Question about Brother IntelliFAX 5750e Laser Fax
No confirmation and can't fax any outgoing
Hi. The fax machine at work does not seem to print any confirmation and won't take any outgoing faxes. On the screen it says, "RESERVED and it's on SLEEP. Can you guide me on how to resolve this?
    Genius:
  • 2,120 Answers
There is a fax stuck in memory. Try unplufgging the machine for 30 secs.
Plug a regular into the wall jack to verify that you have a dial tone.
Posted on Sep 30, 2008
How do I set the Fax 2910 Brother to print a fax confirmation each time? Thanks
Using the Reports Key
Five reports are available:
1 HELP LIST: Prints the Menu Table so you can see at-a-glance how to quickly program every menu selection.
2 AUTO DIAL: Lists names and numbers stored in Speed Dial and One Touch Dial (FAX models only) memory, in numerical order.
3 FAX ACTIVITY: Lists information about the last 200 incoming and outgoing faxes. TX means Transmit; RX means Receive.
4 TRANSMISSION: (CONFIRMATION) Prints a Transmission Verification Report for your last transmission.
5 USER SETTINGS: Lists settings for GENERAL SETUP, SETUP RECEIVE, SETUP SEND, SETUP REPORTS, and TEL SERVICE.
The settings for REMOTE FAX OPT are included.
Jan 18, 2011 | Brother IntelliFax-2820 Laser Fax
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
Confirmation
By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Oct 14, 2008 | HP LaserJet 3055 All-In-One Printer
Print Fax Confirmation
Press MENU button, then 5 on the numbers keypad. you should be able to scroll through a list using the up and down buttons. #1 is the HELP LIST, #2 is AUTO DIAL, #3 is FAX ACTIVITY which shows LAST INCOMING AND OUTGOING faxes,#4 TRANSMISSION,prints a TRANSMISSION VERIFICATION REPORT of the last transmission. #5 USER SETTINGS lists your setting. To select your report, select the REPORT NUMBER, press SET, then START, to print
Jun 23, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Fax confirmations
i have read the manual end to end and I don't think you can.
Only thing I see is this.
Customizing your settings using the Lexmark Fax Solutions You can adjust the fax settings in the Lexmark Fax Solutions. These settings apply to the faxes you send or receive.
  1. Click Start onestep.gif Programs onestep.gif Lexmark 7100 Series onestep.gif Lexmark Fax Solutions.
  3. Click each tab and change the settings as desired.
  4. Press Save Settings after you finish your updates. Nothing is saved until you press this button.
  5. Click Close.
The following table contains the Setup and Settings tabs for the Lexmark Fax Solutions.
On this tab
You can
Personalize
  • Enter your company name and fax number.
  • Enter your name, company name, phone number and address as you want them to appear your cover page.
  • Select a cover page for your fax.
Send
  • Choose to use error correction.
  • Choose to use fax header.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report
Select when to print an activity report is the only close item I can find. Nothing whatsoever about a confirmation report.
Feb 25, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Confirmation Printout
Yes go into reports on the operation menu. use the arrows to get where you want and confirm by hitting set.
Nov 13, 2007 | Brother IntelliFax-4100e Fax
Can't get Fax Confirmation page to print
What model brand name something!!!!!!
Nov 12, 2007 | Sharp AR-F152 Fax
Brother IntelliFAX 5750e Laser Fax Logo
180 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
