Question about Intel D102GGC2 Motherboard
There are no sound and volume - Intel D102GGC2 Motherboard
  • Intel Master
  • 32,281 Answers
Try installing the latest audio driver.
You can download the motherboarddevice drivers from Intel WEB site. Select your model motherboard/device, andmake sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system. Please click on this link andselect your model motherboard : - http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Posted on May 24, 2011
I have lost my sound on my desk top pc how do i retrive it bk again
maybe you selected the wrong sound driver. go to control panel. go to sounds, speech, and audio devices. go to sounds and audio devices. go to audio. sound playback, check the device and if diffrent change it and see if that works.
your main volume on all channels where droped. some applications can cause this to happen.
go to start. all programs. go to accessories. go to entertainment. volume control. ensure the volume is up on there. Then if it has it on your volume controll. click on speaker volume that is over top the main volume controll. and make sure your computer speakers didn't drop volume.
make sure the mute is not checked
Oct 25, 2010 | Computers & Internet
Yes sound problem pls helo me now
From the Taskbar located at the bottom of your computer click once on the "Volume" icon.
Uncheck the "Mute" box. If this does not resolve the issue, proceed to step 3.
Right click on the "Volume" icon.
Select "Open Volume Control."
Uncheck all of the boxes next to "Mute" in the Master Volume, Wave, SW Synth (short for synthesizer), CD Volume, Mic Volume, Line Volume and PC Beep selections. If this does not resolve your sound issue, proceed to step 6.
Right click on the "Volume Control" icon.
5
Select "Sounds and Audio Devices Properties."
Under the "Volume" tab, slide the "Device Volume" indicator to High.
6
Under the "Speaker Settings," click on "Speaker Volume."
Slide the "Left" and "Right" volume indicators to "High."
7
Click "OK." If this does not fix your sound issue, proceed to step 8.
8
Go to the "Hardware" tab and select the "Driver" tab.
9
Make sure you are connected to the Internet and then, Click on "Update Driver."
10
After the driver has been updated, Click "OK."
11
Exit.
Thanks.
Oct 10, 2010 | Computers & Internet
No any sound from the pc
Step 1
From the Task bar located at the bottom of your computer click once on the "Volume" icon.
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 10
Step 11
Click "OK." If this does not fix your sound issue, proceed to step 12.
Step 12
Step 13
Step 14
Step 15
Step 16
Step 17
Exit.
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 01, 2010 | Intel DG31PR Motherboard
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
Have external gateway speakers
First make sure your sound cards are working properly. 1) Check the master volume of your PC. Go to start menu, control panel, sounds speech and audio devices, sounds and audio devices - i) In volume tab click the speaker volume and check whether all the left, right, etc.. volumes are in medium or high. ii) In audio tab click the volume tab of sound playback and make sure that the master volume is not in mute and all the volumes are either in medium level or at 100%. After making these changes try playing any music. Even if the problem persists go and get your sound card checked in an authorised service centre.
Thanks & Regards,
Shiva
Sep 11, 2009 | HP (ZD929AA) Computer Speakers
HP Pavillion dv 8000 no sound
check the volumes on sound driver.., also check maybe the master is muted ...if any of these won't work ..check wave volume also ...or reinstall the sound driver ....
look that when you double click the volume in trey system ( bottom right ) you get the full volume manager ..
if those would not fix the issue...uninstall the sound driver and reinstall it ..I assume you have the installation cd ..or the driver on disposal
Apr 08, 2009 | HP Pavilion dv6000z Notebook
Ring volume too low
All you need to do is goto Tools and Settings/Sound Settings/Ringer Volume
Apr 03, 2009 | LG KC910 Renoir Cell Phone
Cable Set-Top Box remot won't change sound vol. Only TV Rem. does
They volume indicator you are seeing is meant to show the volume of content if it were to be recorded on the cable's dvr. This indicator has no effect on the volume of content as it is being watched. This feature allows recording of sound at a set volume even while the tv is off. It sounds as though you'll just have to use the volume buttons on your tv's remote, though you might want to try seeing if there is alternative set-up for those cable volume buttons.
Jan 05, 2009 | Samsung LN19A330J LCD TV
Volume
Hi the volume is just a big fuzzy sound. You can listen to anything. Mute button does work and volume adjustment does work. No Sound at all other than fuzzy sound.
Jan 07, 2007 | RCA 32F531T 32" TV
Intel D102GGC2 Motherboard Logo
173 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
