Question about Vacuums
I need to know which water lines go to and from pump on bissellporheat steam cleaner? mod.#1699R
The plastic screw-on cap for the fresh water/solution tank has a tiny internal spring loaded plunger that looks like an "X" when viewed from the end. There is a donut type rubber gasket that goes on the end of this screw-on cap. I had reseated this donut gasket but the rim interferred with the plunger so it discharged when I pressed the tank into position. When I got the donut gasket reseated properly, leaking was solved.
Posted on May 28, 2011
Repair Polti VT Evolution steam cleaner doesn't work
Steam nozzle/lines are probably clogged. The minerals in the water will eventually clog up the system, you need to use only Distilled water whenever possible to eliminate as many minerals from the water as you can. If the screws are spinning and not coming out, you will have to pry up slightly on the cover the put pressure on the inner parts so they will come apart. Easiest way is to push something like an old credit card betwen the seams and pry up carefully. go slow and easy so you won't break anything.
Aug 20, 2014 | Vacuums
Bissell steam mop
-Pump is out (Broken). or water line is clogged.
Good Luck
Mai
Aug 19, 2014 | Bissell Lift-Off Steam Mop, Titanium, 39W7
Shark portable steam cleaner heats up but does not produce steam
Built in thermostat...sounds like you need to buy a new steamer.
Dec 12, 2013 | Vacuums
Aquamark hand held mod.am680 not steaming why
hi there did you find a solution i have the same problem thanks
Mar 01, 2013 | McCulloch MC1246 Handheld Steam Cleaner
Water won't spray out of the cleaner
If it won't dispense water then that means that the pump belt needs to be replaced. Here is the belt you need:
Bissell Proheat Pump Belt
May 22, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
No water
check the pump belt that runs from the brushroll to the pump. frequently the plastic gear on the pump wears out. the pumps also frequently fail. check all solution supply lines for cloggs, and most importantly check the spray nozzles inside the unit by the brushes for cloggs. let me know if you need any further instructions. thanks,
chuck
Jan 07, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
No steam
I used the straw to prime the lines and 50/50 mix of vinager and water and it worked perfectly. I then mixed the water container with the same mix and ran it through the system. All works fine now.
Feb 20, 2008 | Black & Decker SV1000-4 SteamBuster Vacuum
Vacuums Logo
266 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
