Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Door won't open slowly
On my Kenmore elite, on opening, suddenly the door just slams to the bottom without the gradual opening that it had before.   And you have to really close it -- previously it would stay ajar 2 or 3 inches but now it will open all the way.  Whatever was holding the door up and not in the down position is now kerplooie.  Any suggestions?
  • acastille Sep 06, 2008
    Our diswasher's door has also lost tension to hold it into place when opened. The heavy door falls into the open position, which can be hazardous for any person's leg in the way of the door when it is let go. My husband found a web site that stated that plastic clips were used on the door to hold the spings in place and these frequently break. Supposedly you can fix this yourself by using metal papercips to replace the plastic clips. I am searching for more specific instructions on how to access the springs. Any help is appreciated.
    Novelist:
  • 171 Answers
Hi barrianne,
I'm Harvey the Master Plumber.
You're asking: On my Kenmore elite, on opening, suddenly the door just slams to the bottom without the gradual opening that it had before. And you have to really close it -- previously it would stay ajar 2 or 3 inches but now it will open all the way. Whatever was holding the door up and not in the down position is now kerplooie. Any suggestions?
You're not alone! This is very common. It is usually easy to repair if you have the technical skill and tools to remove the d/w to allow access to the springs on each side and properly reinstall. I don't recomend it to the average homeowner.You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
The code f-DL displays whn I try to start the machine . I was thinking the door lock was jambed so I used a flat tip screw driver to jog the lock. The problem now is the lock is now locked and won't...
Remove the screws attaching the bottom flange of the lower front panel to the machine cabinet then pull the panel down and off. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side. Locate the tear-drop shaped tab then gently pull it down until a click is heard.
You can also remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel. Pull down gently on the release tab until a click is heard.
The FdL code indicates a door lock failure and you need to replace the door lock/switch assembly if the problem persists after resetting the door lock. Click on the link below for the details of the procedure.
Kenmore Elite and Whirlpool Duet Error Code FdL
Jul 16, 2011 | Kenmore Elite 45986 Front Load Washer
The door is locked and won't open; how do i unlock it manually?
unplug it,remove the bottom panel,stick your hand up where the door lock assy. is and on the bottom of the door lock assy. there is a plastic wire that releases the door manually,grab it and pull down and the door will release.
Jul 10, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he washer lock light. cannot open
You can manually Unlock the door Lock System
1. Unplug washer or disconnect power.
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is heard.
6. The door may be opened.
Thank you !!
May 31, 2010 | Kenmore Elite 45986 Front Load Washer
Alarm no longer sounds when fridge door is open
Chances are that you will have to replace the buzzer. That part is available at Sears Direct. J
May 28, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
It won;t power up at all, clothes... Solve It won;t power up at all, clothes are locked inside, no lights on the panel. Plug in is working, I... (More) It won;t power up at all, clothes are locked inside,...
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2009 | Kenmore HE2 Plus Front Load Washer
Bell wont stop ringing
Thankyou,
Bonjour, dearest Sir/Madamme, it would be an honor to help you out, the bell is a door open and close alert system in the Elite. They are usually activated with time. On the hinges on the doors, there are sometimes tilt switches, the tell the circuit system when to alert, as soon as the door is open some count time, if the time is prolonged, and the switches are open, (that would mean the door is open as well). They activate. I would check the door hing, a swith could be open/closed depending on the format of operation.
Thankyou, :)
Jun 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer door not sealing
replace the seals and / or have the hinge adjusted
May 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Front Load washer with dl F error code.
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened.
You're gonna rate me..............?
Apr 09, 2009 | Kenmore Elite 45986 Front Load Washer
Dryer won't start unless I slam the door
Not normal. Check door switch. As a test you can jump it out to see if the dryer works then. if that does not help then , I i would consider replacing the starter switch.
Jan 08, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
158 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
