Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Dishwasher spray arms don't spin & spray water
When washing the arms arn't spraying water leaving the dishes dirty. I'm having the same (or similar) problem with my Kenmore Elite 665.15953000. The bottom arm spins and cleans dishes on the lower rack, but the middle spray arm doesn't spin and just sort of dribbles water out. As a result the top shelf items don't get cleaned at all.
I've followed your advice and I'm getting water to the proper level (in fact, the very bottom of the heating element actually sits in the water). I had a repairman here yesterday who took apart the lower arm and checked the food chopper and filter. He said everything looked clean as a whistle. He then said that this model has a secondary pump to get water to the top levels and that must have gone bad. He's advice -- to replace the dishwasher. The main pump works fine and drains the wash water every time.
After doing a little research, I'm not sure there is a secondary pump or that he knew what he was talking about. Do you have any additional advice or should I just chuck my dishwasher which had previously given me no problems whatsoever.
    Master:
  • 623 Answers
Go here
www.partselect.com/repair.aspx?appliance=dishwasher&part=dishes-not-clean -
Posted on Aug 15, 2008
  • ritchie dempacco
    ritchie dempacco Aug 15, 2008
    or here
    www.fixya.com/support/t397577-dishwasher_no_spray_arm_action
    Master:
  • 521 Answers
It is not a major problem i will send you the solution for help.
  • tech expert12 Aug 15, 2008
    It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher.
    The motor (and pump) located beneath the dishwasher.
    Check if motor spins. In case it spins, the problem is with the pump ,in case it doesn't spin it could be a motor problem or a motor and pump problem.
    First of all: filter plate clean? Clean any locked hole.
    1) Can you remove the upper spray-arm and verify if holes inside are locked by any residus. Clean the holes , and check if pure water come out when you fill the center hole with some water.
    2) Switch on the dishwasher , coldest wash cycle dish-washer empty and without the upper spraying arm. Once you hear water streaming in, open the door and look if a little water fountain comes out from the center hole where the upper spraying arm was fixed. If not, this canalisation is blocked and should be cleaned. Try to continue the wash cycle, often the water pressure will clean itself this canal. Check also lower spray arm: it should be rotating a while and ejecting water thru its holes. If not, verify this canalisation as well.
    3) Put the spraying arm again on its place, verify also the sealing else water pressure is going down and spraying will not turn and spray water.
    4) Again, continu a wash cycle, open the door and look; upper arm should be rotating and some rays trown out.
    Hopefully, this helps .
    If not, pump pressure may be low; have a repair verify, can be that only brushes in the motor must be replaced, can be the pump worn out and to be replaced at all.
    pls do rate the solution that helps you.keep me updated.thanks.
  • Kenmore Master
  • 19,396 Answers
Check that the water pumped on arms has enough pressure.
  • 1,029 Answers
It could be due to Not filling enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
check the food chopper:
Remove lower spray arm and rear water supply tube to upper spray arm.
. Remove torx screws that secure the sump cover. Remove primary filter. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
Dirty dishes
Aug 12, 2008 | Asko D1776 Built-in Dishwasher
Dishes are always dirty, maybe even dirtier after running dishwasher. has hot water, lower arm moves.
Check the outlet holes on both spray arms for clogs. If necessary, remove the spray arms, clean out the holes and empty out any debris inside the spray arms. Verify that the upper arm is turning also.
If the machine does not drain completely at the end of the cycle, the pump drain outlet is partially blocked and you are retaining dirty water for the next load.
You may have a chemistry problem - inferior soap, empty rinse agent dispenser, or extremely hard water.
Improper arrangement of the dishes can prevent some from being washed. Make sure no dish blocks the spray to another.
Jul 23, 2011 | Dishwashers
2 MONTH OLD bosch DISWASHER. WATER WILL COME OUT BUT TOP SPRAYER ARM WONT SPIN??? LEAVING DISHES ON TOP DIRTY??? LOTS OF WATER PRESSURE THATS NOT THE PROBLEM HELP!!!!!
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 31, 2011 | Dishwashers
Hi, I have an LG LDS4821 dishwasher and it appears to stop working properly. The dishes don't seem to be cleaned at all. It seems like the spray arms are not spraying the dishes as the dishes are still...
Dishwasher
How to Buy
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 16, 2011 | LG LDS4821 24 in. Built-in Dishwasher
The dish washer is taking ages to wash and it not clean ing dishes well
ok so If your dishwasher has worked fine in the past but, suddenly, your dishes aren't clean after the dishwasher completes all cycles:
1) Check your water heater's temperature dial to be sure it hasn't been changed recently.
2) Be sure dishes haven't prevented the detergent dispenser from opening properly during the wash cycles or kept the spray arms from turning, the lower arm from rising, or the spray from reaching the upper rack's dishes.
3) During the wash cycle, listen to the spray arm spinning inside. If it seems to be spinning poorly, clean out the spray holes in the spray arm(s) with a stiff piece of wire; wait for the machine to cool, and then remove the spray arm(s) by unscrewing the hub cap and lifting the arm(s) off
Regards Gizokieth
Sep 10, 2009 | Dishwashers
Soap build up on dishwasher. Dries white and stays on dishes.
the spray arms is eather bad or the wash motor ,,,,, it isn't spraying water onto the dishes with any force.
Larry
Nov 25, 2008 | Dishwashers
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Jun 29, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Upper arm does not spray
Dig deeper, until you find filters. Those are probably clogged. You may need a screwdriver...
Dec 29, 2007 | Kenmore 15952 Dishwasher
Dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Nov 19, 2006 | Frigidaire 24 in. FDB126RB Built-in...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
1,034 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
D. E. Hev
Raisin Brann
Level 1 Expert
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
