change out front wheel bearings
Compare to a rear wheel drive care, the bearings are totally different from the tapered style from the old days. Those where much easier to remove and don't require special tools. FWD bearings have high temp grease which is thicker and doesn't breakdown into a soupy state when it gets hot.
  • You'll need an air hammer and the correct sizes of metric sockets
  • You need to remove the CV joint nut which is torqued at least 120lbs psi on the spline part
  • You'll need a long 1/2" breaker bar for leverage
  • You'll also need a 1/2" torque wrench
  • At least a 10 ton hydraulic bench press and corresponding flanges to push out the old bearing
  • If you have a bearing tool you might get away without a press
  • Must have factory manual with torque specs
  • If you don't have all of the above mentioned tools then I'd suggest to forget the idea doing it on your own, you'll need tons of power just to start the bearing out of the wheel bearing housing (carrier).
Feb 17, 2010 | Toyota Avalon Cars & Trucks
Rear wheel bearing
SECTION 205-02B: Rear Drive Axle/Differential — Ford 8.8-Inch Ring Gear 2003 Mustang Workshop Manual IN-VEHICLE REPAIR Axle Shaft Removal
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
  1. Remove the rear brake disc (2C026). For additional information, refer to Section 206-04 .
  1. Remove the differential housing cover (4033) and drain the lubricant. For additional information, refer to Differential Housing Cover in this section.
  1. Remove the differential pinion shaft (4211).
    1. Remove the differential pinion shaft lock bolt (4241).
    1. Remove the differential pinion shaft.
  1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the axle shaft groove.
    Remove the U-washer (4N237).
    1. Push the axle shafts (4234) inboard.
    1. Remove the U-washer.
  1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Damage to the rear brake anti-lock sensor (2C190) may occur if it is not removed before the axle shaft.
    Carefully remove the rear brake anti-lock sensor. For additional information, refer to Section 206-09A .
  1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal.
Rear Wheel Bearing and Axle Shaft Oil Seal Removal
  1. Remove the axle shaft (4234). For additional information, refer to Axle Shaft in this section.
  1. NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged.
    Using the special tools, remove the rear wheel bearing and wheel bearing oil seal.
Installation
  1. Lubricate the new rear wheel bearing with the specified lubricant.
  1. Using the special tools, install the new rear wheel bearing.
  1. Lubricate the lip of the new wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. Using the special tools, install the new wheel bearing oil seal.
  1. Install the axle shaft. For additional information, refer to Axle Shaft in this section.
Installation
  1. Lubricate the lip of the wheel bearing oil seal
    Install the two axle shafts.
    Install the U-washer.
    1. Position the two U-washers on the button end of the axle shaft.
    1. Pull the axle shaft outward.
  1. NOTE: If a new pinion shaft lock bolt is unavailable, coat the threads with Threadlock and Sealer EOAZ-19554-AA or equivalent meeting Ford specification WSK-M2G351-A5 prior to installation.
    Install the differential pinion shaft.
    1. Align the hole in the differential pinion shaft with the case lock bolt hole.
    1. Install a new differential pinion shaft lock bolt.
  1. Install the differential housing cover and fill the rear axle with the specified lubrication. For additional information, refer to Differential Housing Cover in this section.
  1. Install the rear brake anti-lock sensor. For additional information, refer to Section 206-09A .
  1. Install the rear brakes. For additional information, refer to Section 206-04 .
  1. Install the tire and wheel assembly. For additional information, refer to Section 204-04 .
  1. Lower the vehicle.
Apr 10, 2009 | 2004 Ford GT
Replace left rear axle seal 1999 ford explorer
Axle Shaft Removal
  1. Remove the differential housing cover (4033).
    1. Loosen the bolts and drain the lubricant from the rear axle housing (4010).
    1. Remove the bolts.
    1. Remove the differential housing cover.
  1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Turning the differential case (4204) or an axle shaft (4234) with the differential pinion shaft (4211) removed will cause the differential pinion gears (4215) to fall out of the assembly and damage the components.
    1. Remove the differential pinion shaft lock bolt.
  2. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the U-washer groove.
  3. Remove the U-washer (4N237).
  4. Push the axle shaft inboard.
  5. Remove the U-washer.
Reinstall the differential pinion shaft.
  1. Install the differential pinion shaft.
  2. Install the differential pinion shaft lock bolt finger-tight.
  3. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal (1177).
Seal Removal
  1. Remove the axle shaft (4334). For additional information, refer to Axle Shaft in this section.
  1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the wheel bearing oil seal (1177) by itself. Always remove the rear wheel bearing (1225) and the inner wheel bearing oil seal at the same time.
    NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged with foreign material.
    Using the special tools, remove the rear wheel bearing and wheel bearing oil seal together.
6c7eb46.gif Installation
  1. Lubricate the new rear wheel bearing.
    • For 4.0L SOHC and 4.0L EI with limited slip rear axles and 5.0L vehicles, use SAE 75W-140 High Performance Rear Axle Lubricant F1TZ-19580-B or equivalent meeting Ford specification WSL-M2C192-A.
    • For 4.0L SOHC and 4.0L EI with conventional rear axles, use SAE 80W-90 Premium Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Using the special tools, install the rear wheel bearing.
  1. Using the special tools, install the wheel bearing oil seal.
Feb 22, 2009 | 1999 Isuzu Rodeo
Cycling Logo
278 people viewed this question
Top Scott Cycling Experts
John Egan
John Egan
Are you a Scott Cycling Expert? Answer questions, earn points and help others
