Question about HP ScanJet 3200C Flatbed Scanner
When I scan a picture I get the image of upper portion , that too noisy with colored lines. For the rest part of the picture do not appear. I get only garbage.
SOURCE: Lines appearing in scanned images
it is due to following reasons 1. dust on lense 2. connector problem 3. laser lense gone 4. missalingment
Posted on Sep 30, 2007
mumma_1
  • 903 Answers
SOURCE: scanned image appears with lines going through it
it is possible, but first try cleaning the glass with a window cleaner and a soft cotton cloth and under the scanning options increase the quality to a higher setting and see if this helps at all. You may even benefit from purchasing a new scanner if this does not work as they a fairly resonably priced and will save you the hassle of repairing it.
Posted on Jan 15, 2009
SOURCE: I'm using a HP Scanjet 2400 scanner. After I
THIS THE PROBLEM OF YOUR DATA THIN CABLE WHO HAVE INTERLINK WITH CCD BOARD WITH PAWER BOARD PLZ CHANGE WITH CABLE AND 100% SOLUTION
ASHOK RANA JALANDHAR
9815424965
Posted on Apr 02, 2009
mohanchennai
  • 490 Answers
SOURCE: vertical line in scanned image
This is because of dust sticking to the glass. Clean with isopropyl alcohol (rubbing alcohol) and dont use solvents. For emergency you can use your after shave but take care only to clean the glass portion!
S. Mohan, Chennai, India
Posted on Jul 09, 2009
SOURCE: Mustek Scan Express A3 USB
Got same problem. Beginning to suspect the traveling lamp or associated electronics. Looking out for parts suppliers for elimination trials. Strange, once in a far while it works. Updated drivers again this very day.Suggest you try a good power adapter, and if you are technical, search for loose connections. Will keep you posted if I solve mine, being an electrical engineer, NOT electronics.
Pax
Posted on Feb 27, 2010
I HAVE A LC401EM2F EMERSON TV 2 YRS OLD. WHEN I TURN ON THE TV I INITIALLY GET GREEN VERTICAL LINES, AFTER IT HAS FOR BEEN ON FOR A FEW MINITUES, THE VERTICAL LINES DISAPPEAR BUT A HORIZONTAL LINE APPEARS...
It sounds like a power surge has damaged the color controller and scan line section of the circuit board. The cost to repair is more then the replacement cost. Next time use a UPS for protection (battery back up for computer and electronics). Regards DaytonComputerDoctor@hotmail.com
Dec 18, 2013 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
How do I accent one colour and make the rest black and white?
This is a photoshop technique done in "post" processing. The picture is first made in color, layered in Photoshop, changed to B&W, then a portion of the picture is brought back to color. The image is then flattened and saved as a different file number.
Dec 22, 2010 | Canon PowerShot SX30 IS Digital Camera
How do i scan using a HP desktop F380
Deskjet F380 features a scanner within the upper portion of the device. "Scanning" an item describes the electronic process of converting pictures or text to data, then transferring that data to the computer as an image. Scanning an item into the computer is a simple task with the F380, the only limitation is the size of the item,
follow the steps below
Step 1
Turn the unit on by pressing the "On" button located at the top control panel. The control panel is located on the left side of the unit. The "On" button will illuminate to indicate that the unit is receiving power.
  • Step 2 Load the scanner with the item to be scanned. First, lift the lid of the F380 to the upright position to reveal the scanning surface. Place the item to be scanned face down onto the scanning surface. Position the item so that the edge of the item rests squarely against the front left-hand corner of the scanning surface, then close the unit's lid.
  • Step 3 Press the "Scan" button located at the lower left-hand corner of the F350's control panel to start the scan. If necessary, the scanning process can be stopped by pressing the "Cancel" button located just to the left of the "X" on the control panel.
  • Step 4 Save the scanned image to the computer when the scan is complete by clicking the "Accept" button on the window that appears on the computer's monitor.
  • Dec 29, 2009 | HP DeskJet F380 All-In-One Printer
    How do you scan a picture into the computer with a lexmark P6250?
    SORRY, I COULD DO ALL, SAID TOO BIG, Using a computer 1. Make sure your All-In-One is connected to a computer.
    2. Load your document face down on the scanner glass. For help, see Loading your document on the scanner glass.
    Open the Lexmark Imaging Studio. For help, see Using the Lexmark Imaging Studio
    4. Click the Scan button.
    The All-In-One Center appears with the Scanning & Copying tab expanded
    5. Click Preview Now in the upper right corner of the All-In-One Center.
    An image of the scanned item appears in the preview section.
    6. Click and drag the dotted line box to select a specific area of the preview image to scan.
    7. Click Display Advanced Scan Settings to review and change the scan settings. Click OK.
    here is the web site where the info was. If you want to see better images just click on link below. good luck :0)
    MORE LOOK AT WEB SAYS TOO LONG
    http://www.lexmark.com/publications/
    pdfs/2007/6200/winug/en/frameset.html
    Nov 19, 2009 | Lexmark P6250 All-In-One InkJet Photo...
    Visual transparent lines at top of picture
    You have a vertical output circuit problem. This was common for Philips' sets. Have a repair shop check it out. Should not be too expensive to repair.
    Oct 15, 2009 | Philips 27PT6441 27" TV
    How do I tell scanner to save pictures to a designated file? When I 'browse' and try to select a place, the 'OK' goes pale & I can't click on it. It seems to want to send it in an email.
    hi,
    Basically when you are saving pictures or images after scanning them out, all of you have to do is, click on File Menu bar on the upper left portion of your PC screen. >Select Save from the drop-down menu and try to locate the computer drive (e.g My Documents) where you want to save the item exactly.
    Hope to get your issue resolved,
    Jazerblue
    Aug 28, 2009 | Canon CanoScan 4400f MultiFunction Color...
    Scans wrong size...only scan a portion or smaller "window" of document
    Normally these scanner have a prescan window whcih shows the image that is being scanned. Only the selected area will be bright and the rest little shaded. You need to expand the selection, by dragging the line (dashes running along the border). Select default option in the software setting, if in doubt.
    S. Mohan
    Jul 18, 2009 | HP Office Equipment & Supplies
    Vertical line in scanned image
    Jul 08, 2009 | Kodak i40 Path-Through Scanner
    Trying to scan and then attach as document an 8.5 x 11 paper
    Usually there will be a dashed line that is around the image. Sometimes it will just surround a darker portion of an image, such as the text portion on a white piece of paper. This is common. Use the mouse and aim it at the dashed line and "pull" the lines to the edges of your document, then press accept. This should fix your problem.
    Jun 14, 2009 | HP Photosmart C5180 All-In-One InkJet...
    Images appear to be very noisy or grainy
    When DIGITAL ZOOM is set to ON in the MODE MENU, the lens can zoom into the Digital Zoom portion of the zoom by pressing the zoom (T) button. When you see the zoom indicator on LCD enter the red portion (towards Tele), the image in the viewfinder will become closer. However, since the D-630 is using the digital portion of the zoom, the lens doesn't physically zoom, it takes the existing image and enlarges your image using an electronic program. This can result in a “noisy” or “grainy” look to the image. This is normal when using the DIGITAL ZOOM. The DIGITAL ZOOM can be turned OFF to prevent you from using this portion of the zoom. Locate DIGITAL ZOOM in the Mode Menu and set it to OFF.
    Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
    HP ScanJet 3200C Flatbed Scanner Logo
    29 people viewed this question
    Seeker5211
    Seeker5211
