Question about Olympus FE-20 Digital Camera
Hello!Yesterday i was taking picture of nature with my Olympus camera,after that i transfered them onto my computer using usb cable.Today i can't take any picture because it says on screen ''WRITE PROTECT''.When i pressed the button to check and see my pictures on camera in the upper right corner showed a key.What happened to my camera and how to solve the problem?Help! Stefan
  • stefan_drobn May 25, 2011
    Hi heatman101,
    Thanks for the tip u wrote but when i took out my SDCard i didn't find any switch like you mention in tip so there must be some other way to unlock this.And i am pretty much confused how did it lock itself if nobody touch it.
    Stefan
  • 43,501 Answers
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards. If youare getting a memory card locked message then check this out.
How to UnlockSD Card heatman101
Posted on May 24, 2011
How to put photos from my camera onto my hp laptop
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jun 07, 2012 | Olympus Cameras
Tip
Get Photo's Off of a Memory Card
With digital camera's people want to get photo's off of the camera and onto the computer. However many camera's use unique USB cables or need specific drivers in order to have the files transferred off of the camera. It's important to note that all camera's save the images to a memory card that's in the camera, it's usually in the same compartment as the battery. What you can buy is a USB card reader, they either plug directly into the computer or use a standard USB cable to connect. You take the memory card out of the camera and put it into the card reader. Then you're able to transfer all your pictures without any special cable or driver. This method is preferable because a card reader is inexpensive and you can get types that will read many different types of cards.
on May 11, 2011 | Cameras
How do I transfer my pictures from my camera to computer? I have a red Olympus tough TG 310 camera.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 16, 2012 | Olympus TOUGH TG-310 Digital Camera
Have "olympus sp 800uz" and
1. Put the SD card into the computers cardreader.
2. Connect the camera through USB with the computer .
3. Copy the pictures.
If you have trouble with the SD card:
1. Copy all the pictures to the computer.
2. Format the sd card in the camera.
3. Copy the pictures back onto the sd card.
Aug 31, 2011 | Olympus SP800UZ Digital Camera
I cannot put my pictures and videos onto my computer using the iB menu that the camera has!!!!!!! Every time I tell the program to transfer the images to my computer, it says "No Media to...
Welcome to Fixya
Try the alternate way of transferring the pictures to your computer instead of using cable.
To download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer. Once the card is plugged in, it will appear to your computer as a removable drive. Just drag&drop pictures from the card to the computer's hard drive, the same way you copy any other files.
Thank you for using Fixya!
Apr 07, 2011 | Olympus SP600UZ Digital Camera
Hello, My olympus sp-500uz has more and more problems with connecting to my PC. Some USB ports don't work any more(front connection) and the back connection works sometimes but getting my pictures on the...
Many people find it more convenient to just take the memory card out of the camera and put it in a card reader, especially now that these readers are built into computers and printers. That would be a "work around" for your problem.
As to the problem itself, a bad cable might be the cause, with damaged connectors. That is something you can replace cheaply (search Amazon on "Olympus SP-500 USB") so it won't be expensive to check it out.
Slow transfer might be due to using an older standard USB port. The first USBs were much slower than USB2 widely used now. Some older computers only have the earlier standard, and some have a mix of old and new.
Nov 19, 2010 | Olympus SP-500 UZ Digital Camera
Can i charge an Olympus fe-4000 with a usb cable connected to my computer?
No. The camera does not incorporate any charging circuitry. You have to use the supplied battery charger to charge the battery. The USB cable is strictly for transferring pictures and videos to the computer.
Jun 28, 2010 | Olympus Cameras
I can't get my Sp-55OUZ digital camera to transfer pictures onto my Windows XP computer. When i use the USB cable it makes the connecting "beep" but nothing shows up on my computer screen.
Take you card out and put it in the printer slot for your card. Or you can get the Olympus USB card holder and stick it into any USB port.
Apr 13, 2008 | Cameras
Olympus Fe-280
rotate the knob or pressing to view pictures plug in USB cable sound beep suddenly message appear by click to transfer picture to computer.just follw instrucion.
Jan 04, 2008 | Olympus FE-280 Digital Camera
Olympus D-370 picture transferring help
Have you tried another USB cord? If your camera had software, you might want to do that over again.
Sep 12, 2005 | Olympus Camedia D-370 Digital Camera
Olympus FE-20 Digital Camera Logo
156 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
