The light on the tv is on, when you press the button the tv should come on but it doesnt. I used to have to unplug the tv then press the button for it to come on. Now it doesnt come on at all? Do you think this is would be cheap to repair?
  • 2,098 Answers
Hi lady_dancer,
This is an indication ofout-of-regulationin the power supply section. This was cause byleaky/dried electrolytic capacitorin that section. It willdroppedthe supply from normal voltage and will disable the unit.It needs a little warm-up to make itself stable but the symptom will get worst until the unit will not even power up. Sometimes it has abulged/domeat the top but not all, it is better that you have acapacitor checker/testerto determine its condition. Your unit will back to normal again if the leaky/dried capacitor is isolated.
You may replaced the entire power supply board if you can't troubleshoot the unit yourself or look for a qualified tv technician to isolate the faulty capacitor.
Also check if your unit is under warranty /extended warranty, avail it because the manufacturer of your unit will fix it for free. Don't open the back panel, this will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 24, 2011
Wont power on
some tv's always have standby light on, even iff you turn off by tv button. solution 1: with light on, press a number on remote. solution 2: with light on press stand-by button on remote. solution 3: with light on push the 'on' button on the tv set. solution 4: unplug tv set, wait a few seconds then plug back in, if no light then turn on tv using button on the set, and then channel number.
Jun 25, 2012 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
I have switched the TV off at the switch. When I have turned it on again the picture doesnt appear and the red light just keeps flashing.
First you need to try turn it on using the remote, by pressing any of the number buttons on the remote. If it does the same, then you go ahead to press the power button from the television to see if it comes on.
If either of them does not turn on the television, then you will have to reset the television. To do so, unplug the television for some minutes, lets say about 5 minutes, then you plug it back on, then press and hold the power button for about 15-30 seconds and it will restart the television.
That should help start up the television.
Hope this helped.
Goodluck
Elect_Comp
Jun 27, 2011 | Panasonic Televison & Video
I have a Proscan 62 inch ,rear projection TV, we plugged it in after moving it in (came strapped down on a flat deck truck) driver said it was a bit of a rough ride........it makes a small sound when...
Your problem is most likely in the main power supply or possibly in the sweep power supply. Without the know how and a service manual, you could turn a minor problem into a mojor headach.. LOL Play it safe and invest in a pro to assist you in this repair. The 'rough' ride might have loosen some connections.
Jun 08, 2011 | Proscan PS52800 52" Rear Projection...
Standby light flasher red and green but the tv dont come on
Press and hold the power button for about 30 seconds. Tv will return to normal.
If that doesnt work unplug for about 2 mins.
GOOD LUCK,
CNBY
Jun 03, 2010 | LG RZ20LZ50 20 in. EDTV-Ready LCD...
When I turn on the TV the blue indicator light comes on but there is no display, then the blue light starts blinking.
The following steps should be able to correct the problem:
1) Unplug the TV or remove AC power from the TV
2) Count to ten and then plug in the TV
3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel
4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons.
5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons.
6) The TV’s lower left Blue Power LED will come ON.
7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time.
8) Press the [Mute] button on the TV remote twice
9) Unplug the TV or remove AC power
10) Count to ten and plug the TV in
11) The TV power should automatically come ON and the blue power LED with be ON
12) Wait 40 seconds and the TV picture should appear
13) You can now continue using your TV.
14) If the picture does not appear, power on the TV manually:
· If the LED begins flashing, unplug and power ON a second time.
· If the LED begins flashing again, power ON the TV without unplugging
If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you.
If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
1) Press the [Menu] button on the remote control.
2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote
3) Scroll down to "system info" and select [OK] button on the remote
Dec 19, 2009 | JVC Televison & Video
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Sony bravia tv
Solution is simple....
First, unplug power cable from the back of your TV. You will notice the flashing light is still flashing. Don't worry, go to the Second step.
Second, keep pressing on the POWER button, located on the panel at the top of your TV, to shut off your TV. This will stop the flashing light from appearing.
Third, Plug the power cable back onto your TV
Fourth, press the POWER botton ONCE, using the same button used in the Second step to turn your TV back on.
Fifth, you will see the POWER light comes on, as normal.
Sixth, using your remote control, press the green button to turn on. Your TV should work as normal.
Jun 08, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
