Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Water remains in drawer where comfort goes - Hotpoint Aquarius WD640 Front Load Washer/Dryer
  • 4 Answers
Take it easy
Posted on May 24, 2011
How can I open detergent drawer, opens about 20mm & won't come out any further
Pull the drawer out as far as it goes then lift it up and pull it out completely. It may be stacked due to detergent remainings.
So, you should clean the drawer with a soft brush under warm running water. Do not put the drawer into a dishwasher!
Replace the drawer by tilting it into position.
Hope it helps.
Jun 08, 2015 | Asko W6021 Front Load Washer
Hi, I have a Saeco Magic Comfort Plus. When I press the button to brew coffee, the coffee is spilling into the dregdrawer rather than thru the spout for the coffee. It's not water, but actual coffee is...
Hi
Sounds like your thumbscrew is getting stripped. Its the same for all the older machines.
http://www.fixya.com/support/t2927107-lttle_filter_disk_plastic_rod
If its only partially stripped it slips up and allows the water to enter the brew head pocket where the thumbscrew is and the spill over into the dredge drawer. Check the brew head for water.
Aug 14, 2011 | Saeco Magic Comfort Plus Espresso Machine
The fabric softener drawer on my hotpoint hd420 is not draining. At the end of a wash the fabric softener drawer remains for of water. Can you advise?
It is not that unusual to find some plain water remaining- has the softener gone OK?
If not here is just a quick POSSIBLE (1st) solution if you have not tried it already-
Completely slide out the drawer - normally made possible by pressing down the plastic flap at the backend of the softener part of the drawer - as it is normally in the middle.
You may find 'gunge' made up of washing powder (if you use powder of course!) and softener combined in the tube that the softener should syphon into. Wash out with plenty of water!
I do this to ours fairly frequently.
Hope this helps.
Jan 22, 2011 | Washing Machines
The top drawer started getting very loud - maybe the water pump? Now it looks as if no water is getting into the drawer so dishes remain dirty. The bottom works fine, and is not loud when running.
Yes it is likely the pump rotor is seized. I am assuming the water goes in to the drawer but does not get moved around by the washer arm. This is the function of the rotor. This rotor also acts as a drain pump in the drain cycle.
Sep 19, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
The wash cycle starts with a 5 second delivery of water then stop
SOUNDS LIKE YOURE INLET VALVE HAS FAILED IF YOURE MACHINE IS COLD FILL ONLY IT WILL ONLY WORK ON ONE PART OF THE CYCLE ALTHOUGH IT HAS ONLY COLD FILL THERE ARE 2 VALVES SHARING SAME BODY,WILL NEED CHANGING
Aug 11, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Whirlpool Duet frontloader washer's dispenser stays filled
I had a similar problem, but mine was with the detergent side. I removed the top of the washer and had to clean the dial that advances to let the cyle of dispensing continue. It worked, but now the machine shakes and I am told is 'unbalanced'
Jan 16, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Water remains in detergent drawer
bpkaplan - did you find a solutiion? I have the exact same problem with my LG Tromm WM2477HW front load washing machine. It is about 2 1/2 years old.
Nov 24, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Zanussi zwf1631 w
there just one hole in the comfort part of the drawer is that clear,it has to be that.did you take out the drawer to clean
Oct 19, 2008 | Zanussi ZWF1440 Front Load Washer
Dregs Drawer filling up with water
If this comes into the dregs drawer then you have to look at your brewing unit, if it comes to the drip tray, then it´s normal
Jul 05, 2008 | Saeco Magic Comfort Plus Espresso Machine
Frigidare Front Load Washer dispenser drawer wont drain.
I think you have something stuck in the fill hose.. Remove the top two or three screws in the back.. then pull out the hose that goes to the tub. I bet you will have something in there.. most common is the inside liner to a bleach cap..let me knowif this it it... krazytech
Sep 08, 2007 | Frigidaire GLTF2940ES Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
