Question about Cell Phones
I need to be able to reset a pre-dial number on a Telemate PTC202 phone.
  • 1 more comment
  • coleman_fami May 27, 2011
    I have sent instructions of what I require and you do not resond with the correct model information. I am very disappointed.
  • coleman_fami May 31, 2011
    Thanks for your attempt to assist. I have now had a telecoms technician come in and do the change.
    The manual you supplied is also not the model required.
  • 3,083 Answers
The closet manual I could find to your model is the following one:
http://www.portrobinson.net.nz/manuals/Telemate_TE1208PM.pdf
Page 17 and 18 have information about the phone book operation.
Good luck, and hope this helps.
Posted on May 28, 2011
  • 2,069 Answers
If you don't have a user guide, you may get a manual guide here.
hope that assists.
Posted on May 24, 2011
How to run a report on a fax machine?
To run the auto dial and speed dial report you need to do the following:
Press Menu, 5, 2, then Start. The display will prompt you to the correct numbers. This will give you a list of pre-programmed numbers.
Jul 15, 2014 | Brother MFC-8220 Fax
Telemate Phones Manuals
TRY HERE
http://www.telemate.net/products/telemate/pdf/telemate_first_steps_guide.pdf
Nov 03, 2013 | Lands Phones
I HAVE A DECT 1588 SERIES DIGITAL PHONE SET.IT CAME WITH A USERS GUIDE.I'VE ENTERED ALL THE LOCAL AND LONG-DISTANCE NUMBERS.NEEDED! THE GUIDE DOESN'T DIRECT A WAY TO ENTER THE NUMBERS ON MY...
The guide doesn't indicate this as there is no other way to do so.
You could always I guess program in and put the 800# & Digit, under a "Speed Dial" key, then at least one would only have to enter the 10 digit PIN number, after pressing the speed dial.
Jul 11, 2011 | Uniden Cell Phones
I DON'T know what is initial programming is?
initial programming occurs when your phone needs a second roaming based and if you accidentally change the NAM settings of your phone to NAM2. the default NAM settings of your phone is NAM1.
Jul 01, 2009 | Samsung Glyde SCH-u940 Cellular Phone
Vu 204..new phone, speed dial does not work, goes to verizon wireless message which says call cannot be completed as dialed. Checked numbers they are OK, also happens which #1 for speed dial of *86 which...
I had the same problem and found that the speed dial feature in "settings" is not turned on by default even though voice mail number is pre-programed into the speed speed list. Go to "Settings & Tools/Call Settings/One Touch Dial" and turn the option on.
Cheers,
Don Devine
Mar 30, 2009 | Motorola Mobility VU204 Cell Phone
Use call phones through voip321
It took me a while to figure out but here is how I am able to dial out from skype to a hardline to a person not in my skype contact. Simply start to dial the number (not from the talk button!!!) then instead of hitting the talk button to dial, hit the skype button on the bottom left hand side. I also have to dial 001 then the phone number. Hope this works for you too. good luck.
Sep 25, 2008 | Philips DECT VOIP-321 cordless telephone
User Manual for Telemate 1209DP
the nearest manual I found is
when looking for a manual for my Telemate 2000+2 set of three cordless.
Hope this helps
redearsau@nospamYAHOO.nospam.com
Apr 15, 2008 | Lands Phones
RCA Model 25204 2 line speakerphone corded with call waiting caller ID
As bsmither said, how voice mail is accessed is very dependent on your phone company and how they've set things up. They would be the best place to ask about any problems you're having there.
As for programming the voice mail buttons on the 25204, I was confused by that one as well until I finally figured it out. Specializations aside, they're just speed dial buttons, and are programmed in exactly the same way as the ones along the right side of the phone. RCA could have documented that detail better than they did.
In my case, with Vonage, I just programmed the buttons with the numbers for the lines that they're associated with. When they dial and I'm connected to the voice mail system, I'm prompted for my VM password, which I then enter manually.
Jan 30, 2008 | RCA 25414RE3 Corded Phone
Pre-set dial numbers
Pick up the handset / handsfree button, hit the SET/SAVE key, punch in the entire phone number you wish to program to speed-dial, hit the SET/SAVE key again, hit the speed dial key you want to save to (0-9). To actually use the speed-dial key once set, you have to pick up the handset / handsfree, hit the AC key followed by your speed dial (0-9) I know this seems unusual and you have to do it relatively quick, but it's the only way that works properly on this phone unit. Cheers!
Mar 31, 2007 | Innovage 69420210126 Phone
Cell Phones Logo
37 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
