Question about Cell Phones
I phone Hi, I have an i phone and it has been set back to the factory setting which means i can only get emergeny phone calls, NOTHING ELSE. I have purchased and down loaded ILiberty which jailbreaks and unlocks the phone, i have also uninstalled the new version of I Tunes and reintalled the 1.1.4 version,. The problem i am having is once i have conected the phone to mt L-Top i tunes goes through all the set up, but at the end it comes up with THE I PHONE CANNOT BE USED WITH I TUNES BECAUSE THE INFORMATION REQUIRED FOR ACTIVATION COULD NOT BE OBTAINED FROM THE I PHONE....... i am well lost...
  • swanny38 Aug 15, 2008
    i am using a T-Mobile, when i got the phone it was unlocked
    do u have a link that i can get to download and install firmwear 1.1.4
    Master:
  • 521 Answers
Iphone is having a problem.get it reset at service center with proper reset code.or your phone will be of no use as it becomes old, its memory will be corrupted.and if that time you connect it to your computer it will produce viruses and it will also be affected. it better to take it to the service center to get it properly reset.it is not a major problem.get it solved quickly.at now it will not be too costly to get it repaired.thanks. keep me updated.
Posted on Aug 15, 2008
  • Cell Phones Master
  • 6,487 Answers
Try checking this link for some steps that you can follow http://iphone.unlock.no/
Hope that helps........
  • Mark Gil
    Mark Gil Aug 15, 2008
    You can go to this link http://www.ziphone.org/ and alos check the first link that I gave you for the complete steps to unlock this Iphone..
    Master:
  • 848 Answers
What sim card do you have in your iPhone......
  • 19,396 Answers
You need to bind the Iphone to the computer you are using.
I need to know how to take my SGH A877 out of emergeny calls only. I got the unlock code from at&t but I do not know how to unlock it now.
hi there are many online providers found that render codes to unlock .to purchase codes visit onlinegsmunlock here they send you codes along with the instruction guide about how to enter the codes in your mobile .
Jan 31, 2012 | Samsung SGH-A877 Impression Cell Phone
Ican call out but calls
Reset the phone to the factory settings
Jun 09, 2008 | Lands Phones
How to formate my uphone 3g and original factory settings
You don't format it to do that. What you do is...
1. Tap Settings
2. Locate General and tap
3. Scroll down to the bottom and find Reset, and tap
4. When it comes up. You can choose either Reset All Settings -or- Erase All Content and Settings.
4a - Reset Settings will usually keep all your pics, apps, and songs and just reset it back to factory.
4b - Will delete the entire phone and put it back to the way it came out of the box the day it was purchased
Meaning you'll most likely have to resync it with itunes and go through all that set up process.
Aug 19, 2011 | Apple iPhone 3G
Sir when i play songs...write msg...or dial the call...after 2mints gone the screen gone to white.and song , msg and call is disconnected.or close..give me the solution..i am very upset
hi, i think two things is causing this,
1. it could be that the phone is infected with virus, so i would advice you to scan your phone for virus.
2. you could equally try to set your phone back to factory setting but please NOTE: IF YOU ARE SETTING YOUR PHONE BACK TO FACTORY SETTING, MAKE SURE YOU BACK-UP ALL YOUR CONTACTS, MESSAGES AND ANY APPLICATION YOU SAVED ON THE PHONE MEMORY to avoid lossing them after restoring to factory settings.
cheers
Feb 16, 2011 | Nokia 5220 XpressMusic Cellular Phone
My "brake" light turned on but my emergeny brake is not on and my cruise control stopped working at the same time. What does this mean?
Check your brake fluid level. Check brake lights. If the cruise sees any sign that you are trying to slow down. ie... any brake input. It will not allow you to set cruise.
May 20, 2010 | 1994 Toyota Camry
I had purchase a new nokia 1650 wont ring or vibrate
just fomat your phone first then try to change your tone settings
Mar 11, 2010 | Nokia 1650 Cell Phone
Configuration/browseing settings
Never configure it manually !
That means there are many settings are already saved in your Nokia device . Just discard them and try again.
If you couldn't discard them here is another solution :
Just restore factory settings and I'm sure that you'll solve the problem .To restore factory settings here is the way: Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no 3 key on keypad and then press the power on/off to swtich on the phone.
Remember, do not let go the 3 keys press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
then here is what to do :
Just call your service provider support center and they'll help you for sure . don't try it by yourself . let them help you . they are the only ones , who can help you correctly .
your rating is very important for me , that's why I've helped you .
good luck .
Mar 06, 2009 | Nokia 3110 Cellular Phone
Nokia 6310i
Hi ahve you tried looking under the settings the profile settings then their should be an option for handsfree device try selecting this profile and see if that makes a differance.
If not the check the contacts on bottom of phone that connects to the craddle check their clean and not coroded also check the cradle connections make sure their is nothing like a bit of paper or bent pin anything that could cause their to be loss of conection
Mar 30, 2008 | Nokia 6310i
What is setting the pc back to factory settings mean?
2 WAYS
Restore default factory settings in setup - Only recover the seetings of your motherboard (date and time, pc health, etc)
Restore Software factory defaults - All hard drive is reinstalled, original software of Dell. Programs like MS Office, all of your data have to be reinserted in the computer.
I didnt understand the "over the phone".
See ya
Dec 18, 2007 | Dell OptiPlex GX260 PC Desktop
Sony ericssion k800i
If i were you id restore factory settings. This means that your phones settings will go to default. and this will fix the Language problem and the Call lock. you can acces the factory settings by clicking settings and then restore factory settings most likely there will be a code and the code will be 1234 or 12345 or something similar.
Sep 10, 2007 | Sony Ericsson K800i Cellular Phone
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
