Question about Panasonic KX TG1000N Cordless Phone
I have KX tg 1000n. The handset shows c533 and the green light is on. Otherwise the phone is dead. Solution?
Panasonic phone#KX-TG-63215 manual
You may download a copy of the KX-TG6321S manual at http://service.us.panasonic.com/OPERMANPDF/KXTG6311.PDF
Battery information is on page 6.
The KX-TGA630 handsets use two rechargeable AAA batteries, which should be available at just about any department, electronics, or office-supply store.
Jan 02, 2014 | Panasonic KXTPA50 Phone
Can I register a panasonic kx-tg55438 handset to a kx-tg5622 base
No, The kx-tg 5622 uses only the kx-tga560 (2 of them) for its cordless sets
Jan 07, 2010 | Panasonic KX-TG5622 Phone
Panasonic CORDLESS
1st check that the charger is plugged and energized. It should light up when dropping a hanset into the craddle.
2nd Check that the batteries are connected properly inside the handset and that they have the full voltage. Try 1st step again
Oct 14, 2009 | Panasonic KX-TG1033S Cordless Phone
I have the kx-tg 4500 4 line base unit phone. Line one flashes but does not ring or display caller. The other lines work fine. The handsets show no activity ie they don't even flash if a call comes in on...
I had the same problem once, turned off the base unit from power cord and the phone line and all connected handset units, then turned it back on & it worked.
Aug 05, 2009 | Panasonic KX-TG4500 Phone
No ringer sound panasonic KX - TG 7200 BX
not that I am aware of . usually just buy a new phone and be done with the non functioning one .
Jan 16, 2009 | Panasonic KX-TGA101S Cordless Handset
Panasonic KX-TG1100
yes!
sorry, it seems that they have no manual for this model base online yet. however, the procedure to reset handset numbers for the 1000N may work for you. there is a 15 digit number on the base unit. type that into the handset using the book (was on page 54 for the 1000n) for your 1100 and see if that will register the other 1100 to your base.
Nov 26, 2008 | Panasonic KX-TG1100 Cordless Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Panasonic KX TG1000N Cordless Phone Logo
90 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
