.nzHi There - the first
  • 1 more comment
  • kmilton897 May 24, 2011
    Hi Sorry - its a Fisher & Paykel GW712. It wont wash or spin. If I turn it off at the wall sometimes it fixes itself but over the last couple of weeks not even that helps. It will attempt to wash and spin but doesnt have enough grunt to do it and the machine just start beeping.
  • kmilton897 May 25, 2011
    So basically this is a job for a qualifed technician? Dam was hoping to fix it myself. The machine is only 4 years old - surely they make them to last longer than that.
    HOw hard is it to check and fix a belt on the washing machine. I think my problem may be the belt?
  • 4,323 Answers
Hi
The error code reading from right to left (not left to right) indicates a faulty pump that should be replaced. I mean flashing lights from left to right won't even give a error code. So it seems that the pump is stuck or clogged and the error means that the display module has read an incorrect voltage on the pump circuit. If the pump is fine then the display module should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on May 25, 2011
  • 4,399 Answers
Thanks for choosing FixYa and welcome. What model and make is your washer please?
  • Richard Hale
    Richard Hale May 25, 2011
    Ok I saw your last post. Since the spin and agitation both do not work, it would lead me to think it is a part that controls them both. It may be the part that connects the washer motor to the agitator drum. In order to get to it, the drum will need removed. You need to check your belt also. The drive motor controls the spinning, agitation, and the draining. Listen to hear if it is coming on. If not, it may be bad or not getting power. If this is the case, you will need a voltage meter to test the wires. There may be a problem with the board causing the motor to not receive a signal from the board also. To be honest, it is hard to tell without taking the machine apart to run a few test.
    Brigadier General:
  • 3,917 Answers
Hi
The problem you have stated are not clear.Kindly be a bit precise about the error code and the type of washing machine you have.So that it will be easy for us to solve your query.
Thanks for contacting fixya.com
Posted on May 24, 2011
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
E000805-0000 E000110-001
FIXING EXAS FAN ,,, IN RIGHT SIDE DOOR
Feb 06, 2018 | Canon Office Equipment & Supplies
The DVD RW/CD-RW'S DRIVER is not working
CHeck the Device Manager. Does the CD/DVD Drive show up in Device manager, and when you right click it and choose properties, does it give any error code, like Error code 39?
Normally the CD drives use the default Windows drivers. Try right clicking the HL-DT-ST DVDRAM GSA T50N ATA Device in Device Manager and choose uninstall. Then reboot the computer and Windows will find the device and re-install drivers automatically.
If you are still getting the error, it may be an update or some other program that added data to the DVD's driver data in the registry. Try this:
1) Close all open programs
2) Click on Start, Run, and type "regedit" (without the quotations) and press Enter. Back up (File > Export) the registry before you make any changes)
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • Left Click and Highlight: {4D36E965-E325-11CE-BFC1-08002BE10318} **Make sure you choose this exact key**
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed on the right hand side, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Apr 11, 2009 | HP Compaq Presario SR1420nx...
MP145 with E42 22 ?
E42 means scanner error. It's posible to be dirt scanner timing sensor or the whell. You can check videos on youtube to find how can fix this issue in detailed mode.
All the best !
Oct 08, 2017 | Canon PIXMA MP150 All-In-One InkJet...
How to fix code 39 err
I was fixing a computer the other day and ran across the following error in Device Manager on the CD-ROM drive.
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Because of this error, the drive did not show up in My Computer and the customer was unable to burn CDs or read any CDs.
I uninstalled the drive from Device Manager, rebooted the computer, and the problem remained, so obviously it appeared to be a registry issue that I would have to solve. If you are receiving this Code 39 error and your CD or DVD drive is missing and has a yellow exclamation mark in Device Manager, I hope this information is useful.
To solve this Code 39 error, follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
2) Click on Start, Run, and type REGEDIT and press Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
UpperFilters
LowerFilters
UpperFilters.bak
LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
Another possible CD/DVD issue you may want to investigate
How to Correct Missing Copy to CD option in My Pictures in Windows XP
Oct 18, 2008 | Computers & Internet
Error E000
This is a reprint from another tech, he was right on with this...
okay lets shed some light on the E000 error code on the D680, D880, IR1300 family ( including the 1310,1330,1370,1630,1670)
The error code E00 is a memory threshold error what it means is your machine has logged 4 of the following errors, E001,E002, or E003. It is a lockout error and the machine cannot be used until the problem has been repaired or the errors cleared. First lets look at the errors:
E001 fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
E002 fuser temp dropout means the fixing assy has cooled below a set point during a copy session
E003 fuser no response means the fixing assy didn't even attempt to warm up at power on
How to fix, most common problem is bad power setting 4 E002's either brown outs of brief power failures.
To clear the error, Enter service mode by pressing additional functions then the # button, use the left or right arrow buttons to scroll to #7 printer press set. again use the arrow buttons to scroll to #4 printer reset press set. press the appropriate arrow key under the YES to clear the error. unplug the copier and reboot. At this time normal function should return if not and it resets a E00 the you can assume either the fixing assy is bad or either the power supply PCB or DC controller is bad and it is getting E001,E003 errors. At that point id call a qualified tech to research the problem to avoid spending money on excess parts
Hope that helps...
Lbcoaster
Aug 08, 2008 | Canon ImageClass D880 Copier
Canon Imageclass D860 - I have a System Error E000 code on the LDC display. No paper jam or other problems evident. Disconnected power for 10 minutes and that didn't help. For this error code I am to...
Hope that helps...
Lbcoaster
Aug 08, 2008 | Canon Office Equipment & Supplies
Falla cannon
Hope that helps...
Lbcoaster
Jul 11, 2008 | Canon ImageClass D880 Copier
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
Washing Machines Logo
Top Washing Machines Experts
