Question about Pool & Spa
How do I clean my filter/strainer on my rheem pool heater
    Brigadier General:
  • 3,917 Answers
Your filter may be dirty. If so, backwash or clean filter. (To tell if your filter is dirty, look to see if the filter pressure will be higher than usual).So if your pool intake strainer is clogged with debris, therefore it will restrict water flow, or that your main pool filter is clogged and needs to be backwashed. However It does NOT have its own, internal filter or strainer. On indoor heaters, clean room intake openings to ensure adequate flow of combustion and ventilation air. Also your pump strainer basket may be full. If so remove debris.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 24, 2011
My pool heater rheem said clean filter and strainer. not turning on heat what should i do..to solve the problem and tell me how do i clean the strainer where it is location...
They are referring to the strainer basket inside the filtration pump, and the pool filter system itself. The indication is either this basket is full of debris or the pool filter is so dirty you do not have enough water flowing through the heater. A safety device in the heater is shutting down the heater to prevent damage. None of the parts you named are inside the heater.
Jul 18, 2011 | Raypak RP2100 DIGITAL POOL HEATER R206...
I received a notice that the filter needs cleaning. How do I do that?
THis is a PRS code (clean filter/strainer) correct?
This simply means that either there is no water flowing through the pool heater (possibly due to a dirty filter)
If you know you have good water flow, then your pressure switch has failed. Replace the pressure switch.
May 31, 2011 | Rheem M406A 399K BTU Cupro Nickel Pool or...
Prs error code, clean strainer
Your not getting enough pressure to run the heater. So you need to clean the strainers and clean the filter. If you have a DE filter you may want to break it down and clean it. While your at this you should check your pressure switch and your by-pass valve.
Sep 06, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool pump shutting down -- heater?
Trying to get the TA correct before you kill the alge? Leslies diagnosis?
You probally just need to kill the alge before you do anything. Nevermind the TA for now and just add about ten gallons of liquid chlorine. The alge untill you kill it will plug the filter constantly. This will give you the code on the heater and will make the pump run very hot and will hurt the plumbing by shrinking it. This will stop water flo by letting air in also it will leak water at the pump discharge.
A lot of liquid will break the alge as it is unstable, but use a lot.Once you kill the most of the alge then add probally another four gallons and now brugh the whole thing real good. now you can start running again and start with all the stuff they will sell you to adjust the PH and TA. I hope this helps, and good luck.
Jul 13, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Heater not working -
Check the pump strainer basket for debris and see if the pressure is high on your filter. If so, backwash time. The "filter: error is usually restricted flow...
Jun 18, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
What do you do about a service strainer notification on a rp2100 digital
Clean the strainer basket on your pump and clean your filter. If this does not help you will need to check your impeller expecally if your basket has any cracks in it. Also if you have a by-pass valve between the inlet and outlet pipes going to the heater that should be 80-90% closed. Hope this helps, good luck.
Jan 23, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypack gas pool heater displays"clean filter/strainer" when I turn it on
There is not enough system pressure to close the heaters pressure switch so the heater will not fire. Assuming your pump is on and any valves in your pipes are set correctly it means something is restricing water flow too much and needs to be cleaned to fix your flow rate and allow the heater to fire.
Start at the skimmer(s) baskets and then the pump strainer basket and finally clean your filter. If sand, backwash it. If cartridge or DE clean according to your manufacturers direction. In some cases cleaning a cartridge filter will no longer satisfy heater pressure requirements meaning you will need to replace the element.
Nov 11, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Says clean filter strainer
Could be the pressure switch on the heater. Jump switch. If heater fires the switch is bad
Jul 11, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Pool & Spa Logo
848 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
