Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
Kenmore 2.1 cu. ft. Portable Washer - won't drain
Hi, I have a Kenmore 2.1 cu. ft. Portable Washer (top loading) that won't drain. It pumps water in fine and agitates but then it just stops and clicks and hums. I have tried manually draining the water by removing the hose at the bottom and when the water is out, the washer will continue an spin.
Can anyone provide any advice on this situation? I would love to fix this myself if at all possible- so instructions would be amazing! And does anyone know where I can find a manual for the Kenmore 2.1 cu ft compact portable washer?
Thanks for any support!
  • 1 more comment
  • mipollo Aug 17, 2008
    Nagyboo, you're totally right, there was a bunch of junk in the pump. I just had to be brave enough to turn the machine over and take it apart a little. Thanks for the response!
  • jchicco Oct 05, 2008
    I have the same problem - it appears to be draining (meaning water comes out of the hose into the sink) but when it's finished the clothes are still dripping wet, so I know it has not drained completely. Maybe the problem is in the spinning? it's not spinning hard enough? How could I fix that?
  • Anonymous Mar 24, 2014
    My Washing machine is making loud noises while in the spinning cycle
Probably something caught inthe pump. Will have to remove pump and take obstruction out. Only other thing I can think of is the pump ran tight and would have to be replaced
Posted on Aug 17, 2008
  • jay maxx
    jay maxx Apr 20, 2014
    I have the same problem with the water not draining, this is my 3rd sears machine and rather than pay the continued rising cost of sears maintenance I will get another brand.
Washer is full of water. drain is blocked with hair or lint i believe. washed some nasty stuff. wont drain. how do i clear the blockage? i think may be blocked inside washer. drain hose is very narrow...
If you can get a garden type water hose near there, try to carefully use it to blow the water backwards through the drain hose. Put the hose up to the drain hose end and wrap a rag tightly around it and turn the water slowley. This may free up any debris from the hose and pump. If anything comes out,clean it out of the tub before you turn it back on.
Sep 02, 2011 | Kenmore 2.1 cu. ft. Portable Top Load...
Washer won't drain the water out of the machine.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 29, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My kenmore portable washer, washes but does not drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 07, 2010 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore portable washing machine won't drain all the way
most common cause is there is a sock or other small item in the inlet hose from the drum to the pump, restricing water flow and the normal time allowed in timer cycle is not enough
open the cabinet as described elsewhere, I am just too laxy to type it at the moment.
examine the short hose from the drum to the pump, and unblock it
Aug 21, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
648 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
