Question about Yamaha PDX60BL iPod iPhone Dock Speaker System Black
Hi, I have been using iphone4 with the Yamaha dock system. Recently, I have the error "Accessory not recognised by iphone...". What could be the reason and how should I resolve the issue? Thanks.
  • 2,069 Answers
Could be dirt or some other particles that are blocking part of the interface jack. have the two cleaned well then if problem persists, update your iphone to the latest firmware available. you may post back for a followup.
Posted on May 24, 2011
Wont charge iphone
please ckeck connectors for power and cleanthem---unit probably on its way out
Mar 28, 2014 | JVC NX-PN10 Compact Component System -...
IPhone not recognised when docked
Try a different charging dock make sure it puts out the same volts as the iphone has
Oct 03, 2017 | Philips Audio Players & Recorders
Iphone4 will not playing music through docking station Sony XDR-DS12IP... Iphone was working with system perfectly until sunday? still manages to charge iphone ? Iphone message iphone not configured...
first return sony and get ihome because sony is bad at docky station(not affending ps) or you can do is take it where you got it and bring the ios deviece and get it checked if it works congrauts if it doesn`t BUY IHOME.
Aug 23, 2011 | Sony HD Radio and Dock Docking Station,...
When my iphone 4 3G is docked in my Bose Sound Dock, it says "This accessory is not optimized for this iPhone". I'm confused because this Bose is made to dock iPhones. Plus there is no sound....
Unfortunately, the iphone 4 is not the same as the previous models of iphones. I have run into problems with similar products where the iphone 4 will not work, but the 3rd gen will. If you know someone else that has an iphone 4, test theirs to verify that its not a problem with your phone. There is a high possibility that your sound dock is not compatible with the i4.
Jan 07, 2011 | Audio Players & Recorders
This comes up on my iPhone ALL THE TIME and is interfering with my sounds. It thinks that it is still hooked into the stereo. It doesnt stop saying THIS message and it is getting annoying!!! Please...
Replace your dock connector board. If you have water damage, then clean your circuit board with isopropyl alcohol. Of course, you should talk to the genius bar first.
Dec 29, 2010 | Apple iPhone 3G
Iphone4 new, "this accessory
You could try blowing some compressed air at the doc connector at the bottom of the iphone . There could be some dust or small particles confusing your phone into thinking something is connected.
THANK YOU
Dec 20, 2010 | Apple iPhone Smartphone
When I plug my iphone 3gs in to my sony srs-gu10ip sound dock it says this accessory is not optimized for this iphone. You may experience noise cause by cellular interference and a decrease in cellular...
I have experienced the exact same problem, all of a sudden both my iphones stopped working with my Sony SRS-GU10iP. Error message Accessory Not optimized For iphone
Dec 17, 2010 | Computers & Internet
I have a Sonic Integrity Tube Pod (Tube Pod) and need to know how to make it work with iphone 4. I can play the iphone 4 only through the earphone jack at this point. The iphone 4 however can sit on the...
It is normal to get incompatible devie message when you attach your iphone to dock because you don't use apple dock. I have 5 different brand portable speakers, charging docks. And all of them give same message when i attach my iphone 4 to dock. When you press "ok" on your iphone screen, it should start to play your songs. You don't need to use your iphone at airplane mode.
You may have problem with your iphone dock conncector cable pins. If audio related pins are damaged, you can not use any external iphone speakers with your iphone4. In order to test your sonic integrity tube pod; try another ipod or iphone on its dock. If it gives same result, you may need to change dock connector unit on sonic integrity tube pod due to damaged pins. If it works; iphone 4 dock connetor cable of your iphone 4 needs to be replaced.
Nov 29, 2010 | Sonic Integrity MP5-DS iPod Tube Docking...
Ipod touch no longer compatable with dock ( Yamaha YDS - 10 )
Even though this is the early dock it should basically work with all generations of pods n phones.
Not sure what your symptoms of 'incompatibilty' are, but see if this sounds anywhere similar.
Had a similar problem recently with a TSX130- same dock technology as far as I know, linking with my iphone 3gs.
phone would disconnect/stop charging after a few secs or minutes- maybe not be recognised when first docked and sometimes caused the TSX to turn OFF...like protection mode requiring a power off full disconnect/reboot.
Other ipods were still ok, it was the phone that had the problem.
Not sure what happened to make this do this but I only solved the problem when I upgraded to OS4 on the phone.
Hope that may help.
AW
Aug 30, 2010 | Yamaha YDS-10 Docking Station for Apple...
After I dock Iphone 3G in JBL Stage II an error message opens
Have you tried not setting it to aeroplane mode ? If you cant put up with the error or if their are bigger issues, sad to say you would have to update you jbl stage to a model that supports your version of firmware or phone model
Jul 29, 2009 | JBL On Stage Speaker Dock for Apple iPod...
Yamaha PDX60BL iPod iPhone Dock Speaker System  Black Logo
60 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
